VW T2b Jurgens Autovilla 1978
v6-star
v6-star is offline
PostPosted: Sun Jan 07, 2018 10:34 am    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Rhd to lhd Conversion
notchboy
notchboy is offline
PostPosted: Sun Jan 07, 2018 11:10 am    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Laughing You dont see that often. Usually its LHD to Rhd. Wink
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
TomWesty
TomWesty is offline
PostPosted: Sun Jan 07, 2018 11:18 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
I love the side cutters left in the foam on the roof! I worked with a guy that was always losing his tools like that. I was always finding his tools because I was taller than he was and would find them lying n top of cabinets. Cool
cliveawn
cliveawn is offline
PostPosted: Mon Jan 08, 2018 2:55 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Cool camper! I remember seeing them often while growing up in South Africa...fond memories of them.
good luck with the restoration!
Green 78 Westfalia Helsinki,
2056 with 41 x 34 valves,ported heads
Fully balanced
8,5:1CR
JPM Custom made cam
JPM 7075 dual taper pushrods
IDF 40's with 28mm venturi's
Python CSP 42mm exhaust.
115 HP
Daily driver 2017 Volvo V60 D5 hybrid
Rica stage 2 tune 345hp.
''Funny thing about common sense is that its not very common''
Seismic gun mechanic
orwell84
orwell84 is offline
PostPosted: Tue Jan 09, 2018 3:27 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
That is absolutely the coolest thing ever...absolutely hideous, but in the most compelling way. I recommend shag carpeting for every surface including the needle on the speedometer.
I was wondering if you had any photos of your bus without the campre walls on it. I am really curious as to what parts of the bus they cut out to make it. Thanks. I look forward to more of your updates.
v6-star
v6-star is offline
PostPosted: Wed Jan 10, 2018 4:03 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Hi.
In was a Panel Typ 21 with walk thrue, Long gearbox CP and 70PS CU Engine.
I will make puctures for you.
The rebuild to lhd is finished.
Last was the clutch pedal
v6-star
v6-star is offline
PostPosted: Wed Jan 10, 2018 4:21 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Hi.
telford dorr
telford dorr is offline
PostPosted: Wed Jan 10, 2018 9:13 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
How are you going to deal with ducting cooling air to and away from the engine?
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
v6-star
v6-star is offline
PostPosted: Thu Jan 11, 2018 12:00 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
I hope, the original scoops are enough
telford dorr
PostPosted: Thu Jan 11, 2018 5:31 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Well, the reason I mention it is, from the pics, it appears that the original engine is liquid cooled, and thus the cooling air only has to pass over radiators. Now, with air cooling, the cooling air has to be ducted to the fan input, and the waste air has to be prevented from reaching the fan. This is usually done by using a sheet metal barrier to separate the top half of the engine from the bottom half. Unless I'm not seeing it, the pictures currently show no such separation.
Just curious...
v6-star
v6-star is offline
PostPosted: Thu Jan 11, 2018 7:47 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
I think it is a original bay window engineroom?
telford dorr
PostPosted: Thu Jan 11, 2018 8:49 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
OK, from the new pics, it appears that you're correct. Disregard the question.
v6-star
v6-star is offline
PostPosted: Mon Jan 15, 2018 4:40 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Some Parts for the new Engine
94mm Pistons and Cylinder and a Web86 cam.
Two oil cooler
KentABQ Premium Member
KentABQ is offline
PostPosted: Mon Jan 15, 2018 4:49 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
That Autovilla is gonna be a head turner on the race track! Laughing
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
v6-star
v6-star is offline
PostPosted: Mon Jan 15, 2018 7:21 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
I hope so Laughing
v6-star
v6-star is offline
PostPosted: Sun Jan 21, 2018 3:29 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Today we picked up a 1976 Westfalia Trailer.
It stays exactly in Wiedenbrück, the Point of Westfalia.
1st hand, original manuel.
notchboy
notchboy is offline
PostPosted: Sun Jan 21, 2018 8:58 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Ooooooohhhhh nice find Cool
Can you make a good scan of that original paperwork?
1964 1500 S
busboy25
busboy25 is offline
PostPosted: Mon Jan 22, 2018 8:28 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
You don't see many rebuilds on these documented. That is great, in addition to actually doing the rebuilt.
I do have two questions.
Where are the fuel tanks hiding? I see that the dinette seems to occupying that space?
Is there any reinforcement to the under body/ chassis? I would wonder how they kept chassis rigidity when they removed the roof and side wall. I am assuming the camper body is fully wood structure.
I am sure I will have others if you will humor me. I see it as a goal of mine to build one of these someday.
76 Bay - 2056 Type four
v6-star
v6-star is offline
PostPosted: Wed Jan 24, 2018 6:15 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
Hi.
Thanks.
The Jurgens have 2 baywindow fueltanks.
Left and right in the engineroom complete in the back.
The floor pan is complete vw.
Jurgens put 3 tubes from left to right over the original floor pan.
You can see that in the next pictures.
On this tubes are a inner sill welded.
The wood floor is with screws on the floor and sill, the woodframe with screws on the sill.
Many nails.
On the roof corner is an alu profil from the windshield to the rear bumper.
v6-star
v6-star is offline
PostPosted: Wed Jan 24, 2018 6:17 pm    Post subject: Re: VW T2b Jurgens Autovilla 1978 Reply with quote
The left inner sill was rusty.
It is a selfmade new one.
Page 2 of 5
