Busstom Samba Member
Joined: November 23, 2014 Posts: 3854 Location: San Jose, CA
Posted: Tue Jan 02, 2018 1:29 am Post subject: Need help deciphering numbers for a '66 'vert... |
I need help determining if a buddy's '66 convertible has the original engine. I'm confused by the tables of available info in the technical section, so we're hoping some experts can shed light.
The VIN plate number is 156350138, and the engine number is 0173846. If it's not the original case, it certainly appears to have all the original components bolted to it. But the VINs and engine numbers in the technical archives don't even seem close.
Or is it that we need to be referencing the "chassis" number off the pan to correlate with the engine numbers from the table??
Thanks for any assistance!
Edit: from type2.com, perhaps a '64 Bus 1500 with no cam bearings? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Tue Jan 02, 2018 7:04 am Post subject: Re: Need help deciphering numbers for a '66 'vert... |
A 1966 engine would originally have been a 1300cc engine with a number starting with "F". Sounds like a 1200cc engine is in there. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Jan 02, 2018 7:25 am Post subject: Re: Need help deciphering numbers for a '66 'vert... |
Pan and body numbers “should” match. The engine does appear to have started life as a 1500 based on the number. Good chance it’s a 1600 since from my understanding 1500 pistons have been NLA for awhile. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Tue Jan 02, 2018 8:08 am Post subject: Re: Need help deciphering numbers for a '66 'vert... |
No, that's an early 1500 block it sounds like. Assuming the engine number is under the generator stand, it would have come out of a type 2. Not really common to see those blocks re-used that much, they usually got pretty hammered by normal usage in Tranporters. _________________ Andy T.
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Tue Jan 02, 2018 2:38 pm Post subject: Re: Need help deciphering numbers for a '66 'vert... |
Thanks everybody. If this engine is good (and it's believed to be), it might even be of some added value to someone restoring a '63 Bus...but that will be for the next owner to assess.
This car has been mothballed for a coupe decades, and since the owner also has a '78 'vert and my old '68 'vert, he's going to part ways.
We have no reason to believe that the pan and body don't match, but what still confuses me is that the table here (link below), under Beetle / VIN Chassis Numbers for 1966, doesn't list any chassis numbers starting with 15_, only 116 and 117, so it got me pondering whether convertible chassis numbers still carried the sedan format. Probably user error somewhere https://www.thesamba.com/vw/archives/info/bugchassisdating.php
The car is a couple hours away from me, and about 45 minutes away from the current owner, so the VIN matching is delayed...but once it's road-worthy, it's going on sale. |
67ctbug Samba Member
Posted: Tue Jan 02, 2018 3:00 pm Post subject: Re: Need help deciphering numbers for a '66 'vert... |
Yes they use the same format. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Posted: Wed Jan 03, 2018 2:04 pm Post subject: Re: Need help deciphering numbers for a '66 'vert... |
Okay, thanks. I probably should've said "sequence."
So simply substitute the second '1' with a '5' (for convertible), and the remaining chassis numbers fall in line with the running sequence for ALL sedans of the given year...right? Okay
Posted: Wed Jan 03, 2018 4:58 pm Post subject: Re: Need help deciphering numbers for a '66 'vert... |
That's correct. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Jan 03, 2018 10:19 pm Post subject: Re: Need help deciphering numbers for a '66 'vert... |
Yes, and it sort of says that at the top of the VIN page where it says they are prefixed by the model # from 1965-onward but maybe it's not as clear as it could be...
I'm totally open to new text if what is there is confusing.
If you have some input, PM me so I don't miss anything posted here in a thread _________________ How to Post Photos
Posted: Thu Jan 04, 2018 1:31 am Post subject: Re: Need help deciphering numbers for a '66 'vert... |
I appreciate your willingness to amend the preface info. After re-reading it and understanding it now, I do have an idea that may clarify the statement. I'll send you a PM. |
