xzener Samba Member
Posted: Mon Sep 24, 2018 12:01 pm Post subject: Re: <insert name here> Build Thread |
Thanks KGCoupe! Still have yet to properly capture the color the naked eye sees. My recent pictures make it look very grey. Its blue/green with the naked eye. Have to agree with you, I also love the stance. Seems as though the spring plates have been adjusted, as the passenger side is lower. Will probably ignore it till I save up and install the rear air ride stuff. Will be removing the torsion bars at that point.
Now its time to stop procrastinating and get the windows done. By far my least favorite part of the build. Started in on the front windshield. The PO had purchased "American" style rubber (which I thought was Cal Look), turns out I had it on backwards, and the groove for the metal trim was there. So, I will be buying more rubber. Also need to purchase some windlace and get that going. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Onceler Samba Member
Posted: Mon Sep 24, 2018 7:43 pm Post subject: Re: <insert name here> Build Thread |
I don't think you'll have much trouble with the cal look rubber. The American aftermarket rubber with trim made me want to burn the car to the ground _________________ 1972 Karmann Ghia |
xzener Samba Member
Posted: Mon Sep 24, 2018 8:25 pm Post subject: Re: <insert name here> Build Thread |
Oh... Yeah... I was getting so pissed. As I rounded the third corner, I didn't have enough slack to get around the forth and had to start over. As I went along, the other side would slip off... Just to find out it was all for not. There were MANY cuss words being blasted. I'm sure the neighbors heard. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Sep 25, 2018 6:55 pm Post subject: Re: <insert name here> Build Thread |
I have a Grant GT Signature series wheel mounted. The turnsignal cancellation isn't working as it should. My front end has been completely rebuilt, 2 inch narrowed beam with 17" rims. When I turn left or right, the turnsignal is not turning off after completing the turn. It works fine in the garage, so I assume the wheel is not being turned enough to cancel the signal. Has anyone ever experienced this?? If so, is there a way to fix it?? Thanks. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Sep 26, 2018 5:24 pm Post subject: Re: <insert name here> Build Thread |
myghiarocks wrote: |
Take the six screws out of the sender, pull it out and ground it. Then try moving the arm up and down and see what the gauge does.
That is how I diagnosed a bad sender unit in mine. |
Pulled the sending unit out of the tank. Using a multimeter, I tested the resistance from the chassis, to the connector while tipping the cylinder allowing the float to travel up the shaft. There was no visible change in resistance. Reinstalled and gave the chassis a better ground. Didn't seem to have any effect. Went for a spin around the block and noticed the gas gauge needle bouncing around, but not past 1/4 tank. Parked it, allowed the fuel to settle, and turned the key. Now it reads 1/8th of a tank, but is intermittent. Turned the key a few times, wouldn't work a couple times without me tapping on the gauge. Having a hard time troubleshooting it down to the problem, but am leaning towards the gauge now. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Fri Oct 05, 2018 7:50 pm Post subject: Re: <insert name here> Build Thread |
Got the front wind shield in. Love the Cal look rubber from WCM. Was going in just fine by myself, had a neighbor (fellow VW enthusiast) help with the rest.
Wasn't happy with the original license plate bracket that came with the car. It didn't fit correctly. So, I made my own. Have since painted it black and installed it. Works perfectly.
Posted: Fri Oct 05, 2018 8:02 pm Post subject: Re: <insert name here> Build Thread |
Good deal IRT the window rubber, I've always like the cal-look rubber with modernized looking ghia's.
I bought a aftermarket license plate bracket, ended up re-contouring it to keep the plate off the new paint _________________ 1972 Karmann Ghia |
xzener Samba Member
Posted: Sat Oct 06, 2018 5:10 pm Post subject: Re: <insert name here> Build Thread |
So my wiper arms don't match. One has a nut that tightens to the shaft under the blade, the other tightens off to the side. Kiwighia68 was kind enough to let me know the nut under the blade was correct. But he said the length of the arms should be 10.5 and 11.5 inch. My supposed correct one is only 9.5 inch. Would the 67 beetle ones work, or are they shorter than Ghias??
https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-955-407-DPR _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Sun Oct 07, 2018 7:13 pm Post subject: Re: <insert name here> Build Thread |
A couple photos as promised. I see a rubber grommet, a stainless steel washer and a brass washer (13mm maybe) on the wiper shaft. At least one of the photos will show the internal mechanisms of the arm.
