samwise Samba Member
Joined: May 04, 2010 Posts: 611 Location: North Salt Lake, Utah
Posted: Thu Jan 04, 2018 5:29 pm Post subject: Best starter? |
So, of all the current options, including FLAPS, what is the best option for a new starter, including remanufactured, for my '79? _________________ Ben
1979 7-passenger bus
Harvee the Wonder Bus' pics |
Brian Samba Moderator
Posted: Thu Jan 04, 2018 5:31 pm Post subject: Re: Best starter? |
I've had good luck with Duralast from AutoZone. The O'Reiley's brand ain't that great. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
timvw7476 Samba Member
Posted: Thu Jan 04, 2018 6:04 pm Post subject: Re: Best starter? |
^at one point, one of those FLAPS sold rebuilt bus starters with two brushes
instead of four. That FLAPS wasn't Autozone. |
Bendejo Samba Member
Posted: Thu Jan 04, 2018 6:18 pm Post subject: Re: Best starter? |
I bought the tdi starter adaptor plate from bus depot and installed a self supporting starter from a Jetta. Solved my cranking noises. |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2068 Location: Ontario Canada
Posted: Thu Jan 04, 2018 6:19 pm Post subject: Re: Best starter? |
I'd try to find a shop to rebuild the original. Auto electric shops are getting rare though _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Thu Jan 04, 2018 6:24 pm Post subject: Re: Best starter? |
Bosch reman are good units from my experience. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Jan 04, 2018 6:43 pm Post subject: Re: Best starter? |
I THINK the late buses have the luxury of using the GoWesty gear reduction starter... Guaranteed to make your cranking issues and wallet disappear!
For the record, Genuine Bosch starters haven’t started to suck just yet. Get them while we can.....
www.airschooled.com |
musktchup Samba Member
Joined: November 30, 2004 Posts: 207 Location: Wilm. NC
Posted: Thu Jan 04, 2018 7:07 pm Post subject: Re: Best starter? |
hands down auto zone.
put mine on in 99' along with a hard start kit and has never been an issue since.
good torque and speed
Also has life time warranty. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6979 Location: Durango, CO
Posted: Thu Jan 04, 2018 7:15 pm Post subject: Re: Best starter? |
All the new Bosch starters I’ve seen in the last year or so have all been manufactured in Mexico and sound like shit. I’m currently running one from Autozone (lifetime warranty) with no issues and there’s an autozone in just about every town if you need to warranty it. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Danwvw Samba Member
Posted: Thu Jan 04, 2018 7:26 pm Post subject: Re: Best starter? |
Yeah, the ReMans all have problems but the Bosch SR-17X reMan is not too bad. These are very heavy duty starters too.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Thu Jan 04, 2018 7:42 pm Post subject: Re: Best starter? |
This was the last FLAPS starter I installed after three days of driving. Luckily it jammed into the flywheel and never came back, which only caused us to come skidding to a stop in the middle of an intersection, nothing unsafe or anything....
Robbie
EDIT: Don’t ever do this with a standard starter; only automatic starters have the self-supporting bushing to withstand a bench test like this. Standard starters must be tested installed in a transaxle. _________________ Learn how your vintage VW works. And why it doesn't!
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Thu Jan 04, 2018 8:01 pm Post subject: Re: Best starter? |
Bendejo wrote: |
Do you have pictures of this and or more info? Was it a bolt in situation and good to go? What year tdi motor? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Thu Jan 04, 2018 8:17 pm Post subject: Re: Best starter? |
Spike0180 wrote: |
Bendejo wrote: |
Do you have pictures of this and or more info? Was it a bolt in situation and good to go? What year tdi motor? |
Pretty straightforward, good instructions included with the adaptor. I couldn't find a tdi starter in the junkyard, so I ended up using a starter from a gas model 2.0 ABA engine, somewhat ironic as that is the same engine as what is in the bus now.
The stock starter always rattled after the high compression engine was installed but that's no longer an issue. |
Posted: Thu Jan 04, 2018 9:59 pm Post subject: Re: Best starter? |
Danwvw wrote: |
Fine for rigs with early bellhousing but will not work with the later 091 bellhousing.
For a '76 and later, I don't know if the 2.1L Vanagon starter will work, but suspect it would but have never tried it. This would be any easy way to pick up 33% more cranking power. The only potential problem is the clocking of the starter solenoid, at least TTBOMK.
