sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Wed Dec 27, 2017 12:33 pm Post subject: Block heater |
I have a '81 diesel Caddy and it came with a ton of great parts. I found a block heater in the box which works but I can't figure out where it goes? It has some light scrapping as if it was mounted on the bottom. And it has a 3 bolt plate for mounting. I did some searching and keep coming up with the freeze plug style. Any ideas?
_________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Thu Dec 28, 2017 8:14 am Post subject: Re: Block heater |
How do you know if it's for the VW? I could be just a block heater for some other manufacturer.
The one I had in my gas Caddy [Why? I do not know, I bought it used], fell out while driving on the freeway. |
Posted: Thu Dec 28, 2017 2:48 pm Post subject: Re: Block heater |
Butcher wrote: |
I don't know for sure, The huge box of spare parts looked like the PO parted out another rabbit. I was just taking a stab in the dark that someone else would know. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu Dec 28, 2017 3:37 pm Post subject: Re: Block heater |
sixfootdan wrote: |
Butcher wrote: |
I don't know for sure, The huge box of spare parts looked like the PO parted out another rabbit. I was just taking a stab in the dark that someone else would know. |
I haven't seen one that looked like that for a VW application & can't think of any part of a rabbit engine that would accept those mounting points. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Dec 29, 2017 6:25 am Post subject: Re: Block heater |
So let me ask this, What is a good heater for the diesel? _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Fri Dec 29, 2017 9:18 am Post subject: Re: Block heater |
This is the common style that replaces a freeze plug on the back of the block.
https://www.partsplaceinc.com/vw-freeze-plug-style-block-heater-3710.html _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri Dec 29, 2017 11:20 pm Post subject: Re: Block heater |
I used that style for years on my gas motored Rabbit, had heat almost the moment I started car. Never had any snow on hood, always melted away.
I think the Freeze plug style is the only style that will work on a VW, was told or read somewhere the ones that go into the hose won't work. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Dec 30, 2017 8:39 am Post subject: Re: Block heater |
hard to tell the size but that looks like it might have bolted to 3 of the 6 bolts on the oil strainer plate of an air cooled bug with a grommet for a hole in the cooling tin.... |
Posted: Sat Dec 30, 2017 6:09 pm Post subject: Re: Block heater |
volksworld wrote: |
Good point Thanks for the info everyone. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
