DubNuts Samba Member
Posted: Tue Dec 26, 2017 1:53 pm Post subject: Bus Depot New Vanagon Rectangular headlamps |
Not sure if this was Posted, Looked but didn't see anything..
New Vanagon Rectangular headlamps by Bus Depot..
These things have been long extinct and out of Production.
But Ron at Bus Depot has resurrected the dead, and it appears that the Kit includes everything including the e-code Lights..
They even include a Cool Accent Light. So you can add a K@@L parking Lamp color of your choice..
Gots mine on Order what about You?
http://www.busdepot.com/255941105kit |
Paulbeard Samba Member
Posted: Tue Dec 26, 2017 3:11 pm Post subject: Re: New Vanagon Rectangular headlamps |
Busdepot posted a note to one of the existing threads on adding E-codes/H4 lamps. I rolled my own, with a lot of help from some other folks on here. It's not that hard to do it yourself, if I can do it. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
jimf909 Samba Member
Posted: Tue Dec 26, 2017 3:24 pm Post subject: Re: New Vanagon Rectangular headlamps |
Here’s the DIY thread PaulBeard mentioned. There are several write-ups of good conversions.
https://www.thesamba.com/vw/forum/viewtopic.php?t=583876
As with the GPS tracker thread that discusses several tracker options, this is one of those improvements that can be done several ways and the important thing isn’t which alternative one chooses, it’s that one chooses to make the modification.
Most old rectangular headlights are just plain unsafe and should be replaced (see my photo of the worn out “reflector” in the thread above). I hope Bus Depot sells hundreds of kits (I may have gone with his kit if it was available at the time I followed the DIY instructions in the thread).
Post a write-up of your install! I’d love to see how it all goes together. _________________ - Jim
Abscate wrote: |
figborg Samba Member
Joined: August 24, 2015 Posts: 338 Location: Northeast
Posted: Tue Dec 26, 2017 11:27 pm Post subject: Re: New Vanagon Rectangular headlamps |
Thanks for the heads up. I will pre-order a set. Interested to read other comments though these will not be out until February. I read the thread that Jim shared a while back and almost went that route but I’m happy to support the Bus Depot... and ultimately do less work
Edit: very interested in the answer to this question by Alaskaberrys posted on another thread, just in case it falls through the cracks. I have the GW relays:
Alaskaberrys wrote: |
Figured I'd ask this question here instead of directly on BusDepot website as others may have similar question.
If I have an aftermarket headlight relay kit already installed like GoWesty's or T3's, which kit would we order? I'm assuming the Ultimate kit would just be replacing these? Would the Upgrade kit too? Trying to avoid duplicating parts (I've got T3's headlight kit) but would like to maximize the light. |
_________________ -- PF
Providence, RI
1986.5 Westy camper (G year code, grey interior), 2WD, manual transmission, Subaru conversion by Vanaru. Spoiled rotten.
http://www.thesamba.com/vw/forum/viewtopic.php?t=662374 |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Dec 27, 2017 3:27 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
If they are the same as I have on my Syncro imported in 2016 they do work much better then the OEM VW.
However, my hopes of using the city lights(parking lights) as DRL's has not lived up to expectations.
The city light bulb is too far away from the optical center to show a concentrated beam that is what you need to attract attention.
I do have LED bulbs in for the city lights and they are bright, but just not enough uumph in daylight due to the offcenter of the bulb. The LED's I put in were the highest power I could find for the socket at the time and brighter then the H4 low beam.
I had to fit the LED from the inside out as they were too big to fit through the opening.
I'll post some pics tomorrow in daylight for a DRL evaluation.
Meanwhile here is a night shot showing the reflected light from the city light being too far away from the ideal optical center..
_________________ This free advice is worth exactly what you paid for it.
Posted: Wed Dec 27, 2017 7:58 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
My Thoughts on the City Lights is that they would be Great when maneuvering through Camp Sites after dark not to blind or distribute other Campers late at Night..
Also think they could be Kool to use other color accent Lights when parked, etc..
BTW guys these are direct Fit Plug and Play Replacement Headlights.. |
dougass Samba Member
Posted: Wed Dec 27, 2017 8:29 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
What do you guys think of these Rigid Industries / Truck-Lite headlights?
https://www.rigidindustries.com/led-lighting/55003 _________________ '91 GL - 2.1 automatic named Klaus for weekend adventures.
#klausvan & @thisisklausvan |
Posted: Wed Dec 27, 2017 9:50 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
DubNuts wrote: |
My Thoughts on the City Lights is that they would be Great when maneuvering through Camp Sites after dark not to blind or distribute other Campers late at Night... |
No. They have little projection forward to "see" by.
The LED 7" Jeep headlights with the DRL Halo ring are better for lighting a picnic table or space to pitch a tent at night.
Edit: I just tried them tonight and it was not a dark area, but there was "some" light in front of them. They are a bright light with the LED bulbs in there, but it doesn't seem a good light to see by.
I'll try them outside of the civilized part of town to tomorrow night and see I can get some pictures of them. _________________ This free advice is worth exactly what you paid for it.
Posted: Wed Dec 27, 2017 4:31 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
So the City Lights as DRL in Daylight...actually overcast and in the shade of the building.
City Light OFF
City Light ON
City light at a distance not jumping out at me!Overcast day in the shade too!
Low Beams ON
City light bulb inside the lens.
Now having said they don't light up my life I still use them as DRL's only because they are different and people do notice something different.
I plan on upgrading with some Cree light Strips.
