ATTN: Check Your Power Steering Switch Wiring!!!
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Jan 05, 2018 11:32 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I recall a thread here on the 1.9 PS switch in regards to the boost valves.
Digijet "late version" P. 24.24b in Bentley makes reference to the PS switch.
Neil.
1981 Westy air cooled to 15º ABA swap: http://tinyurl.com/y9n4xob8
50º ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
teej
teej is offline
PostPosted: Sat Jan 06, 2018 4:51 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I just wanted to add a word of gratitude for threads like this. I added a 7.5A fuse a couple months ago to the suspect wire after reading about some of the incidents of smoked wires. I don't post a lot these days as others here are much more knowledgeable, but am always reading on here and learning more about these rigs and how to reinforce function and reliability.
1986+ Wolfsburg Weekender Pop-Top 2.1 WBX
djkeev Premium Member
djkeev is offline
PostPosted: Sat Jan 06, 2018 6:55 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
?Waldo? wrote:
Is the power steering switch unfused on the 1.9 Digijet? Is the same fuse location recommended?
My knowledge of the 1.9 is limited, but I'd study the wiring diagrams for a fuse in the fuel pump / fuel injection system. If one isn't shown, I sure would install one in the unfused feed wire!!
Dave
Ghia
Vanagon
Beetle
?Waldo?
?Waldo? is offline
PostPosted: Sat Jan 06, 2018 8:29 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
The 1.9's that came equipped with power steering have the pressure switch which controls an aux air valve to bump up the idle. I was hoping someone already knew whether or not the system was fused and if not, then whether or not the fuse should go in the same wire.
dhaavers
dhaavers is offline
PostPosted: Sat Jan 06, 2018 9:03 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Vanagon Nut wrote:
...Digijet "late version" P. 24.24b in Bentley makes reference to the PS switch...
Indeed. Of course, that page is only about the vacuum system layout, nothing electrical. The PS switch certainly
exists on the 1.9, but (as is not uncommon) Bentley's documentation keeps it shrouded in mystery...
<shrug>
Confused Rolling Eyes Evil or Very Mad
- Dave
86 White Westy Weekender
"The WonderVan"
Love My Westy
Love My Westy is offline
PostPosted: Sat Jan 06, 2018 10:45 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
My '86 Weekender does not have power steering. Are the wires still in place for PS that I need to check anyway? I know it is the original harness.
Love My Westy
PostPosted: Sat Jan 06, 2018 10:49 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I forgot to mention, it is a late '86 manufactured in July.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Jan 06, 2018 12:55 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
The 2 PS switch wires are part of the Digifant harness so I would expect them to be there. Good thing to check.
Mark
djkeev is offline
PostPosted: Sat Jan 06, 2018 1:05 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I would suggest that everyone install a 7.5 amp inline fuse for the fuel injection / fuel pump circuit.
It is cheap insurance warding off potentially big problems.
Keep in mind that If the fuse does blow, your engine shuts off.
But for me, better that than a fire!
Dave
Ghia
Vanagon
Beetle
Vanagon Nut
PostPosted: Sat Jan 06, 2018 1:20 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I was a bit vague. My WAG is that the PS switch on the 1.9 is wired somewhat separately, so to speak, of the main harnesses. However. The positive supply wire (from 15 buss?) to PS switch might have similar potential if a dead short happened? Like, it runs along in part of the main harness somewhere? I"m sure a voltmeter and flashlight would shed some light?
There's more unfused wires on a Vanagon than one might think. Personally, I think this all speaks towards install of a ground cut off at battery(ies) or fused link type wire on positive near batter(yes)
I wonder if someone makes a kit for an easy install, easy access ground switch?
Neil.
VE7TBN
SteveMc
SteveMc is offline
PostPosted: Sat Jan 06, 2018 1:59 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Dave
And mark up your Bentley wiring diagram for when your van dies and you forgot you installed a fuse.
