Did you change it because you needed a new starter? |
Did you change it because you wanted the higher torque? |
28% |
[ 7 ] |
Did you notice a real change in starting 2.1 WBX with it? |
28% |
[ 7 ] |
Did you not really notice a big change between it and the OEM starter? |
12% |
[ 3 ] |
Did you think it was worth the time to change it if your OEM was working? |
32% |
[ 8 ] |
Total Votes : 25 |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Sat Dec 16, 2017 1:20 pm Post subject: Re: TDi Starter - Is it Hype? |
Steve M. wrote: |
I'm just not seeing a great improvement. My Syncro with a stock starter starts just as easily compared to the TDi starter.
I might add that I did increase the wire gauge for the starter wiring so old wiring or too small a wire gauge is not an issue. |
My '81 with ABA gas I4 has a new gear reduction starter on a Mullendore adaptor. HUGE improvement over the stock Bosch starters I had in rotation. That new starter has been absolutely flawless over the last ~ 10K miles operating under a variety of ambient temps with a battery thats at least a few years old. I don't recall if it's a slightly larger gauge but that van has a 1985 starter to battery cable and engine compression should be in spec. On my '88, installing a NOS OEM cable made no improvement to my $$ rebuilt WBX starter. (and no obvious difference to charge system). And that starter was turning a 2.1 WBX with lower compression readings. On that '88 the yet to be started rebuilt ABA conversion will have the same starter upgrade. I bet the original starter cable would've operated this new gear reduction starter on this rebuilt ABA engine just fine.
Both vans have a manual transmission.
I've only ever had one Bosch Vanagon rebuilt but in my limited experience, even a new off shore starter vs a rebuilt older Bosch core stands a better chance of being reliable. And, the electrical-mechanical advantage and better future proofing using a gear reduction starter makes money spent on the adaptor plate a "no brainer". Bonus; I will most likely never feel a need to pack a spare starter.
1988 West DIY 50º ABA
VE7TBN |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2329 Location: Southeast Kentucky
Posted: Sat Dec 16, 2017 4:28 pm Post subject: Re: TDi Starter - Is it Hype? |
This is the 1st of three Remans from Autozone over about 30 days that I installed on my 89 Van. The OE starter had about 148k miles on it. They are OE replacements (not TDI).
This one was a Bosch reman. The other two were no-name brands as far as I could tell. The 3rd one has worked like a champ for about 11 months.
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Sat Dec 16, 2017 4:47 pm Post subject: Re: TDi Starter - Is it Hype? |
In this forum you won't likely hear feedback from all the non-Vanagon applications I've sold them to as well. Trikes, V8-powered builds, Beetles and buses with Subarus, TDIs and other engines. When I designed the adaptor I thought maybe I'd sell a hundred or so. I think I'm at 700-800 right now. Blown away - so thanks everyone for buying!
I bought a 1990 MV automatic last year, which came with a new rebuilt starter and 'sketchy' engine. I replaced the engine with a DJ-code 112hp wbx I had on hand and at the same time one of my adaptors and the Latrical (CA starter) knockoffs. It never fails to crank fast whatever the temperature, and often fires off in less than one revolution. The fast cranking speed and almost double the torque of the stock starter makes it one of my favorite mods too. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Sun Dec 17, 2017 7:31 am Post subject: Re: TDi Starter - Is it Hype? |
syncrodoka wrote: |
I changed over to the 1.8T starter with the adapter rather than the TDI starter with my stock engine. I went with that one due to a easier installation procedure in a syncro with a diff lock with it's shorter length.
How much shorter is the 1.8T starter compared to the OEM design for the 2.1wbx? That sounds very attractive for the reason you stated!
Do you have a part number or link as a source? _________________ This free advice is worth exactly what you paid for it.
Posted: Sun Dec 17, 2017 8:30 am Post subject: Re: TDi Starter - Is it Hype? |
So to summarize this into the first post so you do not have to read through it.
Even though I did say the 2.1WBX engine there were a lot of response in regards to the conversion engines.
