dennis 356 Samba Member
Joined: January 09, 2009 Posts: 100 Location: Malmö, Sweden
Posted: Sat Jan 06, 2018 5:38 am Post subject: How to split a stubborn case? |
Can anyone give advice on how to split a very, very stubborn case (after the third piece has been removed of course)? Have checked numerous times for all the bolts being out, incl. the long one that goes through the block and of course don´t want to pry into it with anything sharp, so the only resort was a careful banging a little here and there with a wooden block inbetween, but that was naive, sits as a rock.
Is there some special tool (pressing?) available?
Dennis |
PD41 Samba Member
Joined: May 30, 2016 Posts: 109 Location: Redondo Beach
Posted: Sat Jan 06, 2018 7:47 pm Post subject: Re: How to split a stubborn case? |
Maybe try some heat to warm up the block (to soften the sealant)
A thin screwdriver at the top above the flywheel and a hammer.
Or try this guys method.
https://www.youtube.com/watch?v=jMP05Gtca38 |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Sat Jan 06, 2018 9:08 pm Post subject: Re: How to split a stubborn case? |
Did you take off the flywheel? _________________ Jack Staggs
Actual name |
Posted: Sun Jan 07, 2018 4:25 am Post subject: Re: How to split a stubborn case? |
I tried heating up the case, for the same reason you mention, but had only a hair drier and don´t think it generated enough heat.
I´ve seen that Youtube video and it was far too easy.
Posted: Sun Jan 07, 2018 4:28 am Post subject: Re: How to split a stubborn case? |
Jacks wrote: |
Did you take off the flywheel? |
Of course, its just a bare case with crank and rods inside.
Dennis |
ensys Samba Member
Joined: March 11, 2009 Posts: 322 Location: America's Automobile Heartland
Posted: Wed Jan 17, 2018 10:21 pm Post subject: Re: How to split a stubborn case? |
Mr. Dennis 356:
You should understand that among the reasons it may be difficult to separate the halves. it might be that the case has become deformed, which would produce the same result.
Proceed with caution. _________________ Keep 'em flying...
S.J.Szabo |
Posted: Thu Jan 18, 2018 5:44 am Post subject: Re: How to split a stubborn case? |
ensys wrote: |
Mr. Dennis 356:
Proceed with caution. |
Thanks for the heads up ensys. Checked the case and it doesn´t appear warped, problem is instead someone back in the day smudged on what appears far more glue than necessary and now it sits solid. But I´m going to device some simple expanding tools to place across the sump apperture, between the two sturdy studs bellow the flywheel and additional two studs threaded through the holes above the flywheel, would be surprised if that didn´t have any effect. At a same time knocking carefully on the case of course while expanding the tools. |
Starbucket Samba Member
Posted: Thu Jan 18, 2018 4:49 pm Post subject: Re: How to split a stubborn case? |
Look for a heat gun from a tool supply store or a tool rental company. They will get it hot e`nuff to soften the sealant. They are like a hair drier but so much hotter. |
Posted: Thu Jan 18, 2018 6:25 pm Post subject: Re: How to split a stubborn case? |
Starbucket wrote: |
Hi,
I have a heat gun in a garage out in the country side and am already planning to go there this upcomming weekend to get both the gun, a treaded rod, pipes and some hardware to fabricate the small expanders. |
Jacks Samba Member
Posted: Thu Jan 18, 2018 7:44 pm Post subject: Re: How to split a stubborn case? |
On early cases, the 6 main case bolts used copper sealing washers that can become deformed and lock on the threads. In those conditions, you will have to pry them off to separate the case halves. On later engines, a steel washer with a bevel on the back side to allow use of a small rubber sealing ring. The sealing rings can get forced in the stud bore, making the case stuck. Be sure to remove them before separating the halves.
