SBL74 Samba Member
Joined: November 25, 2013 Posts: 125 Location: Treasure Island, FL
Posted: Thu Dec 21, 2017 6:05 pm Post subject: new 1973 bay window camper owner with mystery engine |
Yesterday I purchased a 1973 bus camper and I am confused about several things. Lets start with the engine. At first glance I thought it was a classic bus engine from that era. Underneath, I saw an oil filter that said Vanogan on it. That filter is on the drivers side, and is sideways (not vertical). And a diagnosic plug is present in the engine compartment. I see AK184317 stamped on the engine as I look at it straight on. And I am not sure what that is on the side of the distributer. I have attached a few pictures. Can someone tell me what engine I have?
Thanks,
steve |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2536 Location: Plattsburgh, New York
Posted: Thu Dec 21, 2017 6:09 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
It's a Type 1 engine. Someone will chime in with more specific information. It was used in North America through 71 and in Europe much longer. The engine tin looks homemade. People sometimes put this engine in a bus they are selling because they tend to be cheaper and easier to find parts for. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Dec 21, 2017 6:16 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
Congratulations and welcome to the bay side of life!
Somebody has adapted a type 1 (Beetle) engine in there, not a bad thing if it was done properly, but I do see a few less than optimal parts installed so you'll want to go over it and check thier work, here's how to do it properly: https://www.thesamba.com/vw/forum/viewtopic.php?t=483408
From here the bus doesn't look all that bad, odd paint color, but seemingly correct tires (how old?), genuine (or good repro) curtains but an odd color interior laminate, fresh looking canvas too. Obviously it's had some work done and much of it may be good, at least they sealed up around the engine instead of hanging it out in the open like the hardcore lipstick on a pig/polished turd flippers do.
Cool bar on the front as well! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Dec 21, 2017 6:25 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
How about some pictures of the oil filter. You can get oil pumps that incorporate a filter into their design and the filters sticks off horizontally to the driver's side. |
SBL74 Samba Member
Posted: Thu Dec 21, 2017 7:14 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
Yes I thought that engine looked familiar.
Here is a picture taken tonight. It is the best I can do. It shows the oil filter and where it attaches. The place where the oil screen goes seems larger in diameter than that of my Thing. Not sure what that means.
I am also concerned that I cannot see any heat exchanging parts, like the hoses. And there is no place to put them either on the shroud or down below.
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Dec 22, 2017 7:21 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
You have a late bay. These typically came with a type 4 "Porsche style" engine. Your bus, as others have pointed out, has a type 1. The fan shroud, as you pointed out is aftermarket and does not have heater tube ports. Though it does appear to have an oil cooler (which is good). The filter is just a filter that fit the aftermarket oil filter mount that the PO installed (fairly common). Some people think these are unnecessary, I personally believe that oil filters are highly underrated in this community.
The bosch blue coil is good, the 009 distributor is typically looked down on, But if it runs well, rock it. You also have an alternator (not a generator), and aftermarket oil filler. When it comes down to it, your bus engine is highly modified from original but nothing that is unfamiliar to these forums. I suggest reading until you understand what you have before changing anything/swapping anything on your engine. Do you have any specification for the internals of your engine?
Additional photos of the bus would help us help you a lot. Im interested in the engine mount and engine hanger assembly. As well as making sure your transmission mount is being utilized (it should be, id be surprised if it isn't), but interior, brake lines, front suspension, interior. (or just keep it to the engine if you are not looking for extra opinions on the rest of the bus.)
For what your bus likely started as:
Tcash wrote: |
Welcome to TheSamba, Bay Window Bus Forum!
73-79 NEWBIE
Tcash wrote: |
Every Type IV engine owner should know this!!!
If you over tighten the Oil Strainer bolt, you will brake the engine case!
There is a Oil strainer in there.
