SOS
Page: 1, 2, 3  Next
TravelingInAFriedOutKombi
TravelingInAFriedOutKombi is offline
PostPosted: Tue Jan 02, 2018 12:26 pm    Post subject: SOS Reply with quote
Is my fuel pump toast?
Drove her a couple hundred miles, then noticed the oil pressure light would flicker when on any sort of incline, downhill or uphill. And, if I didn't give it some gas, she would stall.
Now after a couple days of this, after I parked her, I could here a ticking sound coming from underneath the rear drivers side panel, where the fuel pump is. Even after hours of her turned off and parked, this sound persisted. Went to start her this morning, battery is completely dead. And when I jump her and start her up, she shuts off if I'm not constantly giving it gas.
So, I'm assuming the fuel pump died, and for some reason wouldn't turn off, draining my battery dry. Am I accurate on this?
I am running the stock FI 1970cc engine.
SGKent Premium Member
SGKent is offline
PostPosted: Tue Jan 02, 2018 12:40 pm    Post subject: Re: SOS Reply with quote
sounds to me you are (were) low on oil, maybe gas tooso the pump was sucking air. True FI tanks have baffles in them to stop that sort of thing.
machine work recommendations: http://kentcomputer.com/77VW/machinework.pdf
Pointers on rebuilding an engine:
http://kentcomputer.com/77VW/rebuilding_a_vw_engine.pdf
Setting Engine Timing: http://kentcomputer.com/77VW/Timing.pdf
aeromech
aeromech is offline
Maybe your AFM door is stuck open?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
PostPosted: Tue Jan 02, 2018 1:25 pm    Post subject: Re: SOS Reply with quote
Oddly enough, I have too much oil, according to my dipstick. PO must have overfilled it. Could that be my issue?
PostPosted: Tue Jan 02, 2018 1:27 pm    Post subject: Re: SOS Reply with quote
AFM? Sorry....VERY new to this. I am no mechanic, but thought I could replace my fuel pump on my own with some online help.
aeromech
aeromech is offline
PostPosted: Tue Jan 02, 2018 1:52 pm    Post subject: Re: SOS Reply with quote
Sorry,
From what you described.... the ticking sound always being on and the battery going dead, I'd guess your fuel isn't shutting off like it should. I'm guessing that a stuck AFM (Airflow Meter) door might cause that. I could be wrong and the ignition switch might prevent the pump from running even with the door open.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
lil-jinx Premium Member
lil-jinx is online now
PostPosted: Tue Jan 02, 2018 1:58 pm    Post subject: Re: SOS Reply with quote
The over full oil may be from gas entering the crank case,from the pump running,the thinned out oil may also cause the pressure to drop,causing the light to come on.
Change the oil before running it again.
1968 Dune Buggy
1974 parts bus
aeromech
aeromech is offline
PostPosted: Tue Jan 02, 2018 2:03 pm    Post subject: Re: SOS Reply with quote
I think you'd need to have a leaky injector along with a fuel pump that doesn't turn off in order to dilute the crankcase oil.
Pull the dip stick and smell it for fuel
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent is offline
PostPosted: Tue Jan 02, 2018 2:24 pm    Post subject: Re: SOS Reply with quote
regardless - welcome, and 9 ft lbs max on the oil strainer nut if you remove it or engine damage will occur.
danfromsyr
danfromsyr is offline
PostPosted: Tue Jan 02, 2018 2:50 pm    Post subject: Re: SOS Reply with quote
while we'd all love to help you diagnoses this over the internet..
you have some GREAT VW resources in the SLC area that you should get familiar with.
I don't know any of them personally or by reputation so you'll have to do a little feeling them out..
tell them your story, and don't cheap out on their advice or expertise..
but
Bob's VW parts.. https://goo.gl/maps/hDCeaawdJXD2
Wayne's VW repair. https://goo.gl/maps/kJ2tncUWjWu
Vanagon List Archives
The only cheap thing in a classic VW sits behind the steering wheel
THE List ala Sanchius
syncroserge wrote:
The way these vans have shaped and enriched our family life would make one believe these darn things have a soul Cool
PostPosted: Tue Jan 02, 2018 11:35 pm    Post subject: Re: SOS Reply with quote
Thank you all for your detailed replies- I truly appreciate it! Since I have no idea what the hell I'm doing, I think it's wise to let a local expert have a peek at what's going on.
@danfromsyr- Thursday I'll be towing her to a shop in Orem. UT (Vintage German Motors) that all the local guys seem to rave about. I'll be sure to update the post when I find out the diagnosis.
Thanks again! White Bay Bus
SGKent is offline
PostPosted: Wed Jan 03, 2018 8:06 am    Post subject: Re: SOS Reply with quote
tow rear wheels first or disconnect the axles. or flat bed. More than one person here has had an engine destroyed when the trans slipped into 1st at 55 mph.
PostPosted: Wed Jan 03, 2018 4:32 pm    Post subject: Re: SOS Reply with quote
Yikes! I'm just going to play it safe and flat bed her.
SGKent is offline
PostPosted: Wed Jan 03, 2018 4:36 pm    Post subject: Re: SOS Reply with quote
best way. no low overhangs Smile
PostPosted: Thu Jan 04, 2018 2:44 pm    Post subject: Re: SOS Reply with quote
The dipstick smelled like I had pulled it directly out of gasoline. Sad
Spike0180
Spike0180 is offline
PostPosted: Thu Jan 04, 2018 2:50 pm    Post subject: Re: SOS Reply with quote
Change your oil. Check your float.
Work Horse: 2003 Ford F150 (XLT - 2wd 4.6L V8 )
Air-cooled: 1970 VW Transporter
Engine: 1776cc DP
Current State: Projects never truly end...
aeromech
aeromech is offline
PostPosted: Thu Jan 04, 2018 3:04 pm    Post subject: Re: SOS Reply with quote
That's the strange part. It doesn't have a float, it's fuel injected. Injectors are powered open so even with the fuel pump running somehow, the injectors should keep the fuel from flooding the crank case.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Spike0180
PostPosted: Thu Jan 04, 2018 3:08 pm    Post subject: Re: SOS Reply with quote
Sorry, missed that (kinda just jumped in on this)
If an injector is stuck open (debris?) then it would leak down the pressure in the system into the cylinder/case. (that rail stays pressurized for some time after the engine is shut off.)
Engine: 1776cc DP
aeromech
aeromech is offline
PostPosted: Thu Jan 04, 2018 3:19 pm    Post subject: Re: SOS Reply with quote
Yep, a leaky injector would cause a lot of problems. Running problems as well as flooding problems.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
PostPosted: Thu Jan 04, 2018 4:05 pm    Post subject: Re: SOS Reply with quote
Got to wonder if the running pump and the open injector are related to the same electric problem/s,same power going to both the pump and injectors
1968 Dune Buggy
1974 parts bus
Page: 1, 2, 3  Next