Is there any movement at all? Just above the crankshaft gears on the split line of the case halves, there is a place where a screwdriver can be wedged in between two bosses to help start separation. Did you remove the two nuts behind the flywheel at the cam bore? No wavy washers stuck on any of the small studs? _________________ Jack Staggs
Actual name |
Posted: Thu Jan 18, 2018 8:09 pm Post subject: Re: How to split a stubborn case? |
Jacks wrote: |
Is there any movement at all? Just above the crankshaft gears on the split line of the case halves, there is a place where a screwdriver can be wedged in between two bosses to help start separation. Did you remove the two nuts behind the flywheel at the cam bore? No wavy washers stuck on any of the small studs? |
Jack,
This case is about 1960 with the bevelled washers and I made sure all are off, including the bolts/washers behind the flywheel. There´s no movement whatsoever in the case, but it is interesting what you pointed out about the spot for a screwdriver, will test tomorrow. Other than that I think when I´ll be done with those small expanding tools and placing them than in different spots on the case, it will give way.... |
Posted: Fri Jan 19, 2018 10:21 am Post subject: Re: How to split a stubborn case? |
[quote="dennis 356"]
Jacks wrote: |
Jack,
Odd Jack, went down to my cellar today to check the slot in the case for the screwdriver you´ve mentioned and there´s none. Have two 1960 cases (already split by others when I bought them) and both have them, so this one can´t be 1960 and maybe a couple of years up, but rather earlier (although still can´t say as the third piece wasn´t correct).
With the slot in place I can imagen it being relatively easy peasy to split it, to big help anyway......
Dennis
Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Mon Jan 22, 2018 2:36 pm Post subject: Re: How to split a stubborn case? |
I struggled with this last week as well. I'm a long time VW guy with my trusting oil pump case splitting tool that never fails me. I really wanted a reliable tool for 356 so I didn't have to go through all of the suggested voodoo I've read about on various posts. Long story short, I made a couple of really simple expansion tools with some threaded rod and bolted them to the case where the transmission bolts up. A little pressure to the expansion tools and a few taps on the case is all it took. Good luck. _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
Posted: Mon Jan 22, 2018 3:23 pm Post subject: Re: How to split a stubborn case? |
Envious wrote: |
I struggled with this last week as well. I'm a long time VW guy with my trusting oil pump case splitting tool that never fails me. I really wanted a reliable tool for 356 so I didn't have to go through all of the suggested voodoo I've read about on various posts. Long story short, I made a couple of really simple expansion tools with some threaded rod and bolted them to the case where the transmission bolts up. A little pressure to the expansion tools and a few taps on the case is all it took. Good luck. |
Thanks Envious, good to hear this approach works. I haven´t got around making the expansion tools yet, but will during this week. |
Posted: Sat Jan 27, 2018 4:30 am Post subject: Re: How to split a stubborn case? |
Case split now with the help of my little friends (see pics), easy and very effective without any need for tapping, prying, heating etc on the case.
After taken off the cam gear, it finally revealed the case being from 8/59 so there´s a clear transition in third pieces between 1959 and 1960 (case has later third piece), but surely many of you already knew that, I didnt.
Dennis
Posted: Sat Jan 27, 2018 8:06 am Post subject: Re: How to split a stubborn case? |
The correct sealant for the case split is Loctite 574 and will allow the splitting the case easy. |
Posted: Sat Jan 27, 2018 8:23 am Post subject: Re: How to split a stubborn case? |
Starbucket wrote: |
Thanks for the tips Starbucket, will use it when resealing again, but who knows how many handled the case over the years, not that I´m any pro either......
Dennis |
speedstahguy Samba Member
Joined: March 27, 2013 Posts: 17 Location: Massachusetts
Posted: Mon Feb 12, 2018 1:44 pm Post subject: Re: How to split a stubborn case? |
Doesn't work on a Porsche case. It's 3 pieces. _________________ 71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
Danwvw Samba Member
Posted: Mon Feb 12, 2018 2:16 pm Post subject: Re: How to split a stubborn case? |
Very Smart you made that too. My bet was on the cam bolts behind the flywheel though. I remember them on some engines. Not sure if VW did it too? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
