Windows against scrapers?
avocado_tom
avocado_tom is offline
PostPosted: Sun Jan 07, 2018 5:27 pm    Post subject: Windows against scrapers? Reply with quote
All,
I'm putting the 914 I bought back together (it came "some assembly required", mostly with regards to trim and interior) and I'm trying to figure out if I'm putting the windows back together correctly.
I am assuming that the door window is supposed to be in contact with the outer portion of the scraper?
Thanks!
Avo
raygreenwood
raygreenwood is offline
PostPosted: Mon Jan 08, 2018 8:20 am    Post subject: Re: Windows against scrapers? Reply with quote
Yes....but bear in mind.....the windows can be in the correct position....and not be bearing against the scrapers...if the scrapers themselves are old and shot. Ray
avocado_tom
PostPosted: Mon Jan 08, 2018 5:39 pm    Post subject: Re: Windows against scrapers? Reply with quote
Thanks Ray. That was probably an inherent part of my question, so thanks for picking up on it. My windows aren't touching the scrapers, but the scrapers are totally old. That's probably more the issue than anything.
Cheers!
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Tue Jan 09, 2018 8:17 am    Post subject: Re: Windows against scrapers? Reply with quote
also keep in mind that the inner fuzzy and the outer fuzzy keep the window prone and from flopping around. Also if you have an early model without the felt in the vertical tracks, the guides glued to the window get loose and the front four rollers crunchy from lack of lubrication causing the window to flop a bit and make it hard to roll up and down
avocado_tom
PostPosted: Sat Jan 13, 2018 2:32 pm    Post subject: Re: Windows against scrapers? Reply with quote
That's super helpful to know. Thanks!
