WestfaliaMike Samba Member
Posted: Mon Feb 19, 2018 4:53 pm Post subject: Re: LED Headlights, anyone try these? |
dobryan wrote: |
What is the pattern like vs stock? |
Here you go Dave. Not bad. van is about 30 feet from the door. I marked the center of the light beam, then pulled my wifes car up, and its pretty close. I thought they were high, but my driveway has a bit of an arch.
[img]
[/img] _________________ 1981 Vanagon Westfalia
1983 Vanagon Passanger (Parts Vehicle)
2016 Passat TSI |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1840 Location: Vancouver Island, BC
Posted: Mon Feb 19, 2018 5:07 pm Post subject: Re: LED Headlights, anyone try these? |
Crazy (?) idea here: If the cheaper LEDs, like the one MichaelCamping installed, are fine but just not bright enough, can we put two pairs? It would look like a SA grille, but with all lights the same diameter. Anyone with basic photo imaging skills? _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Posted: Mon Feb 19, 2018 5:33 pm Post subject: Re: LED Headlights, anyone try these? |
We will see how long they last... _________________ 1981 Vanagon Westfalia
2016 Passat TSI |
?Waldo? Samba Member
Posted: Mon Feb 19, 2018 7:01 pm Post subject: Re: LED Headlights, anyone try these? |
I just received these today and installed them in my '85. https://www.amazon.com/gp/product/B01B376YOE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
All I've done is a trip around the block with them so it's just my first impression. They are WAAAAAYYYYYY brighter than the stock headlights. I'm actually understating that. There's a larger difference in lighting between these and the stock headlights than there is between the stock headlights and having the stock headlights off and driving by moonlight during a 1/2 moon... The clarity and evenness of the light seems excellent. I have not had a chance to shine them on a wall and adjust the aim. It's too cold/windy/snowy for that tonight. My '91 has the relays, and brighter e-code H4's and these are much better lighting. Hopefully they last. The specs say 80,000 hours which if averaging 50 MPH is 400,000 miles. At this point I am more than pleased, I'm amazed. |
Posted: Tue Feb 20, 2018 3:09 am Post subject: Re: LED Headlights, anyone try these? |
?Waldo? wrote: |
Well said, in addition to how well they work, they have a glass lens. Theses are also chrome, not thenblacked out ones, so they dont take away the orginal look of the van
Waldo, did you make any adjustments after you installed them? _________________ 1981 Vanagon Westfalia
2016 Passat TSI |
Posted: Tue Feb 20, 2018 7:00 am Post subject: Re: LED Headlights, anyone try these? |
I haven't adjusted them yet. I will some time this week. I think they need to be aimed down a bit.
The ones I got are black and I like the look. I couldn't find the lumen ratings on the chrome ones you linked. Highest lumen output is the reason I went with the ones I got. Low beams are over 3X the lumen output of the stock low beams and yet lower wattage so no relays are needed. Incredibly easy upgrade. It was quicker and easier for me than swapping washer nozzles. |
Posted: Tue Feb 20, 2018 5:35 pm Post subject: Re: LED Headlights, anyone try these? |
?Waldo? wrote: |
I was thinking the same thing, just lower them just a bit _________________ 1981 Vanagon Westfalia
2016 Passat TSI |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Tue Feb 20, 2018 6:23 pm Post subject: Re: LED Headlights, anyone try these? |
I don't mean to hijack this thread but it seems to simple to be real plug in play. I have a '86 westy so if I got a circular head light grill I could just buy these lamps and plug them in and be set?!
