Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sun Dec 17, 2017 9:30 am Post subject: Which LED bulb for 67 Beetle dome light? |
I did a search a while back to find and actual brand/part number for an LED replacement bulb, but it seems like the only replies I found were "replace it with a LED" with no other info. I think the proper terminology for the bulb is called a festoon. Does anyone have any brand/part number/source for a LED replacement bulb that would work in the overhead drivers side dome light on a 67 Beetle? Is it a bulb they've actually used, and were happy with, or simply listing a source? I'm having difficulty actually tracking down the OEM bulb number to use as a crossover reference. Anyone know the factory bulb number? |
Gary Haberman Samba Member
Joined: October 18, 2013 Posts: 70 Location: Farmingdale, NY
Posted: Sun Dec 17, 2017 10:07 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
I have two 6v cars and replaced all of my lamps (with the exception of the radio #47 bulb and my turnsignal indicator) with LEDs. I chose the festoon lamps from the site below:
http://www.dynamoregulatorconversions.com/festoon-bulbs.php
They have bulbs in both 6 and 12 voltages. The length of the bulbs in my '62 and '66 are of the 36mm variety. I believe your '67 is also that length.
Another choice would be https://www.ledlight.com/searchresult.aspx?KeyWords=festoon.
They also sell LED replacements for taillights, turn signals, license plate and running lights. _________________ '62 T1 rag top.
I repair radios and dispense free advice on their repair. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Sun Dec 17, 2017 10:22 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
I have an LED Festoon dome light in my 67. It's nice and bright.
The one problem that I was having, was that the light is the directional one instead of the 360° model. It would rotate in the holder from driving over bumpy surfaces.
To cure the problem. I put a dab of silicone on the holder where the end of the light protruded through the holder. The thing has not moved since.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sun Dec 17, 2017 10:24 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Gary, thanks for the info! Doing some more research from your info, it looks like the modern common replacement incandescent bulb for 12v is a "6418". Looks like there are many LED versions of a 6418 bulb. Anyone have any recommendations?
67rustavenger, do you remember the manufacture/part number? |
Posted: Sun Dec 17, 2017 10:53 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
I pulled the bulb out of the car and cannot determine the brand or P/N.
It is a 12V 0.6 watt light. 1.5" long.
This should work for ya.
https://www.ledlight.com/festoon-hi-power-two-1-2-watt-led-light-1-1-2-inches-or-36-mm.aspx
Buy Once, Cry Once!
mascrappo Samba Member
Joined: January 11, 2012 Posts: 535 Location: New Mexico
Posted: Thu Dec 21, 2017 6:08 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
[email protected] wrote: |
I just went through this last week! Your 67 should be 12V. The 6418 is too short (36mm will not stay put and will rotate in the fixture by itself) and I cannot return it since the package is opened...
If you have a Walmart or Autozone, get a Sylvania "cool white" 6411 LED. Mine was $6.88 + tax, it works well, fits nicely at 41mm.
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Thu Dec 21, 2017 7:36 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
According to Cip1, the regular 12 volt, 10 watt dome light is 42mm long and the 5 watt, 12v bulb is 37 mm long.
I found a source for 12 volt 'filament style" led bulbs, in lengths from 31mm, 36mm, 39mm and 41mm. (https://www.tmart.com/COB-Filament-LED-Festoon-Dome-License-Glass-Light-Car-Reading-Light-41mm-Warm-White-Light_p359100.html)
....unfortunately they don't list a 6 volt version. _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3841 Location: San Jose, CA
Posted: Thu Dec 21, 2017 11:14 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
I'd be curious to know the color temperature of the LEDs...wonder why they don't state as much. Personally, I like the traditional warm white. Cool white might be okay, but that stuff getting into the 6000K range is just too blue. |
Posted: Thu Dec 21, 2017 11:24 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Both web links provided talk about the color of the light their bulbs provide. (yes...I read stuff ....) _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Fri Dec 22, 2017 2:28 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
I think these (or previous similar versions, superseded part - as LED lighting is an ever-evolving technology) are the bulbs I have in my Golf and my two Beetle dome lights, plus the extra Type 2 dome lights I re-purposed as under-glovebox "map lights" in the bugs.
https://www.superbrightleds.com/moreinfo/festoon/6451-led-bulb-6-smd-led-festoon-42mm-car/2038/
glutamodo wrote: |
I've had a type 2 dome light under the glovebox in both of my bugs for like 15 years or so. In both cases I put them as close to the glovebox as I could get them. I also changed them out to LED bulbs as soon as such bulbs came down in price and got to a decent amount of lumens output.
