Manx Lee Samba Member
Posted: Thu Oct 25, 2012 12:50 pm Post subject: Duguda's Manx II build |
found a manx II Thanks MSstevens!!!
JiI Samba Member
Joined: February 18, 2006 Posts: 1845 Location: Michigan
Posted: Thu Oct 25, 2012 8:29 pm Post subject: |
I have an identical body. Lots of room in the rear for tall tires. I should sell mine though....
Jeff |
frizzardking Samba Member
Joined: May 09, 2011 Posts: 575 Location: BUFFALO N.Y
Posted: Fri Oct 26, 2012 5:44 pm Post subject: frizzardking-manx classic & manx 2 |
Well welcome to the buggy world ; you should join the manx club you can have any type of buggy ; go to meyers manx. Com
And good luck! |
Posted: Fri Oct 26, 2012 5:45 pm Post subject: frizzardking-manx classic & manx 2 |
And good luck! |
Bob Elgin Samba Member
Posted: Sat Oct 27, 2012 2:32 pm Post subject: |
Thanks Frizzard and Bob i will check it out
Posted: Sat Oct 27, 2012 2:37 pm Post subject: |
Bob Elgin wrote: |
got one myself, check my build at my spatz rebuild/refresh. or click the link at the bottom of my post |
Looks great Bob how did you attach the hood to the body? |
Posted: Sat Oct 27, 2012 3:07 pm Post subject: |
i mentioned earlier that a IRS pan came with my buggy upon closer inspection i decided to use a donor with a title and alot of the missing pieces
Posted: Thu Nov 01, 2012 3:47 pm Post subject: |
I will be removing the lift kit
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Thu Nov 01, 2012 4:25 pm Post subject: |
Duguda Duguda wrote: |
and new engine
Type 4, Bus motor - what size/engine code?
http://www.thesamba.com/vw/archives/info/engine_letters.php
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Thu Nov 01, 2012 5:14 pm Post subject: |
going with a Corvair power plant
Posted: Thu Nov 01, 2012 6:36 pm Post subject: |
Is the engine a runner? Any history on it? You've probably read about the T4 issues with valve seats & head cracks?
Pulled a compression check on it yet?
Posted: Thu Nov 01, 2012 6:58 pm Post subject: |
no compression test, but the van did run and drive good except the ton of Rust that it had....which is why it was parted out.. UPDATE I decided to use a corvair engine
Posted: Wed Jul 03, 2013 7:26 pm Post subject: |
found a manx 2 so I will be building that instead!
Posted: Tue Jul 16, 2013 7:10 pm Post subject: |
Posted: Sat Jul 27, 2013 1:00 pm Post subject: |
finally home !
Posted: Sat Jul 27, 2013 7:10 pm Post subject: |
sorry been busy , just getting back to normal.
I built a inch and half angel iron(square of course) and also put a rubber pad around the inside of the angel iron, so it wont rub a hole in the tank. As far as the neck i went to u pic um parts and took the gas filler tube and flange from a chevy s10, cut it to the length then mounted the gas cap to the flange.
The gas tank angel iron is adhered to the firewall and also the flat part of the pan,
_________________ OLD ENOUGH TO KNOW BETTER AND STILL TO YOUNG TO CARE!!!!!
My Build http://www.thesamba.com/vw/forum/viewtopic.php?p=5987690#5987690
My Youtube page
https://www.youtube.com/channel/UCqd2r1Af7uZgqlnxAtMap4A |
Posted: Wed Jul 31, 2013 4:16 pm Post subject: |
ok Thanks Bob!
I was doing a search for seats for buggies and I came across these :
they are a from a 71 Opel GT I measured them and it looks like they would it work they are 32 inches from the ground 30 off the front of the seat..
What do you guys think? I would be changing the interior color to black |
Rathbone Samba Member
Joined: February 25, 2006 Posts: 235 Location: Palm Coast, Florida
Posted: Wed Jul 31, 2013 5:52 pm Post subject: |
They're cool! Very vintage. _________________ (o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal |
Posted: Thu Aug 22, 2013 4:29 pm Post subject: Manx 1 build |
getting some fiber glassing done on the rear and front I have quite a bit work
to do but I am getting there.
