heidi85ho Samba Member
Joined: October 17, 2009 Posts: 298 Location: Williamsburg,Virginia
Posted: Thu Jan 11, 2018 6:08 am Post subject: Re: 1983 1.9L will not start after sitting a week in the cold |
Bringing it back to the top.
Any resolution to this? _________________ 85 westy-1.9-standard trans, FAS GenV 2.0 |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4791 Location: Bemidji, MN
Posted: Thu Jan 11, 2018 9:32 am Post subject: Re: 1983 1.9L will not start after sitting a week in the cold |
just fyi, there's lots of reasons why a fuel system will depressurize before you are able to pull the injectors to look for drips. it really has to be done with the injectors already out and the pump forced on. ideally with a pressure gauge attached at the port too so you KNOW the injectors are under the correct pressure.
-dan |
highsierra Samba Member
Posted: Fri Jan 19, 2018 3:08 pm Post subject: Re: 1983 1.9L will not start after sitting a week in the cold |
shagginwagon83 wrote: |
My 1983.5 had problems starting. It would huff and puff and sometimes would turn over. Other times it worked great!
The problem turned out to be the Idle Control Unit. Tried bypassing the unit and it fired right up! Haven't had any issues in over 8 months.
It wouldn't hurt to try! |
I had the same experience in my early '84. Easy to check and cheap to replace if necessary. |
Posted: Fri Jan 19, 2018 4:33 pm Post subject: Re: 1983 1.9L will not start after sitting a week in the cold |
Adding the Vanagon Syndrome capacitor will smooth the idle and make the digital idle control pretty much unnecessary. I probably bypassed mine at least 8 years ago and have never had a problem since. Adding the Digifant orifice to the breather hose will also improve the idle. |
