Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Dec 15, 2017 4:48 pm Post subject: Re: Puking oil from cylinders after rebuild |
Wow that really is puking oil. Check for cracks or the cylinders not seating into the case or damage between the cylinders and case.
No sealer between the cylinders and heads. |
Danwvw Samba Member
Posted: Fri Dec 15, 2017 4:49 pm Post subject: Re: Puking oil from cylinders after rebuild |
Well it must be? It's the story we have. The crank is going to shove a lot of oil up against the cylinder openings. Maybe the case cylinder opening decks need checked. Maybe a cylinder did not seat. My spare engine below "1800cc's Webcam 118 and 1.25:1 Rockers" was fine till I revved it up and Oil started flying out the side of cylinders on both sides of the engine. The problem turned out to be cracked cylinders though. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
rodjr Samba Member
Joined: October 12, 2015 Posts: 223 Location: stanwood washington
Posted: Fri Dec 15, 2017 6:42 pm Post subject: Re: Puking oil from cylinders after rebuild |
Permatex The Right Stuff, no leaks, will hold cylinders with the heads off no problem, and doesn't peel off all stringy. Also no waiting for it to dry, it's good to go as soon as you torque it down. I have not used silicone on a single thing since i discovered it, and i have tried it everywhere i used to use silicone with 100% success. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Dec 15, 2017 7:06 pm Post subject: Re: Puking oil from cylinders after rebuild |
Dürtwagen wrote: |
I was told never to use sealer where the head mates to the jugs, is this accurate? |
Correct. DO NOT USE SEALER BETWEEN THE HEAD AND THE TOP OF THE CYLINDERS. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Dürtwagen Samba Member
Joined: May 13, 2016 Posts: 271 Location: Cottonwood, Arizona
Posted: Fri Dec 15, 2017 7:25 pm Post subject: Re: Puking oil from cylinders after rebuild |
This is a top view of cylinders 3 & 4 , notice the gap difference between the case and jug, but also notice that where it meets at the head, the fins are level with each other. Is this normal?
And here is 1 & 2
_________________ 1974 VW baja bug
1979 Mercedes Benz 300D |
Danwvw Samba Member
Posted: Fri Dec 15, 2017 7:35 pm Post subject: Re: Puking oil from cylinders after rebuild |
Yeah it's right but you know what I bet you got a pulled stud. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Fri Dec 15, 2017 7:42 pm Post subject: Re: Puking oil from cylinders after rebuild |
Please change the tittle of this thread from "rebuilt engine" to "I hacked some junk together, what should I do?" _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Fri Dec 15, 2017 8:06 pm Post subject: Re: Puking oil from cylinders after rebuild |
That one that looks like the case saver came out does have threads and screws in but I just realized that could be whwre a lot of oil is coming from _________________ 1974 VW baja bug
Posted: Fri Dec 15, 2017 8:29 pm Post subject: Re: Puking oil from cylinders after rebuild |
mcmscott wrote: |
Please change the tittle of this thread from "rebuilt engine" to "I hacked some junk together, what should I do?" |
Pretty ignorant statement.
Why Don’t you go stick your shit opinion somewhere else hmm? _________________ 1974 VW baja bug
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sat Dec 16, 2017 12:33 am Post subject: Re: Puking oil from cylinders after rebuild |
Dürtwagen wrote: |
mcmscott wrote: |
Don't bother listening to that mcmscott guy . . . he's probably just some novice that'll crank on a new engine for days without checking to see if it has gas!!!! _________________ Jesucristo es mi Señor y Salvador! |
Posted: Sat Dec 16, 2017 9:42 am Post subject: Re: Puking oil from cylinders after rebuild |
57BLITZ wrote: |
Dürtwagen wrote: |
mcmscott wrote: |
Don't bother listening to that mcmscott guy . . . he's probably just some novice that'll crank on a new engine for days without checking to see if it has gas!!!! |
Well, shit happens. when the gauge tells you there is gas in the car, and there is fuel getting to the carburetor, naturally i assumed the car had gas, which it did just not enough apparently. I don’t know how you guys can talk shit, the engine runs great and looks damn good.
Is this all you do is bag on people trying to solve a problem? _________________ 1974 VW baja bug
Danwvw Samba Member
Posted: Sat Dec 16, 2017 6:18 pm Post subject: Re: Puking oil from cylinders after rebuild |
So what is the scoop? Pulled insert? Just not tight? Is the engine still out? If so and it doesn't need inserts ?? then RTV right. If it needs inserts, then, case comes apart right? 10mm studs need inserts.
Posted: Sun Dec 17, 2017 9:09 am Post subject: Re: Puking oil from cylinders after rebuild |
The engine is in the car still in the car, I didn’t have time yesterday but I’m free all day today, I’m gunna pull the exhaust off and get as much done as I can today, just sealing everything up . I’m gunna look for the ultra black.
Also I’ve been soaking the oil cooler bracket to clean it _________________ 1974 VW baja bug
Posted: Sun Dec 17, 2017 12:18 pm Post subject: Re: Puking oil from cylinders after rebuild |
THis cylinder looks like it’s not seated at the bottom, like it’s cocked upwards, is that no good??? _________________ 1974 VW baja bug
Danwvw Samba Member
Posted: Sun Dec 17, 2017 12:48 pm Post subject: Re: Puking oil from cylinders after rebuild |
The top head bolts would have to have been tightened down first with the bottom loose to do that. What happens if you remove the rockers loosen all the head bolts and go through both torque sequences again? Do the studs hold? etc...
Posted: Sun Dec 17, 2017 12:55 pm Post subject: Re: Puking oil from cylinders after rebuild |
Alright so it’s not supposed to be like that I’m guessing. I tightened them in the same sequence as one of the books said, with a torque wrench. Im loosening the bolts now engine should be out in a few min . I got permatex Ultra Black today . _________________ 1974 VW baja bug
Posted: Sun Dec 17, 2017 1:06 pm Post subject: Re: Puking oil from cylinders after rebuild |
Yeah that's the problem. That thing isn't seated at all. I'm surprised the head sealed. Or did it? Check for piston/ring/cylinder damage too. |
Danwvw Samba Member
Posted: Sun Dec 17, 2017 1:08 pm Post subject: Re: Puking oil from cylinders after rebuild |
With the top studs coming out of what looks like inserts it could be leaking there. On cases about 1/2 of the stud thread holes are blind and can't loose any oil but some are open to the inside of the engine. I would want to make sure both inserts & studs were sealed with thread sealer locker Blue thread locker sealer on the studs usually red is used on the inserts by a machine shop. Probably a machine shop job though to remove inserts and re seal them with thread locker. I have done it though on ones that weren't thread locked to start with. Had to make a spare stud with locking nuts and a collar. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
modok Samba Member
Posted: Sun Dec 17, 2017 2:27 pm Post subject: Re: Puking oil from cylinders after rebuild |
When you replace cylinders on these engines one thing you have to do is set the new cylinders in place with the studs and 6 main nuts in place and see that it sits flat on the case, and see that there is some clearance so you can rotate the cylinder slightly without it hitting anything.
Very common that the cylinders will hang up on the studs, or the case savers, or eachother, or hit the 6 main nuts/washers and you have to grind the cylinder for clearance in these areas. It's not supposed to fit the case tight either. If the case smooshed in and not it's a TIGHT fit int he hole that's NG. |
Posted: Sun Dec 17, 2017 2:49 pm Post subject: Re: Puking oil from cylinders after rebuild |
Alright I got the engine on the stand, I had to take the flywheel and clutch off, I’ll do some investigating now