And headlight buckets of course |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12114 Location: Port Manteau
Posted: Tue Feb 20, 2018 6:28 pm Post subject: Re: LED Headlights, anyone try these? |
You also need the round 7" lens holders and retaining rings. There are two square grill tabs that need to have their rivets drilled out so they can be removed from the body. Then you need to splice in the proper plugs for the lights. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Feb 20, 2018 7:19 pm Post subject: Re: LED Headlights, anyone try these? |
WestyWanter wrote: |
Once you do what Zeitgeist said, its plug and run them. 10 mins is all it took me. Thats including removing and re-installing the grill _________________ 1981 Vanagon Westfalia
2016 Passat TSI |
jimf909 Samba Member
Posted: Tue Feb 20, 2018 7:48 pm Post subject: Re: LED Headlights, anyone try these? |
MichaelCampingInVA wrote: |
dobryan wrote: |
[img]
[/img] |
My first reaction to this photo is that the headlights are aimed high. Knowing the car was isn’t level helps but it’d be interesting to know how they’re aimed using the Daniel stern aiming instructions. _________________ - Jim
Abscate wrote: |
Posted: Tue Feb 20, 2018 9:57 pm Post subject: Re: LED Headlights, anyone try these? |
For the '85 and earlier with the 7" round headlights it is a 10 minute swap that is as easy as swapping the two stock headlights. The wiring connection on the new replacement headlights is correct. No mods, no splicing.
For the '86+ that have the square headlights it is a bit more involved as Zeitgeist13 mentioned.
The headlights I got also came with two pigtail adapters to adapt to an oval connector (h13) which is not correct for the later vanagon, but the adapters provide the correct connectors which could be used for splicing into the late van. Like this:
Ride_On Samba Member
Joined: August 27, 2015 Posts: 385 Location: Ottawa, Canada
Posted: Wed Feb 21, 2018 8:44 am Post subject: Re: LED Headlights, anyone try these? |
Bit of a cross-forum post, but we have a 77 Bay Window and converted from stock 7" round headlights to 7" LED units - Truck-Lite 27027C. Massive difference. I love them. They aren't budget lights, but have/are coming down in price too.
It really is a night and day difference - far brighter, great light spread, excellent beam cut-off, and the high beams - oh the high beams!! Cannons of light. I can see so much more so much better. Ditches? Before, they were dark. Now, illuminated. Much easier to see critters, etc.
Install? I did it in a parking lot at night. 20 minutes as I was being careful and had never delved into the light assemblies on the bus. So easy.
Highly recommend the upgrade... great to see folks sharing pics and experiences of the budget lights too - seems like some good options available. _________________ 1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG) |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Wed Feb 21, 2018 10:25 am Post subject: Re: LED Headlights, anyone try these? |
Also curious to know if anyone has tried these rectangular ones and if so, what kinda results can be expected and what mods are needed. I have the GW HP relay kit that I had planned on installing in the coming weeks, but if this is an even better (brighter) option, I could be swayed.... Thx. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Wed Feb 21, 2018 10:46 am Post subject: Re: LED Headlights, anyone try these? |
coqwesty wrote: |
I have not tried them but suspect based on the lumen rating that they are not even as bright as the stock headlights. For perspective, the 7" rounds that I installed have 3.5X the lumen output of those on low beam and 5X the lumen output on high beams. The pair I bought cost less than one of those. Even after buying the round grill and buckets, you still might come out ahead for cost. The rounds also look a lot better than the square headlights. |
Posted: Wed Feb 21, 2018 11:10 am Post subject: Re: LED Headlights, anyone try these? |
?Waldo? wrote: |
coqwesty wrote: |
Perfect - many thanks. I will proceed with the GW relay for now and continue to 'monitor' the LED landscape as quality continues to increase and prices continue to decrease. |
Posted: Mon Feb 26, 2018 10:56 am Post subject: Re: LED Headlights, anyone try these? |
I got the headlights adjusted per the Daniel Stern aiming instructions posted above. It was very easy to adjust. I aimed them a little lower than specified simply because mine are so bright. At this point I couldn't be more pleased with the upgrade. The lighting is fantastic on low or high beams. Excellent clear even light. The bang for buck on this upgrade is really remarkable. The quality of light went from horrible (stock) to the best of any car I've driven with a cost below $100, 10 minutes of install, and 15 minutes of adjustment. Highly recommended. |
heidi85ho Samba Member
Joined: October 17, 2009 Posts: 298 Location: Williamsburg,Virginia
Posted: Mon Feb 26, 2018 11:26 am Post subject: Re: LED Headlights, anyone try these? |
Waldo........yes they are remarkable for under $100. I have had them in now for close to a year and no issues...fingers crossed. _________________ 85 westy-1.9-standard trans, FAS GenV 2.0 |
