BUSBOSS Samba Member
Joined: January 21, 2009 Posts: 2161 Location: Northern California
Posted: Thu Jan 11, 2018 11:22 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
I'd be interested. _________________ All the redemption I can offer, girl, is beneath this dirty hood
1976 Westfalia
1970 Karmann Ghia Convertible (sold - but not forgotten) |
Hoody Samba Member
Posted: Fri Jan 12, 2018 1:17 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
Thanks Skils for clarifying. It is my contention that the original speaker that was mounted here was 70’s technology and basically garbage in this day and age. Speaker quality has come a long way since then. As Steve pointed out a professionally re-coned speaker is still a 70’s speaker. Period. Dual 3 1/2 inch speakers will not fit into a 5 inch area. Nor will they fit into the 6 3/4 inch area with an adapter. After lots of homework and deciding upon my new sterio set up....I was enlightened by Skills about actually using the original spot for the dash speaker to augment the rest of my set up. Therefore I put forth the idea of producing these. Jeffrey at BusOk has one but he won’t sell the bracket. I want to be able to choose the speaker. The choices are limited. That’s it...plain and simple. There are 2 companies that make dual voice coil 6 3/4” speakers that will fit this spot. If any of you audiophiles can enlighten me please feel free to do so. Because I think I wasted 4 hours the other day researching and speaking to experts about dash speakers. I am not the guy who is gonna put nuts and bolts through my dashboard. It was merely an idea and now I have the original one to reproduce. |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri Jan 12, 2018 7:22 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
in the early bays I use a 6x9 for the center speakers. late I use a 5" (I think) speaker.
by far, it is the best sounding solution, and way better than door or kick panel speakers. anyone that has been in my bus just can't believe what a quality speaker can do in that location _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Fri Jan 12, 2018 10:48 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
I have a 1977 VWoA AM/FM radio hooked up to the speaker which sounds fine.
I also have downward facing under dash speakers and rear units hooked up to a hidden amp with an Aux in. So a couple of audio options that are +/- decent.
I like the original speaker just for the sake of originality. _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
Magion Samba Member
Joined: February 15, 2016 Posts: 236 Location: Vancouver, BC
Posted: Fri Jan 12, 2018 11:30 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
I would buy one as well!
Just out of curiosity, i recently decided to replace the original speaker and it was simply mounted to dashboard by two screws that were visible from above. Pretty sure this is how the bus came originally. Why is it that some came with bracket and some did not? _________________ 1975 Westfalia in Brilliant Orange
1995 Westfalia in Caribbean Green |
Posted: Fri Jan 12, 2018 11:42 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
Think it was the dealer that was supplying the radio and speaker and some just put the screws through the speaker holes. That is how mine was originally set up as well. My original speaker had a 4-5 mm rim of pressed greyboard that sat between the metal speaker frame and the underside of the dash.
Maybe other dealers were a little better about using the bracket. My original paper cone was totally gone from early on. I like how the bracket has the cloth "screen" to protect from some debris and liquid as well. _________________ 1978 Sage Green P22 Westfalia
mserino Samba Member
Joined: December 24, 2016 Posts: 11 Location: Valencia Ca.
Posted: Tue Jul 21, 2020 9:40 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
I picked up a dual 3.5 dash mount bracket from fast fab but it did not have the rubber bumper mounts. Anyone know where to get some or at least the dimensions. I could make two fastfabonline.com |
Posted: Fri Aug 21, 2020 9:30 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
There is also the reproduction speaker mount sold by Bus-OK that looks similar to the original design
https://bus-ok.nl/Type2-bay-Speaker-complete-with-mounting-frame _________________ 1978 Sage Green P22 Westfalia
Okievanner Samba Member
Posted: Mon Dec 07, 2020 3:51 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
Does anyone know where to get the rubber bushings for the speaker bracket? I am needing a pair.
Thanks! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 07, 2020 3:59 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
Okievanner wrote: |
Thanks! |
Welcome!
I've never found a source myself, I've made substitutes by gluing a couple layers of inner tube folded around the end of the tab like a taco in the past that worked great. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
MaggieMay Samba Member
Joined: December 27, 2015 Posts: 41 Location: La jolla CA
Posted: Thu Jan 21, 2021 7:35 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
So did this part ever get reproduced?
There was talk of it.
I would be interested in one. |
EZ Gruv King of Plaid
Joined: December 10, 2002 Posts: 8544 Location: Las Vegas
Posted: Thu Jan 21, 2021 9:10 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
MaggieMay wrote: |
The speaker bracket? Look a few posts up for a link. _________________ Eric
1977 Deluxe Westfalia - 2.0L FI Type IV, Completely Original
Photographer for HotVWs, VolksWorld, AirMighty, VW Camper & Commercial, Hayburner, and more.
My Photography Page. |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2537 Location: Ocean Beach in Beautiful BLUE California
Posted: Thu Jan 21, 2021 9:34 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
OB Bus wrote: |
At 104 euro???? |
If you want one bad enough...
I found a good one in the classifieds a while back for a good price. They're out there if you watch for them. _________________ Eric
zwartePiets Samba Member
Joined: January 05, 2009 Posts: 58 Location: Austin Texas
Posted: Sat Jan 30, 2021 10:04 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
If anyone has one they can post measurements up I would appreciate it. They look fairly simple to make. |
SGKent Samba Member
Posted: Sat Jan 30, 2021 11:42 pm Post subject: Re: 69-79 Bay dash speaker mounting bracket |
Has anyone asked Ken Madsen what he might want for one? I bought a speaker and bracket from him a while back and it was reasonably priced. I sent the speaker out to be reconed which was the most expensive part. Then added a speaker cloth like what VW used. The whole thing complete like new came to about $105 as I recall when I was done. Still have it in a box safely stored away to sell with the bus when it goes so if anyone wants to add a factory radio they can and use a factory speaker. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jan 31, 2021 9:13 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
SGKent wrote: |
Has anyone asked Ken Madsen what he might want for one? I bought a speaker and bracket from him a while back and it was reasonably priced. I sent the speaker out to be reconed which was the most expensive part. Then added a speaker cloth like what VW used. The whole thing complete like new came to about $105 as I recall when I was done. Still have it in a box safely stored away to sell with the bus when it goes so if anyone wants to add a factory radio they can and use a factory speaker. |
I just replaced the old factory speaker with a modern dual-tweeter speaker from RetroSound; it was an exact fit. I did a 'how-to' write up in Volkswagen Camper & Commercial Magazine. _________________ Eric
sloans265 Samba Member
Posted: Wed Feb 03, 2021 10:31 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
https://www.thesamba.com/vw/classifieds/detail.php?id=2449300
I just listed this for sale Price is OBO. But I'm more than happy to take measurements for anybody wanting to make on e themselves _________________ 1970 Lotus White Panel
In search of any Pensacola Fla dealership items |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Thu Oct 14, 2021 6:32 am Post subject: Re: 69-79 Bay dash speaker mounting bracket |
Were you able to take measurements before you sold this off?
webwalker _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
BYeaton Samba Member
Joined: November 27, 2007 Posts: 362 Location: El Segundo
