pwcgecko Samba Member
Posted: Thu Dec 21, 2017 9:57 pm Post subject: Yakima roof rack bars, length? |
Hi All,
All you yakima roof rack owners out there, what length are your bars?
Thanks... _________________ 2002 Eurovan Weekender in SoCal |
PtownVdub Samba Member
Joined: February 02, 2009 Posts: 63 Location: Portland, OR
Posted: Fri Dec 22, 2017 11:14 am Post subject: Re: yakima roof rack bars, length? |
I have 58" load bars on my Eurovan. I like that they do not extend past the body.
_________________ 2001 Eurovan MV - 2.8L 24v, 4 speed automatic |
annieq Samba Member
Joined: May 06, 2007 Posts: 41 Location: Savannah, Georgia
Posted: Fri Feb 09, 2018 6:09 pm Post subject: Re: yakima roof rack bars, length? |
I've been wondering about the track on my EVC pop top. I believe they are a T track, but will they accommodate Thule or Yakima fittings??? _________________ curlygirl and the sandeeman |
greenlaker Samba Member
Joined: December 26, 2016 Posts: 74 Location: Sebastopol, CA
Posted: Sat Feb 10, 2018 8:53 pm Post subject: Re: yakima roof rack bars, length? |
I've run 78" bars on all three of my EVs, cut down to 70". This allows me to run my cargo box, a "basket case" (no longer made) and a bike rack all on the roof. Yes, they do extend beyond the body, but they've never been in the way.
(before I hacked 4" off each side)
_________________ '15 Mercedes-Benz Sprinter Crew 144 hi roof
'10 Toyota Prius iii
'01 Honda S2000
'92 Mercedes-Benz 400E |
Posted: Sun Feb 11, 2018 12:44 am Post subject: Re: yakima roof rack bars, length? |
Thanks all for the feedback. I just ordered the GoWesty Yakima bundle, that comes with the 72" bars. i will see how much they stick out on the sides, initially i was leaning towards 66". _________________ 2002 Eurovan Weekender in SoCal |
Posted: Sat Feb 24, 2018 6:54 pm Post subject: Re: yakima roof rack bars, length? |
greenlaker wrote: |
GreenLaker I just noticed you had your brackets upside down, I have mine the other way and I am thinking of reversing them like your's to lower the rack by 1.5 inches or. Have you had any issues with the brackets being upside down? _________________ 2002 Eurovan Weekender in SoCal |
Zeitgeist 13 Samba Member
Posted: Sat Feb 24, 2018 8:44 pm Post subject: Re: Yakima roof rack bars, length? |
Hey, I need to do that as well. Mine stick up way too high. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Sun Feb 25, 2018 10:08 am Post subject: Re: Yakima roof rack bars, length? |
Ha, I was wondering if somebody would notice my flipping of the brackets. I initially installed them upside-down in order to make the entire assembly lower profile. If my measurements are accurate, I should be able to (barely) park the van in the garage with the towers and bars installed, I've just never attempted it. Your results may vary.
No issues incurred during a ≈3000 mile road trip to CO and back over the summer with the box installed. The rack and box have been off the van since our return though. It'd be easy to flip them over to the proper orientation if needed. _________________ '15 Mercedes-Benz Sprinter Crew 144 hi roof
'01 Honda S2000
Posted: Sun Feb 25, 2018 12:58 pm Post subject: Re: Yakima roof rack bars, length? |
i flipped my brackets this morning and it worked out. The angle of the bracket and the side roof makes for a good hold, I have no concerns of the tower slipping off the bracket. Thanks everyone for their feedback and input on the bars and mounting suggestions. I am very pleased how it came out.
First picture is the brackets right side up, notice the higher profile.
Second picture is the bracket upside down, notice the lower profile.
Third Picture is my new mega warrior mounted and my Fiamma F35.
Posted: Sun Feb 25, 2018 4:54 pm Post subject: Re: Yakima roof rack bars, length? |
I love your custom--painted brackets, looks great! _________________ '15 Mercedes-Benz Sprinter Crew 144 hi roof
'01 Honda S2000
swsl Samba Member
Joined: February 20, 2017 Posts: 94 Location: New Mexico
Posted: Tue May 01, 2018 6:27 am Post subject: Re: Yakima roof rack bars, length? |
I also have the longer bars hanging over. Just in case I need to put something a board or kayak alongside my yakima box.