_________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
xzener Samba Member
Posted: Sun Oct 07, 2018 8:21 pm Post subject: Re: <insert name here> Build Thread |
Strange... You'd think there would be a grommet or something to cover the gasket/nut. It looks unfinished. The Germans couldn't have forgotten that. I will probably find something that will cover those. Your wouldn't happen to have a part number for those arms would ya? Thanks Kiwighia68. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sun Oct 07, 2018 8:47 pm Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Strange... You'd think there would be a grommet or something to cover the gasket/nut. It looks unfinished. The Germans couldn't have forgotten that. I will probably find something that will cover those. Your wouldn't happen to have a part number for those arms would ya? Thanks Kiwighia68. |
Sorry, but I don't have a part number. I'd like to see what you do for a cover over the brass nut and then I'm going to copy your solution. (Unless you take out a patent.) _________________ Festina lente - hasten slowly
xzener Samba Member
Posted: Sun Oct 07, 2018 8:49 pm Post subject: Re: <insert name here> Build Thread |
Already have an idea of what to do... Stay tuned. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
advCo Samba Member
Joined: May 27, 2017 Posts: 373 Location: Houston, TX
Posted: Mon Oct 08, 2018 8:01 am Post subject: Re: <insert name here> Build Thread |
IIRC my '70 had a plastic cap covering the grommet and nut...
I'll find it this evening and edit this post with a pic. Could probably be 3d printed pretty easily. _________________ "He pulled the mirrors off his Cadillac ‘cause he doesn’t like it looking like he looks back"
'68/'70 Ghia Coupe Project
'70 Westy Project - Champagne I Wannabe
A bunch of vintage Japanese motorcycles
"Much ingenuity with a little money is vastly more profitable and amusing than much money without ingenuity." -A. Bennett |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Mon Oct 08, 2018 8:07 am Post subject: Re: <insert name here> Build Thread |
You're begging to score the windshield with this wiper blade insert not being fully seated/secured in the assembly. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Oct 08, 2018 10:23 am Post subject: Re: <insert name here> Build Thread |
TDCTDI wrote: |
You're begging to score the windshield with this wiper blade insert not being fully seated/secured in the assembly. |
Thanks. I'll fix that now.
With the weather here, you either drive your Ghia in the rain or not at all. Four seasons in one day describes Auckland's weather. _________________ Festina lente - hasten slowly
xzener Samba Member
Posted: Sat Oct 13, 2018 12:41 pm Post subject: Re: <insert name here> Build Thread |
Ok, so I think this might work. Otherwise I have another idea... It's a bolt cap. I removed the metal piece and drilled a hole in it. Done. Waiting for the wiper arm paint to dry.
Posted: Sat Oct 13, 2018 1:14 pm Post subject: Re: <insert name here> Build Thread |
xzener wrote: |
Good work. I'm following suit. _________________ Festina lente - hasten slowly
xzener Samba Member
Posted: Sat Oct 13, 2018 3:56 pm Post subject: Re: <insert name here> Build Thread |
Done. Looks better than the bare hardware look, and it's fully functional.
xzener Samba Member
Posted: Sat Oct 13, 2018 7:14 pm Post subject: Re: <insert name here> Build Thread |
So with all the odds and ends getting done, been installing the air compressor permanently in the spare tire area... Out of sight, out of mind. I'm going to cut a tire in half to place on top of the air ride setup to completely hide it. Also contemplating installing the control pad in the ash tray some how.
Edit:
Ash tray air ride controller update. Man... VW made these ash trays nearly invincible. Was able to modify the tray to allow the controller to sit almost flush. Have some tweaking to do, but I'm happy with the results so far.
xzener Samba Member
Posted: Sun Oct 14, 2018 2:29 pm Post subject: Re: <insert name here> Build Thread |
Driver side popout window done and functional... Probably gonna follow suit with Kiwighia68 and leave them closed.
On the passenger side though, is there anything I can do to fix the dent/bend in the weather stripping?? I could probably shove some cotton down into the corner to help it mold to the corner better. Has anyone else fixed theirs in a similar fashion??
