ConcreteAce's '51 build
ConcreteAce
ConcreteAce is offline
PostPosted: Sat Mar 31, 2018 8:06 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Made a little more progress with help from some of my fellow club members. Cut and buffed the old paint. She shined up nicely. enjoy the photos..
and after 11 hrs its almost done
and a couple of high speed video's
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build
Oldman64
Oldman64 is offline
PostPosted: Mon Apr 02, 2018 10:34 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
you guys somehow make this stuff look easy...really cool car and great to see guys rallying around and getting stuff dialed.
txoval
txoval is offline
PostPosted: Mon Apr 02, 2018 6:18 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Did you guys start with 1000 or 2000 grit? Or use compounds only?
Looks great!
ConcreteAce
PostPosted: Mon Apr 02, 2018 7:08 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Looks great!
started with 1000 dry and then moved to 1500 wet , 3000 wet, 5000 wet
wool pad with 3M Cutting
foam pad with 3m Polish
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
German Krew
German Krew is offline
PostPosted: Mon Apr 02, 2018 7:37 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Looks great are you taking it to the Classic?
ConcreteAce
PostPosted: Mon Apr 02, 2018 7:49 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
LOL you must have missed my answer last time. Yes as long as it makes it , Plan is to drive it there.
ConcreteAce wrote:
German Krew wrote:
Nice work will you have it at The Classic?
That is my plan as long as everything does well in the next couple of weeks during shake down trips.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
German Krew
PostPosted: Mon Apr 02, 2018 7:52 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Laughing Laughing Laughing Laughing
Good luck and hope to see it there.
ConcreteAce
PostPosted: Mon Apr 02, 2018 7:55 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
I will need it , I am going to take a few trips that are at least an hour these next weeks to see how she handles.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
ConcreteAce
PostPosted: Wed Apr 04, 2018 8:50 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Well it is always the little things, I am not sure what is going on here, no visible cracks in the plug wires, no nicks, but it darn sure is jumping from the plug wires to the braided oil filter line.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
johnshenry Premium Member
johnshenry is offline
PostPosted: Thu Apr 05, 2018 5:16 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
Disconnect a plug wire one at a time at the head, let it limp on 3 cylinders and see if you can narrow it down to one bad wire, then replace it.
John Henry
'57 Deluxe
'56 Single Cab
sunroof
sunroof is offline
PostPosted: Thu Apr 05, 2018 7:58 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
Just read through this whole thread for the first time, so fun! Great job, thanks for taking the time to post all your great work.
Don
Your mother was a hamster and your father smelt of elderberries!
western auto
western auto is offline
PostPosted: Thu Apr 05, 2018 9:51 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
check your plug gap if its too wide spark will follow the path of least resistance
txoval
txoval is offline
PostPosted: Thu Apr 05, 2018 7:52 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Same thing happened to me...replaced wires
Sometimes you canít see the fractures
ConcreteAce
PostPosted: Thu Apr 05, 2018 7:55 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Yep new wires are on the way. Just sucks buying things twice..lol
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
djfordmanjack
djfordmanjack is offline
PostPosted: Fri Apr 06, 2018 2:54 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
wow, she shines beautifully! gorgeous! terrific mates and work !
Hotrods, Fords, Veedubs and Triumph Twins ! ______Barndoor + Kohlruss Coachbuilt DLX afficionado
'51 Brezel project, Azurblau L36
'52 BD Coachbuild project
'54 Oval Sunroof project with my son, L275 Lichtbeige
'55 Wolfsburg panel project, Taubenblau L31 all original paint
'56 Oval, Polarsilber L324 og paint og chrome og everything
ConcreteAce
PostPosted: Wed Apr 25, 2018 10:21 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
Well I took the old girl on a ten hour trip this past weekend. Drove it from Houston to Fredericksburg TX for the Texas VW classic. I ran her 640 miles the entire weekend. I did get a new set of plug wires installed before the trip, adjusted the valves and put a final tune and sync on the carbs. She hummed the whole way only stopping for fuel. I averaged 28.6 miles per gallon. She is a little slow climbing hills but she ran a steady 55-60 mph (GPS verified).
I only had two small issues the ISP reproduction pulley is leaking. I did run into a thread shortly after I bought the pulley https://www.thesamba.com/vw/forum/viewtopic.php?t=...;start=100
I wish I had read that before I spent 100 bucks on the pulley. I plan on switching it out with a stock pulley to see if that stops the leak. The other issue I have is that it is harder to start after you have been on the road for some time. It does start every time but it takes way longer than normal. I found if I start it with the throttle pushed to the floor it starts faster then if you just pump it once and push the button. I plan on tackling that issue in the next week or so.
One thing I did notice and I am not sure if this is an issue because I have never had a stock height car. It seems that the car is a little stiff and bouncy up front. I installed new kings, links and shocks so I am not sure if it is stiff just because everything is new or if there is an issue that I need to address. Before I left I aired the fronts up to 17 lbs and the rears to 25 lbs. on the highway it seemed fine but at lower speeds on normal roads and you feel everything. (that was the only complaint the wife had on the entire trip, she said the girls were sore from all the bouncing...lol if you get the point)
here are a couple of video's
and here are some pictures from the weekend and at the show. It is hard to believe but I got Best Engine at the show. Kind of a shocker since there were tons of beautiful 2 ltr's out there.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
pastellgreen
pastellgreen is offline
PostPosted: Thu Apr 26, 2018 1:21 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
I would state this to be normal, one time pump before getting started is the rule for a cold start of a 40hp engine with automatic choke system. For an already warmed up split the rule is to push the pedal slowly towards its end during cranking. There will be the point, where the engine will find enough fuel to start. For a very hot engine after only a short stop pushing directly the pedal to the end of its way during cranking is also my experience.
Welcome driving a stock spilt! The stiffy front axle is one of the caracterisitc points of the spilt eara! You might think there is no front suspension, but of course it is. They wanted the front axle to improve the car to corner well. A normal front suspension was spend up from the oval eara by expanding also the spring travel.
Your car sonds so nice during running!
German Krew
PostPosted: Thu Apr 26, 2018 9:27 am    Post subject: Re: ConcreteAce's '51 build Reply with quote
Great finally meeting you Ethan and the DLK guys.
Car looked great and I was glad to finally see it in person.
Here are some of my paparazzi pics.
Two angles.
I had to make them hit the brake lights, it always looks so good!
ScottyG
ScottyG is offline
PostPosted: Thu Apr 26, 2018 12:52 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
ConcreteAce wrote:
.... It is hard to believe but I got Best Engine at the show. Kind of a shocker since there were tons of beautiful 2 ltr's out there.
Disagree... I'm not shocked at all! That engine is beautiful Very Happy
59 DC Chiny Bus... but not too Chiny
50 Beetle 11A Standard Hoffman
57 Beetle Aussie RHD CKD
60 Beetle OG Survivor
84 DOKA 2WD Road-Tripper!
ConcreteAce
PostPosted: Thu Apr 26, 2018 10:19 pm    Post subject: Re: ConcreteAce's '51 build Reply with quote
German Krew wrote:
[size=18][b]Great finally meeting you Ethan and the DLK guys.
Great pics! It was good meeting you as well. I'm looking forward to seeing your split.
Thanks man! LOL glad you didn't blow my doors off on the highway in your DC that cop would have got you for sure.
Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build
Page 7 of 9