FWIW, I am still running the same used starter I bolted up to my 74 when I installed an 091 tranny in it over 27 years ago. Since then, I have had new brushes installed twice IIRC and lubed the starter solenoid once. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Fri Jan 05, 2018 7:04 am Post subject: Re: Best starter? |
if you want NEW, STOCK and economical and are willing to goto a vanagon starter, the solenoid is clocked different.. and I'm unsure if it'll interfer with the gas tank? so look closely at both.
then there's a company having NEW starters made and rock auto has them for ~$70
http://www.rockauto.com/en/parts/power+select,17066N,starter+motor,4152
I've only been running 2 of them since May 2018.. one in my 1.8T vanagon and one in my 2.1 vanagon. YMMV
about power select http://powerselectparts.com/about-us
Quote: |
Power Select Professional Grade 100% New Starter
Technology in starting systems has advanced dramatically in automotive and powersports applications in recent years. The demand for starters that can provide reliable torque in any environmental condition increases each year. Automotive and powersports enthusiasts demand dependable starting power regardless of the conditions. Power Select Starters are designed to exceed the performance of the original starter in your vehicle or any remanufactured starter sold as a replacement.
Features & Benefits Include:
Consistent starting power with a high quality solenoid that properly engages the starter drive with the flywheel in your vehicle every time the ignition key is turned
High standards for components like wiring, brushes, insulation, bearings and coatings for consistent performance in all environmental conditions
High performance machining of the starter casing for ease of installation and solid joining of the starter housing and your vehicle's mounting surfaces
Dynamic design, innovative technology, and easy to install.
Power Select units incorporate many features to optimize wear resistance and deliver consistent performance, including OEM-Type Diodes on rectifier assemblies and welded diode to rectifier lead frame assembly
All products go through stringent validation processes before packaging and release to the market. Tests include:
Endurance Testing
Humidity Testing
Power Thermal Cycling
Vibration Tests
Salt Spray Tests
Power Thermal Cycle Tested from -40°C to 200°C to meet minimum of 5000 cycles.
Alternate/OEM Part Number(s): 025911023, 025911023A, 17066
POWER SELECT Warranty Information
12 months |
Quote: |
About Power Select
Feel like you are caught between the questionable quality of remanufactured and the high-cost of OE alternators and starters? Now you have a better solution, Power Select offers you 100% all new, true OE alternators & starters, at prices that will send the reman guys away with their hair on fire. Today, you can start your engines and keep those batteries charged with a premier name in alternators & starters. Power Select is your #1 choice for original equipment replacement alternators & starters.
Building automotive parts to exact OE specification is no easy task. OE certification requires strict adherence to stringent precision and performance criteria. These exacting criteria are applied in the manufacturing of all Power Select Alternators & Starters. Power Select replacement parts are engineered, quality built and 100% factory tested, under extreme operating conditions, before packaging and shipment to your parts supplier. |
Abscate wrote: |
Posted: Fri Jan 05, 2018 10:30 am Post subject: Re: Best starter? |
danfromsyr wrote: |
I've only been running 2 of them since May 2018.. one in my 1.8T vanagon and one in my 2.1 vanagon. YMMV |
Wow, did they come with a flux capacitor, too?
I'm going to try the screwdriver across the solenoid posts this weekend and see if it's just the solenoid first (a local AutoZone has a new solenoid in stock, according to the website).
If it still doesn't start, then I'll look into the other options - the rock auto one sounds good, and I've had decent experience with them. _________________ Ben
Posted: Fri Jan 05, 2018 10:36 am Post subject: Re: Best starter? |
hahah,, I know I'm always living in the past... _________________
Abscate wrote: |
Posted: Fri Jan 05, 2018 10:44 am Post subject: Re: Best starter? |
danfromsyr wrote: |
hahah,, I know I'm always living in the past... |
I thought your were predicting two starter failures over the coming year.
Living in the past would be writing 2006 on your checks. |
Posted: Thu Feb 15, 2018 1:04 pm Post subject: Re: Best starter? |
asiab3 wrote: |
Robbie |
Nope, GoWesty don't make one for the late Bay/early Vanagon standard transmission buses, just the automatics. They told me that they could do the automatics because they bellhousing on those was the same throughout the years, letting it cover a broader spectrum.
Too bad _________________ Ben
SGKent Samba Member
Posted: Thu Feb 15, 2018 1:17 pm Post subject: Re: Best starter? |
usually it is the solenoid. I prefer to keep the old starter if I know its history. we don't experience the expanded windings like larger block motors sometimes do. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