TORQUE THE STRAINER BOLT TO NO MORE THAN 9 FT. LBS. |
_________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Dec 22, 2017 7:37 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
It looks like you have dual solex carbs. I could be wrong. They don't play well with the 009 distributor. They will run with it, but the advance curve is wrong for them. Jeff at Kaddie Shack is the best guy to talk to regarding a good setup on those carbs. They have a variety of air cleaners that will fit those. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Fri Dec 22, 2017 7:52 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
TomWesty wrote: |
It looks like you have dual solex carbs. I could be wrong. They don't play well with the 009 distributor. They will run with it, but the advance curve is wrong for them. Jeff at Kaddie Shack is the best guy to talk to regarding a good setup on those carbs. They have a variety of air cleaners that will fit those. |
Wouldn't it be easier and cheaper to get a different distributor? ... OP: learn your engine, then after much research change things in a logical manner. This will by far save you more money and headache than anything else. Once you know what you have, go see the Performance Engine/transmission forum and ask their opinions. There are some experts over there that will be able to help a lot. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
SGKent Samba Member
Posted: Fri Dec 22, 2017 8:31 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
considering the shroud looks aftermarket, no telling what is in there really. The case is an AK which began life as a 1973 upright 1600 in a bug. Regardless you will enjoy the camping, and parts shouldn't be too hard to find if you need to do work on it. Wonder what the transmission looks like? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
SBL74 Samba Member
Posted: Fri Dec 22, 2017 8:39 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
Thanks everyone. All of the comments have been very helpful. I am, in fact listening and feeling the engine, making no changes for now. I runs very well, and shifts well. I have cleaned up the wiring etc in the dash (had no blinkers) and cleaned up the interior (not really much to do, frankly) and I drive it so I can see how it behaves.
I will see if I can get some more pictures in the light of day on some jack stands.
On person posted that it did have an air cooler. Where would that be?
steve |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Sat Dec 23, 2017 6:57 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
The oil cooler is located inside the fan shroud. Read up on oil coolers and "doghouse" shrouds.
As noted it would be good to find out what transmission you have and see if it plays well with that type 1 engine. _________________ '71 Westy |
Posted: Sat Dec 23, 2017 5:01 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
ccpalmer wrote: |
As noted it would be good to find out what transmission you have and see if it plays well with that type 1 engine. |
All VW aircooled engines came stock with an oil cooler, so I guess I don't understand the one poster's statement. Also don't know of a way to determine if there is an offset oil cooler installed on this particular engine just from the pics. I must be missing something here. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
sethpat Samba Member
Posted: Sun Dec 24, 2017 10:24 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
Saw this bus on CL a few months ago. Welcome, and have fun! _________________ Unnamed 1986 Syncro
Frankenbus (sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=674133&highlight=
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift |
yellowCOwesty Samba Member
Joined: April 16, 2016 Posts: 97 Location: Rocky Mountains
Posted: Mon Dec 25, 2017 8:57 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
Never mind, I’m obviously tired.....
Carry on.
Edited _________________ _______________________
'78 Westy
Currently yellow and white "Sunny"
A few other air cooled VW and Porsches over the years |
SBL74 Samba Member
Posted: Fri Mar 09, 2018 7:51 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
I was asked to show what transmission was used for this engine. Here are some pictures. It is clearly a rebuilt transmission. Clean as can be on the exterior with a superior paint job. I see 2 numbers, which are shown. The next 4 pics are of the transmission in sections.
And the transmission:
Can someone comment and identify?
steve |
SBL74 Samba Member
Posted: Sun Mar 11, 2018 6:58 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
repost |
Posted: Sun Mar 11, 2018 7:36 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
You have a three rib, 002 transmission, which assuming it has the original gearing means that it is well matched to your engine |
SBL74 Samba Member
Posted: Mon Mar 19, 2018 6:13 pm Post subject: Re: new 1973 bay window camper owner with mystery engine |
Thank you. Doing well so far! |
Posted: Tue Mar 20, 2018 7:48 am Post subject: Re: new 1973 bay window camper owner with mystery engine |
SBL74 wrote: |
Good to hear. Don't hesitate to ask any questions you have. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
