SGKent Samba Member
Posted: Thu Dec 28, 2017 10:04 pm Post subject: EFI |
Kind of curious if anyone has installed an EFI system like these 2 below on a bay engine - either T1 or T4. Kinda wonder why the folks that remove factory FI aren't thinking modern FI systems instead of troublesome carbs. Made me think about it while watching a couple videos of F1 engines which are making 20,000 RPM and a huge amount of power just running injectors that spray into the air horns -see video at bottom below if that sort of thing interests you. There is a throttle blade and an injector plus the monitoring O2 sensor, map, TPS, ECU and programmable software. The newer generation stuff coming out has to be easier to work with that the EFI systems 10 - 15 years ago like the Mexican bug stuff.
dual style:
progressive style:
F1 at RPM
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Dec 29, 2017 12:21 am Post subject: Re: EFI |
If that is Redline of Torrance, Calif, they are the same company that supplied me with the correct set-up advice and jets for my controversial Weber Progressive DFEV carburetor.
It would be pretty cool if CARB would issue their blessing for that kit you show, Steve. |
Posted: Fri Dec 29, 2017 10:34 am Post subject: Re: EFI |
Looks like the Type 4 engine gets ignored once again. Redline shows that kit pictured above is for the Type 1 and their listing for kits seems to exclude Type 4 engines. |
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Sat Dec 30, 2017 2:56 pm Post subject: Re: EFI |
I actually prefer running L-jet over carbs and even better is running a modern FI system that also controls spark. This gives you a ton of advantages in usability of your car once you got everything installed properly. Especially if you live in a place where the climate varies a lot or you drive at different altitudes.
I guess the cheapest way to do it is use the stock L-jet system and slap on some extra sensors and convert to an aftermarket ECU like Megasquirt.
These days a lot of kits are made to make installing your sensors, wiring etc. a whole lot easier. I recently got some quality parts from Mario at The Dubshop. If you want to go modern EFI, you may want to check it out here: http://thedubshop.goodsie.com/dual-throttle-body-package-type-4-vw-fuel-and-ignition _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Dec 30, 2017 7:39 pm Post subject: Re: EFI |
Very good info, MadMax. I wish I had known about the DubShop when I was converting mine. It's expensive, but sounds like it's well worth it. Next time... _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
