Need Ideas
Page: 1, 2, 3  Next
Sharp64 Premium Member
Sharp64 is offline
PostPosted: Tue Jan 02, 2018 5:52 pm    Post subject: Need Ideas Reply with quote
I decided that I want to make the dune buggy a semi permanent two seater so I moved the tank to the area behind the seats. Unfortunately I now have some holes that need to somehow be covered. I had considered cutting a piece of sandpaper tread and putting it over the area but then started thinking a third brake light would be nice if I could find one but enough to cover the area. I tried searching by size but can’t seem to find any sold by size. Does anyone know of a third brake light that is this large? Approx 12x5”.
Any other ideas are welcome.
* please no lectures about putting the tank up front.
1964 Type1 Sedan (Harvey)
2013 JSW
2014 New Beetle (Wife's)
Manx Clone (Bert)
1960 Indigo Blue Ragtop (Blue Barry)
“The sky is falling the sky is falling” - Chicken Little
Dale M.
Dale M. is offline
PostPosted: Tue Jan 02, 2018 9:04 pm    Post subject: Re: Need Ideas Reply with quote
Not sure about big hole but the 4 small ones could be filled with "button head" screws to look like it supported something under body...
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
“Don’t be intimidated by what you don’t know. That can be your greatest strength and ensure that you do things differently from everyone else.” ~ Sara Blakely
jspbtown
jspbtown is offline
PostPosted: Tue Jan 02, 2018 9:16 pm    Post subject: Re: Need Ideas Reply with quote
I would stroll through a wrecking yard. many trucks have roof mounted lights. Some mini-vans as well I think.
Sharp64 is offline
PostPosted: Tue Jan 02, 2018 9:46 pm    Post subject: Re: Need Ideas Reply with quote
This is kind of what I was thinking. Problem is a lot of the junk yards around here won’t let you wander around them for insurance reasons. I may keep a tape measure on me and stroll through a used truck lot to see if anything measures up. I had also thought about mounting a scoop over the holes and putting an LED bar inside.
2013 JSW
Manx Clone (Bert)
jspbtown
jspbtown is offline
PostPosted: Wed Jan 03, 2018 8:00 am    Post subject: Re: Need Ideas Reply with quote
Fiberglass is VERY easy to work with.
You can take a couple of cans of expanding foam, spray it in a heap on some cardboard and then shape it when it dries. Lay some glass over the foam and when the glass dries scrape out and place the light of your choosing in it.
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Wed Jan 03, 2018 8:38 am    Post subject: Re: Need Ideas Reply with quote
I like the scoop idea - I'd add LED back up lights along with a 3rd brake light. How about an VW bug engine lid license plate light? Or at least use that to mold one in fiberglass.
https://www.ebay.com/itm/Vintage-VW-Bug-Deck-Lid-E...0005.m1851
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
vponder
vponder is offline
PostPosted: Wed Jan 03, 2018 10:42 am    Post subject: Re: Need Ideas Reply with quote
If its flat there (cant tell) might get a piece of diamond plate to cover and use some nice bolts like Dale showed. But sometime diamond plate is over done on things .
Sharp64 is offline
PostPosted: Wed Jan 03, 2018 11:10 am    Post subject: Re: Need Ideas Reply with quote
It’s pretty curvy and not really a diamond plate fan.
2013 JSW
Manx Clone (Bert)
TSFR
TSFR is online now
PostPosted: Wed Jan 03, 2018 11:12 am    Post subject: Re: Need Ideas Reply with quote
What was there before?
Thanks,
Jeff
Manxter 2+2 #160
Sharp64 is offline
PostPosted: Wed Jan 03, 2018 11:15 am    Post subject: Re: Need Ideas Reply with quote
The fuel tank. Small holes were for the straps, large was for the fitting to go through. PO work, not mine.
2013 JSW
Manx Clone (Bert)
TSFR
TSFR is online now
PostPosted: Wed Jan 03, 2018 11:21 am    Post subject: Re: Need Ideas Reply with quote
That makes sense now. Maybe if you can fab up some kind of stainless steel polished spoiler/lip that follows the existing tail? Or a new license plate bracket.
Thanks,
Jeff
Manxter 2+2 #160
Sharp64 is offline
PostPosted: Wed Jan 03, 2018 11:27 am    Post subject: Re: Need Ideas Reply with quote
I had thought about a piece of stainless or aluminum as an “accent” piece. Eventual plan will be to glass it in and repaint but I’m not there and don’t like driving around with crappy looking holes in the body. Maybe I could practice my glassing skills and spray the area in a silver stripe of some sort....
2013 JSW
Manx Clone (Bert)
Dale M.
Dale M. is offline
PostPosted: Wed Jan 03, 2018 11:43 am    Post subject: Re: Need Ideas Reply with quote
That would work.... Its far enough away from flames in front so even close match of paint would be ok....
Dale
andk5591 Premium Member
andk5591 is offline
PostPosted: Wed Jan 03, 2018 12:38 pm    Post subject: Re: Need Ideas Reply with quote
Great place for a third brake light.....get a motorcycle turn signal and you can get various color LED bulbs.....Also look at "big Rig" lighting.....
D-Dubya Manx clone - 63 Short pan,1914.
Max - 73 standard Beetle hearse project
There's more, but not keeping them...
EMPIImp69
EMPIImp69 is offline
PostPosted: Wed Jan 03, 2018 1:06 pm    Post subject: Re: Need Ideas Reply with quote
That's a nice looking buggy, I can't believe someone mounted the tank all the way in the back like that. Why not put a VW style tank under the hood where it belongs?
1969 Empi Imp #1325
1963 Ragtop Bug
Use this to balance your wide 5 steelies -->
http://www.thesamba.com/vw/classifieds/detail.php?id=1830990
GS guy
GS guy is offline
PostPosted: Wed Jan 03, 2018 2:26 pm    Post subject: Re: Need Ideas Reply with quote
Might also try to carefully 'glass in the holes, sand smooth/flush on top then cover the upper surface of the "spoiler" with a vinyl wrap material like an accent panel - carbon fiber? wood-grain?? semi-flat black?
You'd have to get the finish near "paint ready", but would avoid having to match the existing color.
Jeff
70's vintage Deserter GS buggy - undergoing transformation to Super GS!
Sharp64 is offline
PostPosted: Wed Jan 03, 2018 4:08 pm    Post subject: Re: Need Ideas Reply with quote
Thanks. I’ll post up some better pics soon. I’ve made some “upgrades” since these pics. As for the tank, someone glassed it in. Cutting it open would mean bodywork, paint etc. Maybe after. Year or so of having it I’ll take it off the road and redo the bodywork and paint.
2013 JSW
Manx Clone (Bert)
Sharp64 is offline
PostPosted: Wed Jan 03, 2018 4:25 pm    Post subject: Re: Need Ideas Reply with quote
Jeff
Yeah a possibility. Some form of silver or carbon fiber would be cool.
2013 JSW
Manx Clone (Bert)
cbeck
cbeck is offline
PostPosted: Wed Jan 03, 2018 7:40 pm    Post subject: Re: Need Ideas Reply with quote
Made my roof panels out of lexan. You can heat, bend, glue, sand, and paint. I also bought 4 12"led strips off of fleabay delivered for $6.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
andygere
andygere is offline
PostPosted: Wed Jan 03, 2018 8:28 pm    Post subject: Re: Need Ideas Reply with quote
Repair the holes properly, then carry the hood flames back over the spoiler. Anything else will look like an attempt to hide an ugly hole on an otherwise very nice buggy.
Page: 1, 2, 3  Next
