Kjb13 Samba Member
Posted: Wed Jan 03, 2018 5:36 pm Post subject: Steering wheel help |
I would like to install an aftermarket steering wheel in my '72 standard bug. I'm looking for help to determine what combination of adapter, spacer and dish depth would put the wheel at approximately the same position as the factory wheel. If anybody has done this or knows what might work, I would be VERY thankful for your input. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5600 Location: 37.5N 77.1W
Posted: Fri Jan 05, 2018 9:20 am Post subject: Re: Steering wheel help |
the problem you are going to run into is the 'dish' of the new steering wheel. I put a grant steering wheel on a '69 and had to use a 3" 'spacer' because of the 'flatness' or lack of 'dish' the wheel has. My knuckles were still close to the turn signal stalk. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Kjb13 Samba Member
Posted: Fri Jan 05, 2018 11:43 am Post subject: Re: Steering wheel help |
The distance from the top of the steering column housing to the rim of the wheel is about 5". If I use a spacer and dish combo that is about 5", I should be okay with the signal and wiper stalks. I was just hoping that someone could verify this from experience. |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Sat Jan 06, 2018 5:44 am Post subject: Re: Steering wheel help |
I've got a Grant wheel in mine, more specifically this one here:
http://www.grantproducts.com/products/view/7/
It has about a 3-1/2" to 3-3/4" dish, plus the inch or so for the adapter kit. I had no problems with the distance to the signal levers. Or rather, no problem until I installed a quick-release mechanism that kicked the wheel out by about 2 inches or so, and had to mod some flappy paddles to the levers.
Interestingly enough, I just did a little write-up about here a couple days ago:
https://www.thesamba.com/vw/forum/viewtopic.php?t=691895&highlight=
Good luck, man. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Kjb13 Samba Member
Posted: Sat Jan 06, 2018 1:11 pm Post subject: Re: Steering wheel help |
Floating VW, I have seen your thread and I have to say those paddles are a work of art. Did you notice much of a difference in the steering with a smaller wheel?
Thanks for you input. |
allenw Samba Member
Joined: September 20, 2016 Posts: 221 Location: Dalton, GA
Posted: Sat Jan 06, 2018 6:16 pm Post subject: Re: Steering wheel help |
I have a 13 inch grant and it is a little tougher to steer but it does help workout the pecs. The only other problem with the 13 inch is it blocks the top of the speedometer. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Sat Jan 06, 2018 6:30 pm Post subject: Re: Steering wheel help |
They made the wheel 15" for a reason. So unless you have rally large thighs.... get a 15" wheel. _________________ Glenn
Member #1009
#BlueSquare |
Kjb13 Samba Member
Posted: Sun Jan 07, 2018 5:38 am Post subject: Re: Steering wheel help |
I do plan on using a 15 inch wheel. I just wanted to verify that a wheel with about a 3.5" dish would allow enough clearance for the stalks.
Thanks for all of the replies. |
Posted: Sun Jan 07, 2018 6:32 am Post subject: Re: Steering wheel help |
Quote: |
I have a 13 inch grant |
I have one too. No problem with steering even with a pair of 205/60-15 tires on the front.
Posted: Sun Jan 07, 2018 8:47 am Post subject: Re: Steering wheel help |
Kjb13 wrote: |
Thanks for the compliments.
I personally can't say I've noticed any difference in the steering. In fact, I'm always impressed with how light and responsive the steering is in my 45 year-old machine. The wheel is only a fraction smaller than stock, anyway, so the difference is very marginal.
Hell, people used to slap 10" steering wheels onto their full-bodied Beetles back in the day, so 13-1/2" shouldn't be a problem. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Kjb13 Samba Member
Posted: Sun Jan 07, 2018 4:25 pm Post subject: Re: Steering wheel help |
Definitely no 10" for me, but I may consider a 13.5".
Thanks |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Sun Jan 07, 2018 10:04 pm Post subject: Re: Steering wheel help |
Ugh, I'm with Glenn, in preferring stock diameter (which is closer to 16 than 15 inches, at 400mm, at least on the 60s Bugs I've had). Back when I was a mechanic, I rather hated driving customer's cars that had small steering wheels. _________________ Andy T.
Kjb13 Samba Member
Posted: Sun Jan 07, 2018 10:17 pm Post subject: Re: Steering wheel help |
Thanks for the input, Andy. |
Posted: Mon Jan 08, 2018 6:23 am Post subject: Re: Steering wheel help |
Chain links always provide a firm grip.
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Mon Jan 08, 2018 7:01 am Post subject: Re: Steering wheel help |
Just my comment on the install of a Grant 13" wheel on my '71 steering column (turn signal switch ONLY; no wiper switch)...
The effort to turn the wheel while stopped was noticeably higher, requiring pulling down hard on the steering wheel.
Turns while moving were not significantly impacted.
With the recommended Grant adapter for a '71 the turn signal lever cleared the wheel, barely. I could not keep my hands on the wheel as I turned the wheel... my fingers would contact the lever. An additional inch of clearance would have been nice. I had to re-learn how to turn while only holding the right side of the wheel, releasing the left side when my fingers approached the lever or reaching for the top of the wheel. With a larger diameter wheel (15") it might not be an issue. _________________ AshMan40
Ron G Samba Member
Joined: September 05, 2013 Posts: 228 Location: Albuquerque, NM
Posted: Thu Feb 08, 2018 7:08 pm Post subject: Re: Steering wheel help |
I’ve got a question guys, I got a 71 super I’m trying to put an aftermarket wheel on and the only problem I’m having is making the porn work because my wires do not come up through the center of the column Any ideas be greatly appreciated.Scratch my head a few times over this trying to figure out how to run the wiring. Because my horn button wire is attached to the turn signal switch. See photos wheel, hub, Turn signal switch. I am sure a new hub/spacer is in order with some type of ring with the wire coming up for the horn button.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Feb 08, 2018 7:33 pm Post subject: Re: Steering wheel help |
Making the porn work might require a picture of your porn button to see how it grounds against the wheel/hub. _________________
EverettB wrote: |
FU#5 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31361 Location: Hot Arizona
Posted: Thu Feb 08, 2018 10:32 pm Post subject: Re: Steering wheel help |
You need to get your hands on the contact ring that is installed on the underside of the steering wheel adapter. It is held in with a few screws.
This brass ring contacts the brass “ears” on the face of the turn signal switch and extends the horn ground path to the steering wheel. In ‘71 this brass ring would have been connected (electrically) to the steering wheel+steering shaft making them part of the horn circuit. Some brass rings (‘72-later?) come with a wire that would allow you to connect the ring directly to the aftermarket horn button and the steering wheel + shaft do not need to be part of the circuit.
The wire coming up from the steering box thru the steering shaft would be the ground path and be connected to the horn button. When you pressed the horn button you closed the contact between the ground wire and the steering wheel giving the horn a path to ground and the horn would sound.
Check if your steering shaft is grounded or not. If it is, then wire the horn contact ring to your horn button and let the button ground to the steering wheel when you press the button.
If the steering shaft is NOT grounded, run a wire down the steering shaft and ground it to the steering box bolt on the coupler. The top end of this wire connects to the horn button so that when you press your horn button the wire from the horn contact ring and the ground wire short together. Whether your horn button allows this directly (two terminals on the button) or you may need to wire the horn contact ring to the steering wheel itself and let the ground wire and steering wheel come together when you press the horn button. _________________ AshMan40
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Feb 09, 2018 2:09 am Post subject: Re: Steering wheel help |
I just have a big button on my dash for my horn lol. |