- I obviously see the benefit for the larger or higher compression engines. That was not in question.
The bottom line answer for me is the availability plus the quality builds of these right compared to the "OEM rebuild" now if you are using the 2.1WBX.
kamzcab86 wrote: |
^That's what needs to be quantified: How old were these OEM starters at time of replacement? It's only natural that a new component works better than an old, worn out component.
What the TDI starter does have going for it over the OEM is that it allegedly lasts longer. Lots of folks have had rebuilt OEMs fail within a year or two, hence trying something different.
That is a key point - from what is being said there is a lot of "rebuilt" OEM starters failing. What is there to rebuild on these or more accurately exactly does anyone know which parts on the rebuilds are failing?
Okay in this regard if you wanted to rebuild your old starter here is a link to parts for rebuilding your OEM:
https://www.ebay.com/b/Starter-Parts-for-Volkswagen-Vanagon/177700/bn_1502980
dhaavers wrote: |
Sorry to be "that" guy, but your poll seems rather unscientific...
I think what you're looking for is more along the lines of a survey' i.e.: "choose
all that apply" rather than a poll, i.e.: "choose the ONE which applies"...
- Dave |
Yeah maybe..I wrote it up before trying to prove Einsteins theory,(before morning coffee x 2 cups)
AndyBees wrote: |
Lastly, the OE TDI starter is still functional in my 2000 Jetta with almost 370k miles on it. So, I do believe they are very robust. |
Sounds like a great reason!
dart330 wrote: |
A quick check for a Vanagon starter at AutoZone and O'Reily shows special order only. A 2003 Jetta TDI starter is on the shelf and ready to go, a real life saver on road trips. |
Very good point. For this reason alone makes me glad I did change to it.
crazyvwvanman wrote: |
This is one of the major benefits to me as well. There are also other even more common VW gear reduction starters that also work with the "TDI" adapter Karl came up with. I use a version for ABA 2.0 gas engine cars as well as the early years of TDI cars. Not rated as powerful as the later TDI starter but still rated more than the old tech boxer engine starters.
Mark |
Gruppe B wrote: |
Don't forget that the TDI starter does not use or need a shaft bushing. I had a bushing spin out on one of my vehicles years ago and the starter gear ended up not being supported. It destroyed the starter and the ring gear.
TDI all the way... |
I agree with you, but your link to the Amazon source did not work.
------------ _________________ This free advice is worth exactly what you paid for it.
Posted: Sun Dec 17, 2017 8:32 am Post subject: Re: TDi Starter - Is it Hype? |
westyventures wrote: |
Along with your mod for the heater fan lubrication this has to be counted as one of the "great" mods we have had the benefits of. _________________ This free advice is worth exactly what you paid for it.
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Sun Dec 17, 2017 9:17 am Post subject: Re: TDi Starter - Is it Hype? |
For stock Vanagon boxer starters they got stronger over time.
From .7_kw up to 1.0_kw afaik (maybe 1.2kw ?)
The early TDI/ABA starters I'm using are 1.6kw
The later TDI starters Karl specs are 2.0kw
Mark |
Posted: Sun Dec 17, 2017 10:02 am Post subject: Re: TDi Starter - Is it Hype? |
That's makes it very attractive to not rebuild the old one! _________________ This free advice is worth exactly what you paid for it.
oceanair Samba Member
Joined: June 09, 2013 Posts: 720 Location: Victoria, BC
Posted: Sun Dec 17, 2017 10:57 am Post subject: Re: TDi Starter - Is it Hype? |
I'm in the process of having my OEM starter rebuilt locally, from a shop that has an excellent reputation rather than of the shelf rebuild from who knows where, done with who knows what.
For $100, i think it's going to have excellent longevity and if need be a warranty with a local business that does them in house to 'talk' to.