@pwcgecko: what length is your fiamma? 8'/2.5 meters? Trying to decide if a 270 will fit. My van is in another state, so I can't measure. I remember that the 10' would not fit when we measured but I didn't know there was a 270 cm option at the time. That would be 8'8" standard. |
Posted: Wed May 02, 2018 8:45 pm Post subject: Re: Yakima roof rack bars, length? |
swsl wrote: |
I believe mine is the 8'2", I like the size and think it fits perfect. The only time I have an issue with the front door is if it is raining and I slant the awning downward it will slightly hit the front door. In normal use I have plenty of clearance. I think an 8'8" would fit fine and you would get more coverage over the front door. Good luck. _________________ 2002 Eurovan Weekender in SoCal |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Tue May 22, 2018 5:54 pm Post subject: Re: yakima roof rack bars, length? |
annieq wrote: |
I've been wondering about the track on my EVC pop top. I believe they are a T track, but will they accommodate Thule or Yakima fittings??? |
My new (to me) '97 full camper has a pair of tracks (I guess that describes them) on the roof w/Yakama bars going across. They are mounted just inside the hump at the edge where the flat top plane loops up and over to make the sides of the roof. There's some sag to the pop-top itself, and I have a feeling that the rack, which I've seen in pics to have carried a bullet box unit of some kind, likely with too much load, caused the sag. Has anyone else w/a Winnie with a moderate sag in the roof found anything that reduces the amount of sag? |
Michigan03EV Samba Member
Joined: January 11, 2020 Posts: 19 Location: Michigan
Posted: Thu May 21, 2020 2:22 pm Post subject: Re: Yakima roof rack bars, length? |
Talk about reviving this from the dead, does anyone know what number Q Clips Yakima used with our EV's? |
swimrr Samba Member
Posted: Thu May 21, 2020 8:10 pm Post subject: Re: Yakima roof rack bars, length? |
Yakima Q12 Clips. Two years ago I was able to track a few down, but they're hard to find as I don't think they make them anymore. |
Posted: Sun May 24, 2020 5:50 am Post subject: Re: Yakima roof rack bars, length? |
swimrr wrote: |
Lifesaver right there. Found a few on eBay and should arrive before we take this baby across the country! Thank you |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sun May 24, 2020 7:32 am Post subject: Re: Yakima roof rack bars, length? |
I'm interested in a rack for my 2003 tintop.
Anyone know what would work for this? So far, everything I've found seems to be for pop tops, though one of the first responses to the thread shows a rack on a tintop.
Edit: I know this thread mentions Yakima but I already have Thule cross bars, so that would be my preference. _________________ Dave Cook
1973 Wild Westerner
My Thing |
smailjordan Samba Member
Posted: Fri Jun 26, 2020 7:35 pm Post subject: Re: Yakima roof rack bars, length? |
vwwestyman wrote: |
Edit: I know this thread mentions Yakima but I already have Thule cross bars, so that would be my preference. |
Did you ever find a rack for your in top? |
streamr Samba Member
Joined: February 26, 2007 Posts: 555 Location: Southwest FL
Posted: Sun Dec 06, 2020 1:22 pm Post subject: Re: Yakima roof rack bars, length? |
vwwestyman wrote: |
Nope, nothing yet. |
I know you mentioned Thule, but this is the Yakima combo that works well. Their Q-Towers with the Q-12 clips (as mentioned earlier). Towers are pretty easy to find, the clips are a little trickier. I may have an extra set of towers laying around, I'd have to check.
Thule has a #400 bracket that is similar and they seem to be available on ebay but I have no idea which clip is needed. I never cared for Thule's racks, they don't seem to be as robust as Yakima, but that's just me.
Anyway, good luck!
PS, to stay on topic, my bars are 58" long. I, too, prefer them to not be wider than the vehicle.
_________________ '03 MV |
