rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Fri Apr 03, 2020 12:51 pm Post subject: Re: The Aufgeladen Ghia |
Crocteau, what is RLR Ron Lumus Racing????
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Fri Apr 03, 2020 12:54 pm Post subject: Re: The Aufgeladen Ghia |
Check out CIP1, much cheaper and pre-plumbed. I never seen one mounted in the cabin, always in the engine compartment.
2012 Passat-Sold
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Fri Apr 03, 2020 1:38 pm Post subject: Re: The Aufgeladen Ghia |
xzener wrote: |
Trying to eliminate oil blow by at the crank pulley. Have an oil stain ring on the deck lid, caused by oil slinging from the crank pulley. Installing a breather box may help this issue... Should it not? |
No, it won't solve all of your issues. Since you are pressurizing the intake, you need to create vacuum on the crankcase by routing a breather hose to the inlet side of the carburetor. You will also need to get a sand seal for the crank pulley, but IDK if you can do that for the serpentine drive pulley. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Fri Apr 03, 2020 4:32 pm Post subject: Re: The Aufgeladen Ghia |
Thanks for the input guys. Jeff, not through the fire wall into the cabin, through the front tin (I called it firewall) to route the hoses to the head covers. I plan on mounting it either on the backside of the fan shroud, or against the firewall behind the shroud. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Fri Apr 03, 2020 4:40 pm Post subject: Re: The Aufgeladen Ghia |
TDCTDI wrote: |
No, it won't solve all of your issues. Since you are pressurizing the intake, you need to create vacuum on the crankcase by routing a breather hose to the inlet side of the carburetor. You will also need to get a sand seal for the crank pulley, but IDK if you can do that for the serpentine drive pulley. |
I read about this today while I was researching my problem. Guys with high performance V8 engines add vacuum to the case to eliminate pressure. Do you recommend adding a T fitting where it comes off the oil filler and add a hose going to the intake/filter? I plan on using AN fittings for everything, I could make the hole bigger on the oil filler.
So how are you guys routing the breather hoses from the box to the head covers? Through the front tin?? Here is the box I got from the classifieds, not sure the brand name...
Posted: Fri Apr 03, 2020 4:50 pm Post subject: Re: The Aufgeladen Ghia |
Are you still running a mechanical fuel pump? If not, there are threaded block off plates to use as a scavenging port.
https://www.appletreeauto.com/FUEL-PUMP-BLOCK-OFF-...bMQAvD_BwE _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Fri Apr 03, 2020 6:21 pm Post subject: Re: The Aufgeladen Ghia |
I'd have to remove the supercharger and modify the mount. That is where it mounts, where the old mechanical pump was. Running an electric pump now. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Sat Apr 04, 2020 4:32 pm Post subject: Re: The Aufgeladen Ghia |
Have the breather box mounted. Hopefully I will be able to get the lid off. 🤔
xzener Samba Member
Posted: Fri Apr 10, 2020 7:01 pm Post subject: Re: The Aufgeladen Ghia |
Finally gave her a bath... She was filthy.
Inchpincher61 Samba Member
Joined: February 05, 2016 Posts: 141 Location: Germany
Posted: Fri Apr 10, 2020 10:49 pm Post subject: Re: The Aufgeladen Ghia |
I think I said that some times before but I really like color in combination with those matt wheels
I am excited of the first test drive! I hope there will be no major problems |
Ant B Samba Member
Joined: December 24, 2019 Posts: 157 Location: surrey, UK
Posted: Sat Apr 11, 2020 1:52 am Post subject: Re: The Aufgeladen Ghia |
That is beautiful.
Love the colour.
Ant |
xzener Samba Member
Posted: Sun Apr 12, 2020 1:01 pm Post subject: Re: The Aufgeladen Ghia |
Turns out is wasn't the heat exchanger junction, it was the #2 exhaust port. Found remnants of a previous gasket, zoom into the port, you can see it in the photo. Cleaned it all up, sanded it smooth. I bought some Permatex Ultra Copper gasket maker and will be applying a thin layer around each gasket before tightening down everything.
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Apr 12, 2020 1:06 pm Post subject: Re: The Aufgeladen Ghia |
doesn't look like it was the gasket failing. looks like there is a piece of a previous gasket still stuck on the head, not allowing the gasket to seal properly in the first place. the surface of the head should be very clean and smooth to get good gasket compression.
i think ultra-copper is not going to hold up well at the head-to-muffler junction. |
xzener Samba Member
Posted: Sun Apr 12, 2020 2:03 pm Post subject: Re: The Aufgeladen Ghia |
Yep. Cleaned the head ports smooth. That piece of gasket was surely the cause. People swear by this stuff... It's a thin layer. We'll see if it holds up. This was more than likely giving me faulty readings on the AFR gauge too. Plan on starting from scratch with the carburetor adjustment. Giving it the recommended cure time of 24hrs before starting it up. Will keep you guys posted. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
xzener Samba Member
Posted: Mon Apr 13, 2020 10:36 am Post subject: Re: The Aufgeladen Ghia |
Thanks for the links Bryan. Will resort to those if needed. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Mon Apr 13, 2020 10:43 am Post subject: Re: The Aufgeladen Ghia |
xzener wrote: |
Thanks for the links Bryan. Will resort to those if needed. |
Now you just need to flange the heat exchangers/J-tubes & get rid of that hokey-ass, sure-to-leak crush washer/clamp deal. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
xzener Samba Member
Posted: Mon Apr 13, 2020 11:10 am Post subject: Re: The Aufgeladen Ghia |
TDCTDI wrote: |
Now you just need to flange the heat exchangers/J-tubes & get rid of that hokey-ass, sure-to-leak crush washer/clamp deal. |
You are right... Planned for the next build. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Thu Apr 16, 2020 9:12 am Post subject: Re: The Aufgeladen Ghia |
Is it possible for a battery to have enough juice to turn-over the engine multiple times, but not have enough juice to fire spark plugs? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
slalombuggy Samba Member
Posted: Thu Apr 16, 2020 9:30 am Post subject: Re: The Aufgeladen Ghia |
xzener wrote: |
Is it possible for a battery to have enough juice to turn-over the engine multiple times, but not have enough juice to fire spark plugs? |
Yes, If you have a high draw from the starter it could drop the available voltage low enough to not fire the plugs. Or there may be a high resistance in the power wire from the front to the coil.
Quick check it to put a volt meter on the coil (+) have someone crank it and watch the voltage.
brad |
