DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Wed Dec 20, 2017 6:50 am Post subject: typical Vanagon theft method? |
seems quite a few Vanagons are stolen... while we can hide fuel pump switches, etc. is there a predominant method of theft? towing? column switch hacking? key left on top of front tire?
i realize publically discussing theft methods can educate the vermin out there but on the other hand, it seems to be pretty common knowledge in that subgroup with all the vans being nabbed. better to discuss hardening systems than being ignorant.
-dan |
Posted: Wed Dec 20, 2017 7:28 am Post subject: Re: typical Vanagon theft method? |
Many Vanagon keys will work in a bunch of other Vanagons due wear and such. Also, it's incredibly easy to hotwire a Vanagon with nothing more than a paperclip. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
DometicLover Samba Member
Posted: Wed Dec 20, 2017 10:00 am Post subject: Re: typical Vanagon theft method? |
If un-engaged, the steering lock is defeated with any vanagon key installed in the lock, no need to turn the key at "on".
To start, all you need is an extra ignition switch. You remove the steering column cover, you unplugged the connector at the ignition switch, plug it in your extra ignition switch and switch it on. Voila, engine is running!
Once inside the van, you can start ANY Vanagon is less than 10sec, if there's no hidden cutoff switch.
Last edited by DometicLover on Wed Dec 20, 2017 11:27 am; edited 1 time in total |
?Waldo? Samba Member
Posted: Wed Dec 20, 2017 10:03 am Post subject: Re: typical Vanagon theft method? |
The steering lock is not released until the key is turned. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6561 Location: Westfalia, Earth
Posted: Wed Dec 20, 2017 10:38 am Post subject: Re: typical Vanagon theft method? |
Thinking this thread is a really bad idea... _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Waldemar Sikorski Samba Member
Posted: Wed Dec 20, 2017 10:59 am Post subject: Re: typical Vanagon theft method? |
E1 wrote: |
Thinking this thread is a really bad idea... |
i know, my hesitation too. but i think very few people who are wanting to steal a van are held back by lack of knowledge. better we all know how darn easy it is and take precautions.
but if the Mods feel this is a bad idea, i no issue with the thread being deleted so it doesn't live on forever in the GoogleVerse. it still sorta will but whatever, it eventually becomes harder to find.
-dan |
vegpedlr Samba Member
Posted: Wed Dec 20, 2017 11:15 am Post subject: Re: typical Vanagon theft method? |
A dedicated thief will find a way.
That said, looking for the weakest points and trying to find ways to shore them up without providing a theft tutorial could be helpful. It seems the weakest points are the steering lock and ignition switch. So could discussion of steering wheel locks and kill switches be beneficial? _________________ 1985 Tintop 4 sp GW 2.3 “Connie”
2006 Mk V GTI 2.0 FSI “Penelope” |
Posted: Wed Dec 20, 2017 11:23 am Post subject: Re: typical Vanagon theft method? |
my Volvo 1800S had an armored cable from the ignition switch to the coil, with the nose of the coil bolted into the firewall! difficult to access to provide the 12v needed for spark.
-dan |
Posted: Wed Dec 20, 2017 11:30 am Post subject: Re: typical Vanagon theft method? |
?Waldo? wrote: |
You are right. If engaged you need to turn the key. If not engaged, it won't lock if a "dummy" key is inserted. It's like this on my van anyway.
I hesitated in putting such info, but people needs to know that starting their vanagon is a 10 second joke. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Wed Dec 20, 2017 11:31 am Post subject: Re: typical Vanagon theft method? |
It's really not a big problem when compared to all vehicle thefts.
If you google "vehicle theft statistics" you can get the numbers for your area. In Portland, where is seems there is a vanagon on every block, 3 were reported stolen in 2017. There were a total of 7800 cars stolen in 2017. 78 were volkswagon models and 3 were vanagon. That's not much in the big picture. VW wasn't even in the top 10 models stolen. That was Honda, Toyota and Subaru. Vanagon was 0.0004% _________________ 89 Westy 2.1 Auto |
Posted: Wed Dec 20, 2017 11:34 am Post subject: Re: typical Vanagon theft method? |
Good point. There are probably plenty of people who wouldn't even take one for free! _________________ 1985 Tintop 4 sp GW 2.3 “Connie”
calfredson Samba Member
Joined: January 21, 2015 Posts: 70 Location: Vancouver, BC
Posted: Wed Dec 20, 2017 11:50 am Post subject: Re: typical Vanagon theft method? |
Having a manual transmission will thwart 80% of thieves these days. |
Posted: Wed Dec 20, 2017 12:01 pm Post subject: Re: typical Vanagon theft method? |
DometicLover wrote: |
?Waldo? wrote: |
If that is the case on your van, then your steering lock is not functioning properly. I just checked and confirmed that with a different vanagon key installed in the ignition lock, the steering wheel lock most definitely engages just fine. You might want to get yours fixed. Hopefully no one reading this thread knows where your park your van in the meantime... |
Paulbeard Samba Member
Posted: Wed Dec 20, 2017 12:04 pm Post subject: Re: typical Vanagon theft method? |
PDXWesty wrote: |
If you google "vehicle theft statistics" you can get the numbers for your area. In Portland, where is seems there is a vanagon on every block, 3 were reported stolen in 2017. There were a total of 7800 cars stolen in 2017. 78 were volkswagon models and 3 were vanagon. That's not much in the big picture. VW wasn't even in the top 10 models stolen. That was Honda, Toyota and Subaru. Vanagon was 0.0004% |
But if it's yours, it could be 100% of the stolen cars you care about. I know how risk analysis works (safer to fly than drive, etc) but with that goes lowering risk. If those three stolen Vanagons had kill switches or some other kind of theft deterrent, maybe that number would be 0. And maybe there were three others that someone attempted to steal but couldn't. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Merian Samba Member
Posted: Wed Dec 20, 2017 12:20 pm Post subject: Re: typical Vanagon theft method? |
I wonder how many Vanagon thieves have been burned alive when the fuel hoses let loose? _________________ .... |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Dec 20, 2017 12:38 pm Post subject: Re: typical Vanagon theft method? |
Merian wrote: |
many Vanagon thieves have been burned alive |
Now an actual product, thanks Merian!!!
JK
Anyway, I've fancied creating a product, loosely based on the awesome pedal lock plans seen here on other threads. My dream locker would cowl the steering column, lock the brake pedal down and the clutch (if applicable) up, and also have a integrated steering wheel clamp that would clamp down over the center to prevent horn/nut removal and turning. I am sure we could croudsource a product, but I am also sure that it would never make a profit. This would also be large and heavy... neither of which are easy to manage.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Wed Dec 20, 2017 1:05 pm Post subject: Re: typical Vanagon theft method? |
Locks exist only to keep honest people honest.
The hidden cut off switch on my Vanagon kills both fuel and spark, so it will have to be a very skilled diagnostic mechanic to drive my Vanagon off, or they will have to bring a tow truck to cart it away.
Even if they tow it away, the hidden GPS tracker will alert me the second it moves from its parking spot, and I can follow the breadcrumbs it leaves every 2 minutes to zero in on it.