1986 Transporter Single Cab Syncro
SlalomVan
SlalomVan is offline
PostPosted: Sat Jan 06, 2018 3:05 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
The exact same thing happened to me a while back! I was putting new belts on and making adjustments to the power steering hoses and I must have bumped the wires attached to the PS switch. Buttoned everything up and started the van up. Died immediately. Looked back and there was a puff of white smoke coming out of the driver's side vent. The harness was scorched all the way from where the PS switch wires entered the harness all the way into the box mounted on the drivers side of the engine compartment with the fuel pump/injection relays in it. Looking at where the wires were attached to the PS pump switch, the prongs were bent and touching one another causing them to short out. I figured that I must have bumped them when messing with the hoses. Sad
New (used) harness installed and everything works just fine! That is something I never want to do again.
Installing a fuse is a great idea! Until I do that, I am always making sure these wires are in good working order with the insulated connectors at the switch on tightly!
1989 Vanagon GL - 2.1 (White - "Northlake")
1988 Vanagon GL Wolfsburg (Orly Blue - "Poulsbo")
1989 Vanagon G - 2.1 (White - "Kingston") - Full rebuild underway - Last on the road in 1997
Paulbeard
Paulbeard is offline
PostPosted: Sat Jan 06, 2018 4:54 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
OK, this is on to-do my list, now that my van is safely home Cool
I think it's explained how 7.5A was arrived at but what would cause a short/blown fuse/sudden engine stop? It seems like most of the incidents are from the wires being bumped.
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
djkeev is offline
PostPosted: Sat Jan 06, 2018 5:18 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
The power feed to the fuel pump and fuel injection is interrupted if the fuse blows.
Dave
Ghia
Vanagon
Beetle
Paulbeard
PostPosted: Sat Jan 06, 2018 5:34 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
I get that but what would create the conditions to blow the fuse? Sounds like most of these cases are from old wiring getting bumped and causing a short. Are there other circumstances that would cause that?
I meant to have picked up the fuse holder and fuses today but I had another inconvenience to manage first. So now I will add an ignition switch to my list.
Git 'r DONE!
— dhaavers
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Sat Jan 06, 2018 5:46 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
well, i haven’t been hitting it too hard.
just kinda casually working on getting things sorted out.
here is the junction box end of the now repaired harness:
this loom contains the fuel pump relay power, coil power, tach lead, and wiring for oil pressure switches, temp gauge sender & coolant level sensor.
had to cut & solder the bullet connections from the old wires onto the new because i couldn’t find any locally. they’re all back in the multipoint connection now. i will wrap it with some split loom before install.
here is the old wiring harness removed from the van:
i also had to completely remove the junction box and repair the power lug that got so hot it melted out of its mount
everything is ready to go back in tomorrow.
71 Ghia - 88 Van - 87 Syncro Projecturewagon - 05 Passat Wagon TDI
dhaavers
dhaavers is offline
PostPosted: Sat Jan 06, 2018 6:22 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
^^^ Sweet...nice work.
Dave
Indeed. FWIW, Dave cleverly installed a clear fuse holder with a "glows-when-it-blows"-type fuse,
easily visible as soon as you open the engine bay. It's such a great idea, I did mine the same way... Cool
I ALSO insulated the PS switch connectors, so it's a real "belt & suspenders"-type fix.
Better this than pants-on-the-ground, or (worst case scenario) pants-on-fire...
Laughing Rolling Eyes Wink
- Dave
"The WonderVan"
kamzcab86
kamzcab86 is offline
PostPosted: Sat Jan 06, 2018 7:15 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Project finally done on my '90: Scratched the heat shrink plan and simply replaced the 90° connectors; also went with a clear fuse holder with glow-when-blows fuse (ironically, the only holders my PepBoys had).
I used a mini fuse. The extra mini fuse is packaged with an extra (giant) maxi fuse, which I converted the A/C fuse to... both are stored in the rear Westy cabinet for convenience. Very Happy
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
Michael4104
Michael4104 is offline
PostPosted: Sun Jan 07, 2018 11:45 am    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
Good job kamz 👍
1990 Wolfsburg Carat with new poptop.
1985 Westy now sporting a 1995 Jetta ABA 2.0L. Sold
dhaavers
dhaavers is offline
PostPosted: Sun Jan 07, 2018 12:18 pm    Post subject: Re: ATTN: Check Your Power Steering Switch Wiring!!! Reply with quote
^^^ FWIW: I ran the leads for the "glow" fuse holder out through the grommet
for easy visual from <outside> the junction box if/when necessary... Cool
(Sorry - no pic) Embarassed
- Dave
"The WonderVan"
Page 3 of 4