Previously in my Baja, I had had some cheap accessory light fixture I had bought at a truck stop, which was a piece of junk and falling apart. I did buy this old SWF accessory interior light fixture off of eBay:
...but I found the cover/lens fit a bit too loose for my tastes. About that time I got a box of misc old parts that included some Bus dome lights and I decided I liked the look and function of them better.
_________________ Andy T.
Posted: Fri Dec 22, 2017 6:27 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Busstom wrote: |
I like warm white too, but LED by it's own nature wants to be blue, so I settled for cool white, which isn't too blue/bad. |
Posted: Fri Dec 22, 2017 6:30 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Digger89L wrote: |
....unfortunately they don't list a 6 volt version. |
Thanks for the link, they sure "look" original, and warm white too. I hope someone buys one and reports how well it works. |
Posted: Fri Dec 22, 2017 6:44 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Busstom wrote: |
I too would prefer more of a warm light to mimic the factory incandescent bulb, I just want more of it. Everything LED seems to be the white, or blueish white. Sure, that color does provide a "cleaner" light that allows you to see "better", so I guess we're limited on options. The car has a black interior, and the compounding of 50 year old wiring connections/contacts probably isn't helping any, but I can't see anything after dark with the current set up. Digger89L's link looks like an option for a little more warm tone for the light.
https://www.tmart.com/COB-Filament-LED-Festoon-Dom...59100.html
The car's put away for the Winter, but I'm going to get some different options, and see what I can come up with. Thanks for everyone's replies. Feel free to add to the thread with any more options anyone else has gotten to work well. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Fri Dec 22, 2017 9:59 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
My preference is for warm white for the vintage look on my VW, but daylight or cool white for a more modern car upgrade.
The directional mature of many festoon lamps is a plus for the dome light. You don't need to illuminate the inner roof! |
Posted: Fri Dec 22, 2017 4:27 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Digger89L wrote: |
Both web links provided talk about the color of the light their bulbs provide. (yes...I read stuff ....) |
Yep, thanks. I think one of the earlier links just says "available in bright white," or something like that. |
Posted: Mon Aug 05, 2019 7:01 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Just to post an update, I finally got around to getting an LED bulb for my 67 dome light. Most list a replacement incandescent festoon of 42mm long, but for what ever reason, mine was 44. I simply did some searching for a 44mm bulb, and came up with a Matrix X-Series LED Minibulb #X-148 from Summit Racing.
https://www.summitracing.com/parts/grm-x-148
The bulb came with a circuit board of 4 rows of 6 leds to make 24 total. It is basically a flat board, so I simply rotated the leds to face outward in the light housing. Here’s a pick of the face of the bulb, it turned for installation, and light output during daylight around 5pm.
Posted: Tue Aug 06, 2019 5:44 pm Post subject: Re: Which LED bulb for 67 Beetle dome light? |
That's super nice.
If you find the light getting a bit dim. It may have rotated in the prongs due to the weight of the LED light being offset.
I used a dab of RTV bridging the prong to the bulb. Never had a rotation issue since doing that.
Buy Once, Cry Once!
Posted: Fri Aug 09, 2019 7:21 am Post subject: Re: Which LED bulb for 67 Beetle dome light? |
Just one comment, personally I've found that huge arrays like this are more prone to failure than others. Not to say that the 6-LED array I talked about above is any better. But after having some failures in various types of big stacked LEDs, I gravitate to having less of them. _________________ Andy T.
