Subaru conversion help
jigga
jigga is offline
PostPosted: Mon Dec 25, 2017 7:14 am    Post subject: Subaru conversion help Reply with quote
Hi,
Ive recently put a subaru 2.5L into my buggy, and im having issue with the engine cutting out. I have driven it briefly before and it was running ok (albiet a high idle). The mechanic had a look at it, did some things and now it cuts out. Naturally, I cant reach him on the phone.
Does anyone have any suggestions on what this could be?
Dale M.
Dale M. is offline
PostPosted: Mon Dec 25, 2017 9:24 am    Post subject: Re: Subaru conversion help Reply with quote
Carburetor(s) or EFI?
Need better description of problem than "cuts out"...
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Mon Dec 25, 2017 9:37 am    Post subject: Re: Subaru conversion help Reply with quote
Add gas. Honestly it could be about anything!
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
Tom_Kathleen
Tom_Kathleen is offline
PostPosted: Mon Dec 25, 2017 2:10 pm    Post subject: Re: Subaru conversion help Reply with quote
Where are you located? If you are in SoCAl, try Outfront Motorsports. We have a shop here in CT that has helped us out many times with our Subaru powered Manxter. It call RABE Motorsports in Wallingford, CT. Tom
Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA
jigga
jigga is offline
PostPosted: Tue Dec 26, 2017 7:46 am    Post subject: Re: Subaru conversion help Reply with quote
Dale
Efi dale.
jigga
jigga is offline
PostPosted: Tue Dec 26, 2017 7:47 am    Post subject: Re: Subaru conversion help Reply with quote
Dale
Engine starts, drives a short distances then it feels like it's starving for fuel (power cuts out then comes back). Then not long later engine stalls.
jigga
jigga is offline
PostPosted: Tue Dec 26, 2017 7:48 am    Post subject: Re: Subaru conversion help Reply with quote
I'm in Australia Sad
sb001
sb001 is offline
PostPosted: Tue Dec 26, 2017 8:44 am    Post subject: Re: Subaru conversion help Reply with quote
Try Out BACK motorsports
1969 autostick sedan, owned since new
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Letterman7
Letterman7 is offline
PostPosted: Tue Dec 26, 2017 11:59 am    Post subject: Re: Subaru conversion help Reply with quote
Not to be snarky, but find a qualified Subaru tech that is willing to sit with the car and diagnose it with the OBD connections. Anything else is going to be guesswork through the internet.
Tom_Kathleen
PostPosted: Tue Dec 26, 2017 6:18 pm    Post subject: Re: Subaru conversion help Reply with quote
That will work unless he has a aftermarket ECU like we have (EMS Stinger). Then the troubleshooting gets more difficult. Tom
Manx Club & CVA
cbeck
cbeck is offline
PostPosted: Wed Dec 27, 2017 6:51 am    Post subject: Re: Subaru conversion help Reply with quote
Start with checking all the ground connections. All the ecm's I have dealt with have multiple ground connections.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
jigga
jigga is offline
PostPosted: Wed Dec 27, 2017 7:41 am    Post subject: Re: Subaru conversion help Reply with quote
Thanks everyone. I'll try a Subaru technician first. Fingers crossed!
Lo Cash John
Lo Cash John is offline
PostPosted: Tue Jan 02, 2018 9:57 pm    Post subject: Re: Subaru conversion help Reply with quote
If it's losing power then stalling, you're losing something. It could be:
Fuel pressure (bad filters? Bad pump? Bad circuit powering pump?)
Spark (bad coil pack? Bad ignitor?)
Info (could a sensor be failing and the lack of info cause the ECU to shut down?)
www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
manxvair
manxvair is offline
PostPosted: Sun Jan 21, 2018 8:47 pm    Post subject: Re: Subaru conversion help Reply with quote
Since you're in Australia try Todd at http://www.subarugears.com/ he deals with all kinds of Subaru conversions and might at least get you in touch with someone that can help.
