dieselgti Samba Member
Posted: Tue Dec 26, 2017 6:44 pm Post subject: 2003 Eurovan Replace HVAC Blower Motor Resistor |
Has anyone replaced the HVAC Blower Motor Resistor on a 2003 Eurovan GLS? My son is driving the van this winter and the front vents stopped working. The HVAC unit blinks on startup and I checked the error code and it's the Blower Motor.
Has anyone replaced it? Any links to a DIY? I can't find much out there...
Thanks, Brandon |
Abscate Samba Member
Posted: Tue Dec 26, 2017 7:21 pm Post subject: Re: 2003 Eurovan Replace HVAC Blower Motor Resistor |
Just remove the knee padding on the passenger side, depress the clip, twist and remove. In total, about 2.5-3 hours , most of which is fussing with the dash. _________________ .ssS! |
Posted: Tue Dec 26, 2017 7:44 pm Post subject: Re: 2003 Eurovan Replace HVAC Blower Motor Resistor |
[quote="Abscate"]Just remove the knee padding on the passenger side, depress the clip, twist and remove. In total, about 2.5-3 hours , most of which is fussing with the dash.[/quote
Cool, thanks! I'll give it a try tomorrow! |
Posted: Tue Dec 26, 2017 8:16 pm Post subject: Re: 2003 Eurovan Replace HVAC Blower Motor Resistor |
Brandon...total brain fart.
I thought you were after the fan motor. I think you can sneak the resistor pack out after removing one screw without pulling the knee pad.
Worth a try.
Alldata reports 0.5 hours for the resistor _________________ .ssS! |
