kirschwagen Samba Member
Joined: April 11, 2005 Posts: 113 Location: bristol, rhode island
Posted: Sat Dec 16, 2017 1:28 pm Post subject: hanging fuel pump |
how does something like this just find it's way to be dangling down?
isn't the EFI fuel pump on a T3 typically bracketed and bolted to the front beam?
what bolts would I be looking for? I might just have to try to zip tie it to the beam until i can get it up on a lift to be reworked or replaced.
Bobnotch Samba Member
Posted: Sat Dec 16, 2017 3:08 pm Post subject: Re: hanging fuel pump |
kirschwagen wrote: |
Looking at the pic, the rubber mounts broke (right mount in the pic is the big give away), allowing it to fall off the beam.
KTPhil knows where you can get new rubber mounts, and McMaster Carr sells them too (but with SAE threads (not metric).
For now though, you could just zip tie it in place until you've got the replacement mounts.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Dec 16, 2017 5:23 pm Post subject: Re: hanging fuel pump |
thanks, bob. it makes more sense now. i also looked at some classifieds of fuel pumps and used brackets. found that agreed, mine sheered off or snapped at the threaded mounting studs on the end of the bushings. i may try to buy a used bracket complete with rubber mounts and studs and try to get under with just a tire jack and the front passenger tire removed if i can. floor jack in the driveway not an option right now. |
Posted: Sat Dec 16, 2017 5:25 pm Post subject: Re: hanging fuel pump |
or those 24" zip ties might come in handy temporarily again |
Posted: Sun Dec 17, 2017 12:25 pm Post subject: Re: hanging fuel pump |
Here's a link to them that KTPhil found. Sorry for the length of the link.
https://www.grainger.com/product/2NNZ6?gclid=CIvZn...NZ6&AL
Someone else found them at NAPA. Part # 191201256 $2.49 each
I hope this helps.
P.S. The 24 inch zip ties will work as a temp solution until you can replace the rubber bits. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
raygreenwood Samba Member
Posted: Sun Dec 17, 2017 1:15 pm Post subject: Re: hanging fuel pump |
Bobnotch wrote: |
I hope this helps.
P.S. The 24 inch zip ties will work as a temp solution until you can replace the rubber bits. |
Yes...you can get them in metric from McMaster Carr...pages 1440 and 1441.
6mm thread @ 0.5" long on each end...5/8" diameter X 5/8" high rubber...available in neoprene part # 9225K52 @ $1.80 each and natural black rubber part # 9217K57 @ $1.76 each.
Ray |
Posted: Mon Dec 25, 2017 9:35 am Post subject: Re: hanging fuel pump |
Thanks Ray. These dimensions and specs are very helpful.
Thanks to all for the input as well. Happy holidays! |
reay Samba Member
Posted: Tue Dec 26, 2017 10:44 am Post subject: Re: hanging fuel pump |
I have to admit I use PVC tape to hold mine in place. _________________ Tom Reay
Da weiss man, was man hat!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
