Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Sun Dec 31, 2017 12:18 pm Post subject: Re: <insert name here> Build Thread |
Also know that "lowered" balljoints have been modified by removing material thus making them weaker. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Sun Dec 31, 2017 2:00 pm Post subject: Re: <insert name here> Build Thread |
Won't be a daily driver... I'll be careful. Thanks for the input. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Fri Jan 05, 2018 8:11 pm Post subject: Re: <insert name here> Build Thread |
Ok, sorted the leaf springs issue on the adjustable beam. Back on all 4s. Just need to adjust the steering stops, then it's time to bleed the brakes. Bought a reservoir that attaches to the master cylinder and does away with the plumbing up to behind the dash.
xzener Samba Member
Posted: Fri Jan 05, 2018 8:18 pm Post subject: Re: <insert name here> Build Thread |
After getting everything back together... I think I will be saving up for a Whiteline OTT sway bar. If I drop it anymore, I will be hitting speed bumps for sure. We'll see. Not to worried about it right now. Lots of time to tinker and decide.
VWRESTOMODMAN Samba Member
Joined: January 17, 2014 Posts: 75 Location: California
Posted: Fri Jan 05, 2018 10:21 pm Post subject: Re: <insert name here> Build Thread |
For what its worth I've been there done that with the front sway bar you just installed, and it will make contact with the road for certain as mine did. I had about the same amount of static ground clearance as yours does in the photo and mine made contact passing over the first mild bump in the road, promptly removed it.
You can try it but unless your set up is going to be very firm you will most likely have the same results I did, sorry but just trying to pass along my experience. Mine is a 2" narrowed beam so my spring rates are just slightly stiffer then what it was when it left the factory. |
Posted: Mon Jan 08, 2018 8:19 pm Post subject: Re: <insert name here> Build Thread |
It leads me to wonder why someone hasn't solved these & several other issues by converting the lower spring pack into a sway bar by making a solid bar & then making a stiffer upper spring pack to suspend the car. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Mon Jan 08, 2018 8:23 pm Post subject: Re: <insert name here> Build Thread |
Well, I guess Whiteline doesn't build a 2" narrowed OTT sway bar... Wonder if I were to purchase their stock length, and have the narrowed bar manufactured locally?? I could then use the mounts to put it all together. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Mon Jan 08, 2018 9:13 pm Post subject: Re: <insert name here> Build Thread |
I bought a tach on eBay from ISPWest, which was nice, but didn't quite look right. I contacted them and they allowed me to trade it in for another...
Original one...
New one, which matches the other gauges better...
xzener Samba Member
Posted: Mon Jan 08, 2018 9:34 pm Post subject: Re: <insert name here> Build Thread |
Also made a one-man-bleeder bottle. Will use this to flush the old fluid out before bleeding all the air.
xzener Samba Member
Posted: Fri Jan 12, 2018 2:53 pm Post subject: Re: <insert name here> Build Thread |
Flushed the brake lines successfully. Got the front brakes bled. Have to adjust the rear shoes still. But so far so good.
Some nasty looking fluid that came out...
c21darrel Samba Member
xzener Samba Member
Posted: Fri Jan 12, 2018 6:36 pm Post subject: Re: <insert name here> Build Thread |
What!? No way is that going back in. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sat Jan 13, 2018 1:51 am Post subject: Re: <insert name here> Build Thread |
It hadn't been flushed in a LONG time... if ever. Just pumping the pedal after filling the new reservoir with fluid caused it to go black. The lines weren't as bad as the master cylinder. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Sat Jan 13, 2018 7:47 am Post subject: Re: <insert name here> Build Thread |
What type of brake fluid ( dot ) are you using ? _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
xzener Samba Member
Posted: Sat Jan 13, 2018 11:04 am Post subject: Re: <insert name here> Build Thread |
DOT 3 High Temperature _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sat Jan 13, 2018 11:06 am Post subject: Re: <insert name here> Build Thread |
Will more than likely convert to rear disks too... After paint and interior. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sat Jan 13, 2018 11:14 am Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Will more than likely convert to rear disks too... After paint and interior. |
Not sure if it adds all that much to the car's stopping power, along with other braking issues , I will not be doing that to mine. _________________ ----------------------
xzener Samba Member
Posted: Sat Jan 13, 2018 12:09 pm Post subject: Re: <insert name here> Build Thread |
Braking issues? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sat Jan 13, 2018 3:53 pm Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Braking issues? |
Locking up brakes in a panic stop, you don't have ALS. There is a lesser chance with drums in the rear. Just brake fade _________________ ----------------------
xzener Samba Member
Posted: Sat Jan 13, 2018 4:32 pm Post subject: Re: <insert name here> Build Thread |
I see... Yeah, that is a concern. I will give that some more thought then. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
