John cilia Samba Member
Joined: May 03, 2016 Posts: 140 Location: Toronto, Canada
Posted: Thu Dec 21, 2017 8:24 pm Post subject: Not so standard, Standard. |
I am restoring a September 1949 Standard bug. It does however have all holes in body, hood and fender horn grills. I know standards were available with Delux body trim when ordered from factory.
My question is that there is no horn mount on body behind fender but there are the two front fender grills. Would VW mount the horn on bumper bracket ahead of horn grill ? Or are the horn grills just part of the Delux look on a Standard sedan ?
Any ideas ? |
sled Samba Member
Posted: Thu Dec 21, 2017 8:53 pm Post subject: Re: Not so standard, Standard. |
it would be helpful if you could provide us all with some good photos of the car. I understand wanting to keep something under wraps, but pictures can go a long way in helping answer questions.
as far as the fenders go, are you 100% positive they are original to the car? is it possible they are from another split beetle? Unless the car is totally original paint and unmolested, it is sometimes difficult to authenticate original parts. _________________ drive your split. |
OvalinAz Samba Mini Tech
Posted: Thu Dec 21, 2017 9:05 pm Post subject: Re: Not so standard, Standard. |
That is my biggest concern that front fenders are not original standard ones but from a Delux.
I was trying too get confirmation if a Delux optioned Standard would also get the horn grills treatment but with the horn on the bumper bracket. |
Posted: Thu Dec 21, 2017 9:07 pm Post subject: Re: Not so standard, Standard. |
Car is 100% a standard sedan and came in pearl gray paint.
All standard interior but optioned in Delux trim. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69802 Location: Phoenix Metro
Posted: Fri Dec 22, 2017 3:10 am Post subject: Re: Not so standard, Standard. |
Here are some pics of my 49 Standard. |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 984 Location: Bath, England
Posted: Fri Dec 22, 2017 3:28 am Post subject: Re: Not so standard, Standard. |
It seems that you have one of the 'Canadian Standards', a hybrid specific to Canada, which is a half way stage between being a Standard & a Deluxe. There is a fair bit written about the subject elsewhere on this site. |
Posted: Fri Dec 22, 2017 3:55 am Post subject: Re: Not so standard, Standard. |
According to my BC the car left factory to Manheim Germany. Dealer was Islinger. |
Posted: Fri Dec 22, 2017 6:33 am Post subject: Re: Not so standard, Standard. |
More unusual info on my car.
Front fenders appear to be original. They have the small horn grill slots for grill mounting but the driver side fender does not have the large hole for horn sound too pass through. Body does not have horn bracket either.
So it appears that horn was mounted on bumper bracket in front of the horn grill. |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
Posted: Fri Dec 22, 2017 7:31 am Post subject: Re: Not so standard, Standard. |
Martin Southwell wrote: |
VWs were not imported into Canada until 1952 - so that would not be the case for a 1949. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
Posted: Fri Dec 22, 2017 8:10 am Post subject: Re: Not so standard, Standard. |
OK. So not a Canadian Standard! - I didn't know when they started, but purely a suggestion. VW's imported into Canada in 1952? That's a year before they started officially importing VWs into the UK in 1953.
I know someone who was in Canada in the very early 50's, and told me once about driving VWs there, and even test driving a new Tatra in the same period. Having not seen him for 5 years now, I ought to try and call him, to see if he is alive, and ask if he can recall dates of these things. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Dec 22, 2017 8:27 am Post subject: Re: Not so standard, Standard. |
Why do you think it's a standard and not a true deluxe?
Deluxe versus standard is more about the amendments on the body than the chassis. For example, my 49 deluxe has mechanical brakes and of course lever shocks, but it also has adjustable seats, white pods and horn mounted behind the fender.
My take is that the deluxe is really just the body molding, pod coloring, how the seats were attached to the pan and a few other small modifications. |
Posted: Fri Dec 22, 2017 9:03 am Post subject: Re: Not so standard, Standard. |
This car is entirely a standard inside with a Delux trim outside except for horn on bumper. |
Wiggy Samba Member
Posted: Fri Dec 22, 2017 10:12 am Post subject: Re: Not so standard, Standard. |
It's 100% accurate that VW started importing into Canada in 52. VW Canada celebrated its 60th anniversary in 2012. Easy to google it to see.
Since he has the birth cert. - it was shipped to Germany. So I very much think this is something that was probably a dealer or owner change - especially the fenders. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Fri Dec 22, 2017 10:43 am Post subject: Re: Not so standard, Standard. |
Can you post pics of rear quarter to see the molding holes? I see your doors have 6 clip holes, when original deluxe split door has 5 clips.
Could be a standard which was make up in Germany to look a deluxe. Quite common in those days. _________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
Posted: Fri Dec 22, 2017 11:01 am Post subject: Re: Not so standard, Standard. |
Thanks Mika. That's what Iam getting that info from my research. |
sled Samba Member
Posted: Fri Dec 22, 2017 1:12 pm Post subject: Re: Not so standard, Standard. |
It seems pretty cut and dry from where I am sitting... the car is grey (standard) the fenders have the horn grills added (standard) there is no horn mount on the front 1/4 (standard) the trim holes may not have been drilled at the factory.
I say restore it to standard factory specs. If you like the look of a standard with trim and chrome hubcaps/headlight rings (very common on standards) then go that route.
Aside from all that, it looks like very good sheet metal to start with! _________________ drive your split. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2171 Location: Graz, Austria, Europe
Posted: Fri Dec 22, 2017 2:49 pm Post subject: Re: Not so standard, Standard. |
drivers side fender seems to have no cutout for horn either. do both fenders have the 4 slots for the horn grill tabs ? if those slots were even spaced and look like factory stampings, that would be good indication for a factory installed DLX trim.
FWIW my ex 51 std with factory Dlx trim did have a horn bracket behind fender, but I can't say if it was factory installed or later added. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
62 Dickholmer, custom color Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Fri Dec 22, 2017 2:56 pm Post subject: Re: Not so standard, Standard. |
Yes both front fenders have the small slots for mounting horn grills and both were there. |