I would still buy them to get a set of H4's in the size for the grill. _________________ This free advice is worth exactly what you paid for it.
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Wed Dec 27, 2017 7:42 pm Post subject: Re: New Vanagon Rectangular headlamps |
figborg wrote: |
There is no need to add a new headlight relays if you already have a set installed.
The "Upgraded Kit" includes a headlight harness similar to the South African Grill Harness. It replaces the old 9004 plugs with ceramic H4 sockets and also has new wiring and terminals for the inner H3 bulbs. Based on the condition of the 27+ year old stock wiring I routinely see, replacing all of the headlight connections is a good idea.
_________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Wed Dec 27, 2017 8:14 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
Jay-great sig. Practicing compassion is the best practice of all and truly promotes mindfulness and happiness for self and others.
Anyhoo, I think these buckets are awesome and are officially on my wishlist. Are wishlists mindful?😀 _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Thu Dec 28, 2017 11:49 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
Thanks for the post. I have a lot of DIY projects on the list, thought maybe I should let someone else do it for once.....I ordered too. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Thu Dec 28, 2017 8:09 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
Steve M. wrote: |
DubNuts wrote: |
I'll try them outside of the civilized part of town to tomorrow night and see I can get some pictures of them. |
Okay I got far enough way from the city and found a roadside picnic area to see if the city lights would light up enough to see at night.
The result is I am suitably embarrassed and will admit my ignorance.
However, while they do cast a light forward enough to see in total darkness the problem is that if you just drove in with your headlights on your eyes may not adjust to the dim city lights to see.
1/2 hr. after turning off all the lights and your eyes accustomed to the darkness they did have enough light to see.
City Lights. Okay you cannot see what is there in this image, but I can see that there is something there in the camera's image.
Low Beams to show how far away the table really was.
Posted: Thu Dec 28, 2017 10:43 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
I don’t believe city lights (the small ~20 watt lamp at the top or bottom of the reflector) were ever meant to project light forward. My impression is that they’re just meant to add some visibility of you. Perhaps they’re from the days before turn signals were used as parking lights?
My experience is with BMW motorcycles: before 1977 (and fed mandated headlights on all the time) there was a light switch setting that would illuminate the front city light and taillight, the key could also be removed to use these lights as parking lights; after 1977, for a few years at least, the switch was gone but the front city light and taillight could be left on as parking lights with the key removed. Then again, motorcycles aren’t cars and this answer may belong in the lazy persons stupid answer thread... _________________ - Jim
Abscate wrote: |
kamzcab86 Samba Moderator
Posted: Thu Dec 28, 2017 11:29 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
jimf909 wrote: |
I don’t believe city lights (the small ~20 watt lamp at the top or bottom of the reflector) were ever meant to project light forward. My impression is that they’re just meant to add some visibility of you. Perhaps they’re from the days before turn signals were used as parking lights? |
A) City lights were/are originally 5 watts.
B) City lights, as explained to me long ago, are parking lights in Europe for when vehicles are street-parked at night, particularly on unlit streets/alleys. Therefore, no, they were never meant for actual driving. The old Euro water-pumpers have city lights in the bumper-mounted light housings... my Cabriolet is using the city lights as running lights. Due to how close the two bulbs are in the bumper housing, the clear lens lights up amber. _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Dec 29, 2017 1:05 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
^^^ 5 watts...that makes sense, my decades old memory may recall folks using a 20 watt lamp so it would appear to meet the always on headlight laws for motorcycles. This was to gain a few watts (by replacing a 55 watt headlight with a 20 watt city light) in the losing battle of running a BMW motorcycle with its inadequate 260 or 280 watt alternator (always be cautious when a mfr. sells a brand new motorcycle with a complimentary battery charger).
Regardless, the origins of city lights may be for parking visibility, not for illuminating the road ahead while driving. _________________ - Jim
Abscate wrote: |
Posted: Fri Dec 29, 2017 9:02 am Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
I think this Topic has gone off Topic.. It's just not about the City Lights of this Product but more the Availability of this once gone Headlight replacement Kit.
I merely posted the upcoming availability of these New Late Style Vanagon Headlights by Bus Depot for those who may wish to finally have a Plug-and-Play solution..
As for the 3rd separate Bulb aka City Lights.. It's simple enough to change that bulb or even bulb housing to the color and wattage bulb of your Choice and that's what I plan on doing since the Headlight Glass Housing already has the Bulb penetration manufactured into it.. It's a great option not an Issue..
The Beauty about this Product is Having New Glass Headlights with a New Mirror Finish. Win-Win..
sciroccojim Samba Member
Posted: Fri Dec 29, 2017 3:52 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
Does anyone have any thoughts about this versus the S.A. 7" round kit (with 5" high beams)? We've converted to the S.A. kit (with relays) and I'm loving it, but I would have been happy to keep the O.E. look, as I think it suits the van better.
Just wondering if these would end up being as bright as the 7" rounds. I tend to think not, although I'm sure they'd be decent. _________________ 1987 Westy Camper |
Posted: Fri Dec 29, 2017 4:33 pm Post subject: Re: Bus Depot New Vanagon Rectangular headlamps |
The rectangular eCode headlights are brand new, so we can only guess how they will compare to the output of the SA Grill.
To make doing any meaningful comparison more complex, it's important to remember that the quality of the lighting from the SA Grill setup is directly tied to the 7" round headlights installed. The beam shape and cutoff can be drastically different from brand to brand.
A few photos of the new lights shining on a wall can give us a decent idea of the cutoff. Getting an overall impression of the quality of the lighting will take some real world testing from the driver's seat. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
