Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1047 Location: Jacksonville, FL
Posted: Sat Jan 13, 2018 6:27 pm Post subject: Re: <insert name here> Build Thread |
Take a stroll over to http://www.shoptalkforums.com/viewtopic.php?f=51&t=127619 and look at the Ghia Road Course setup thread and some of the related brake setup threads from FJCamper and Pyledriver. You will get a lot of good information about getting four wheel disks to work properly. You will need one of the many PhotoBucket hacks to see all the pictures. _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
xzener Samba Member
Posted: Sun Jan 14, 2018 11:30 am Post subject: Re: <insert name here> Build Thread |
Thanks Evil_Fiz, that will come in handy. So, I think the next couple purchases will be to regain what I lost in the rear when I tore the Z-Bar out. I know it's not related, but a truss bar... And then a rear sway bar of some sort. Whether it's a camber compensator or an actual sway bar, that's the question... Does anyone have experience with either one of those?? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sun Jan 14, 2018 6:32 pm Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
...Whether it's a camber compensator or an actual sway bar, that's the question... Does anyone have experience with either one of those?? |
I can't stress the value of the "Ghia Road Course setup" thread enough. I have read through it at least 5 times and I pick up something new every time. This link to the "Race Prep The Swing Axle" section of the thread Will answer most if not all of your questions. _________________
kiwighia68
xzener Samba Member
Posted: Fri Feb 02, 2018 5:28 pm Post subject: Re: <insert name here> Build Thread |
So after removing the steering column/shaft, it seems as though removing the bolts that attaches the column to the dash, and the two bolts from the steering bushing... The whole thing would slide out, steering wheel and all... Is this not the case??
I've sanded down the column and repainted, also replaced the bearing... Would like it to be easily removed when the car is painted. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sat Feb 03, 2018 12:06 pm Post subject: Re: <insert name here> Build Thread |
Anyone have any idea what color this 56 Ghia has?
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
xzener Samba Member
Posted: Sat Feb 03, 2018 12:27 pm Post subject: Re: <insert name here> Build Thread |
Thanks John. Looked through the paint code threads, but didn't see trout blue. What a beautiful color. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Feb 06, 2018 6:34 pm Post subject: Re: <insert name here> Build Thread |
Buying all the parts needed to do the alternator conversion... Do I need a certain backing plate, or will my original pieces work??
Got my purchase finger hovering over the buy now button on this... Is this what I need?? It's an Alt/Gen backing plate.
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Wed Feb 07, 2018 9:14 am Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Also made a one-man-bleeder bottle. Will use this to flush the old fluid out before bleeding all the air.
I flush the hard lines completely with Alcohol, then blow air through them, then use fresh fluid & a Mighty Vac to draw the fluid through on a one-man operation. I don't do the pump-pump-pump the pedal to bleed the lines.
At the very end, I do use an assistant to help push the pedal for final bleed, but I don't bottom-out the pedal.
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Wed Feb 07, 2018 9:56 am Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Reuse your original or find an original one, much better quality. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Wed Feb 07, 2018 10:41 am Post subject: Re: <insert name here> Build Thread |
Its definitely Trout Blue L330
xzener Samba Member
Posted: Wed Feb 07, 2018 7:34 pm Post subject: Re: <insert name here> Build Thread |
didget69 wrote: |
xzener wrote: |
Also made a one-man-bleeder bottle. Will use this to flush the old fluid out before bleeding all the air. |
bryan |
Yeah, I ended up using a vac pump too, but simply kept flushing until the fluid was clean. Would have been a good idea to blow them out with compressed air as you did... Maybe next time... I'll put some mileage on it first. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Feb 07, 2018 7:36 pm Post subject: Re: <insert name here> Build Thread |
Inchpincher61 wrote: |
Its definitely Trout Blue L330 |
Thanks Inchpincher... That's a beautiful car. Yours? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Feb 07, 2018 7:38 pm Post subject: Re: <insert name here> Build Thread |
TDCTDI wrote: |
xzener wrote: |
Reuse your original or find an original one, much better quality. |
Thanks TDCTDI! Peeled my finger off the buy now button until I got a response. I will reuse my original. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Feb 07, 2018 7:50 pm Post subject: Re: <insert name here> Build Thread |
Received my early style dog house shroud today. Decided to buy from a forum member... Should have just bought a new Scat or EMPI one. This thing is falling apart. All the spot welds for the inner air foils we're shotty. Nothing a little JBWeld can't fix. Probably gonna end up painting it the exterior color. Will get it sanded and prepped.
On a side note... Went to the doctor a couple weeks ago, asked to be put on Chantix. I made a deal with myself... Can't paint the car until I quit smoking. Well, it's been over a week since my last cigarette. Looks as though I will be getting some quotes here soon. Very excited. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Feb 20, 2018 5:17 pm Post subject: Re: <insert name here> Build Thread |
Been shopping for a wire harness. Seems as though the early 68 harness isn't listed. I have read that the harness on an early 68 is different than a later 68. Mine had the huge flasher/emergency relay ($65) when I pulled all the electrical out. I'm guessing the 68-69 harness is what I should get... But would I be better off with a 67... Or even a 70-71?? What are the differences?? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Tue Feb 20, 2018 8:52 pm Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Been shopping for a wire harness. Seems as though the early 68 harness isn't listed. I have read that the harness on an early 68 is different than a later 68. Mine had the huge flasher/emergency relay ($65) when I pulled all the electrical out. I'm guessing the 68-69 harness is what I should get... But would I be better off with a 67... Or even a 70-71?? What are the differences?? |
Speaking as someone who had to rewire a '68 using the original wiring loom, and one that had that 9-pin relay to boot, I would suggest that you stick with the 9-pin system if you can. I didn't, and now cannot match my wiring to the diagram.
(I have 3 of those 9-pins to spare, and will place them on Darrel's thread if you don't want them. One has been tested and works. The other two I don't know.)
PS. Would you mind detailing your alternator conversion so that I can follow and do the same on the motor I'm building please? _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
xzener Samba Member
Posted: Tue Feb 20, 2018 9:01 pm Post subject: Re: <insert name here> Build Thread |
That would be great Kiwighia68! Mine was not working when I pulled it out if the car. I kept it in case I needed it as an example, but have found it on multiple sites... $65 is very expensive for what it is. And am reluctant to buy used. If you have one you know works, I will take it for sure.
I will document the conversion... Will be relocating the battery too. But won't be able to wire it all up till after the car is painted and get the harness in. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Tue Feb 20, 2018 9:16 pm Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
I will document the conversion... Will be relocating the battery too. But won't be able to wire it all up till after the car is painted and get the harness in. |
PM your address and I'll post them tomorrow. Pay it forward to someone else when you get the opportunity. _________________ Festina lente - hasten slowly
xzener Samba Member
Posted: Tue Feb 20, 2018 9:17 pm Post subject: Re: <insert name here> Build Thread |
Of course... Thanks man! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