These auto electric rebuilders are everywhere and supports local business. _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
Gruppe B Samba Member
Posted: Sun Dec 17, 2017 12:02 pm Post subject: Re: TDi Starter - Is it Hype? |
https://www.amazon.com/Valeo-438076-Starter/dp/B00...leo+438076
This was the one that Insyncro stated he used.
I've just ordered this for my new 1991 Westy Project and already have the adapter from Westyventures. I'll install it once it arrives to ensure it fits.
Westyventures posted a warning on the automatic starter thread that some people have had issues using the Valeo.
Westyventures
Quote: |
Be careful with the 'Valeo' starters as some have had experiences where they don't fit. My money is on the Latrical / California Starter brand, and that's what is installed on my personal automatic Westy. |
Posted: Sun Dec 17, 2017 1:13 pm Post subject: Re: TDi Starter - Is it Hype? |
Be careful - this starter uses [shows] an 11-tooth gear, the TDI starters normally have 10-tooth, so not sure this will work correctly. Please do update when you find out though. My money is still on the Latrical / California Starter units. |
Posted: Sun Dec 17, 2017 4:01 pm Post subject: Re: TDi Starter - Is it Hype? |
They may have offset the nose to compensate for the extra tooth, hard to say until it's fitted.
Yes, that's the Lactrical version I have. |
Posted: Sun Dec 17, 2017 7:52 pm Post subject: Re: TDi Starter - Is it Hype? |
TDI starter ........ junk yard pic as I recall.
Although it looks really bad, once I cleaned it up and added some lube, it worked fine. It's been in operation for over two years and about 30k miles.
And, below it is mounted on my tranny with the adapter...
MrTibbs Samba Member
Joined: January 16, 2014 Posts: 68 Location: Austin TX
Posted: Mon Dec 18, 2017 1:50 pm Post subject: Re: TDi Starter - Is it Hype? |
I just did the upgrade to the TDI adaptor and starter.
My conversion came w/ a 'hi-torque' IMI starter that worked well for the past 4 years, but recently needed some occasional hammer treatment to crank over the past month.
The new TDI starter definitely spins everything up quicker than the IMI. |
coastdog Samba Member
Posted: Mon Dec 18, 2017 1:55 pm Post subject: Re: TDi Starter - Is it Hype? |
Works great and was necessary on the GW 2.7 |
SteveMc Samba Member
Joined: December 19, 2013 Posts: 210 Location: Alberta, Canada
Posted: Mon Dec 18, 2017 7:09 pm Post subject: Re: TDi Starter - Is it Hype? |
Steve M. wrote: |
syncrodoka wrote: |
Do you have a part number or link as a source? |
I’m not sure if this a 1.8T starter or not but xoo00oox recommends SR0425X in a Syncro for the same reason, it is shorter.
“I recommend using the SR0425x starter, this identical to the SR0408X except about an inch shorter, it was used on the 5 speed gas powered MK4 jetta/Golf/Beetle. It it still very powerful like the TDi starter, so powerful that I have even used them in TDi cars in a pinch and it cranks over just fine.
With the SR0425X, you can R+R the starter in a syncro in minutes with out removing any other parts even if it has a locker.”
Here’s the link. About have way down the page. Has a photo too.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7999542&highlight=sr0425x#7999542 _________________ 1986 Transporter Single Cab Syncro |
Posted: Mon Dec 18, 2017 8:33 pm Post subject: Re: TDi Starter - Is it Hype? |
SteveMc wrote: |
Steve M. wrote: |
syncrodoka wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?p=7999542&highlight=sr0425x#7999542 |
I'm liking it and I haven't got one yet! 😆
Thanks for the info. _________________ This free advice is worth exactly what you paid for it.
jberger Samba Member
Posted: Mon Dec 18, 2017 11:06 pm Post subject: Re: TDi Starter - Is it Hype? |
I have not used the TDI starter conversion as yet. I have however used several higher KW (401x?) units on stockers, 2.2 subi's and my 2.4 wax with 220psi static compression results. Mounting this unit combined with diff lock is a bit of a chore but I have not experienced a need for anything else.
J |
