Uncharted Territory: Adventures with a '78 Kombi
luvtheeluvbug
luvtheeluvbug is offline
PostPosted: Mon Jan 08, 2018 10:18 pm    Post subject: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Hi Samba,
I just recently acquired a very solid 1978 Kombi. As the title implies, Fuel Injection and anything post '71 is new to me. It's currently not running but it was a daily driver before being parked in 2010 due to a "miss" (I'll have to pester the previous owner as to the exact symptoms). I just finished clearing out the interior and vacuuming the spiderwebs out of the engine bay and undercarriage. I know better than to try and start a car on seven-year-old gas, let alone sucking it through the sensitive FI system but, luckily, the PO drained the tank before parking it. I just finished the first of many readings of the FI chapter in the Idiot manual and was a bit overwhelmed but I'm sure I get the hang of it.
I'll be on a parts run tomorrow and will be getting some parts for the bus. Other than the usual hoses, filters, points, plugs, coil, etc. required to awaken a sleeping classic, what other parts should I be picking up that might be specific to the FI system?
First priority is to get it running. After that, you can bet I'll be probing the forums for help on getting it smogged. Any other bits of advice or caution on my first Bay Window would be greatly appreciated!
Fahrvergnugen/ far-fair-gnu-ghen/ Description of a pleasurable sensation experienced when a car and it's driver are in mutual harmony; A unique driving experience; Pleasure; Satisfaction; A feeling experienced by Volkswagen drivers.
78BusGA
78BusGA is offline
PostPosted: Tue Jan 09, 2018 2:32 am    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Congrats on the acquisition!
I stole a '78 tin top myself, though mine had sat for 15 years. It was repair shop refreshed to make it trailerable but thats it.
For the FI situation, you can piece it all together yourself, though I saw I think in the English VW magazine a company there that sells a fill FI refresh kit with all the hoses, clamps and bits for about $110. The pieces were cut to measure, just remove and install.
There is also a thread somewhere about the vapor return hoses that all need checking and replacing as well, and in there is a good 2 dozen posts about Marine Valves to help curb fuel flow in case of emergencies.
Another thing you want to check before you run it is if the brake fluid has gone corrosive. Thats one of the main things I am going to have to deal with, though your situation might be luckier.
Also while you are there in the engine bay, check the vacuum line that goes to the brake system.
My 2 cents!
Keep them rollin'!
Tom H.
'72 Superbeetle (retired)
'78 Bus Standard
KentPS Premium Member
KentPS is offline
PostPosted: Tue Jan 09, 2018 3:29 am    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Here's a link to the best fuel,injection manual for your VW...
https://www.thesamba.com/vw/archives/manuals/afc_fi_training_troubleshooting_manual.php
It's a great source for understanding and troubleshooting the FI components. Much more informative than the idiot book.
Best of luck to you! Get it running and get to having fun with it! Dancing
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
Abscate Premium Member
Abscate is offline
PostPosted: Tue Jan 09, 2018 5:25 am    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Pull plugs, oil in cylinders, and turn over carefully with a wrench listening for expensive noises. Parked with a miss 8 years ago needs investigation of course
.ssS!
KentPS is offline
PostPosted: Tue Jan 09, 2018 6:45 am    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
I forgot to mention...
Be sure to buy fuel hose that is made for fuel injection. There's a few threads in here about one that holds up well to the high pressure and to ethanol-laced gas. The brand is Gates, but I don't remember the part number.
Edit: Found it... Gates 30R9.
-Kent-
luvtheeluvbug
PostPosted: Wed Jul 11, 2018 10:54 pm    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Alright, the beast (I should say banana) is running. However, it wouldn't run at low RPM and I need it to pass California SMOG so I chickened out and brought it over to the local Bosch expert to play with. So far, he's gotten it running well but he says it has the wrong distributor which is causing the timing to be off and won't allow it to pass SMOG. He's having a hard time sourcing the correct California Emissions distributor, so I here I am looking for one. Any ideas?
[/img]
Xevin Premium Member
Xevin is offline
PostPosted: Thu Jul 12, 2018 12:36 am    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
You should probably contact this guy if it’s really just a distributor issue.
https://www.thesamba.com/vw/forum/profile.php?mode...f3ef6343f1
Keep on Busin'
Clatter wrote:
sunnydog wrote:
(This probably is Xevin's new signature line quote: Sunnydog said:"just the tip...")
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
[email protected] wrote:
luvtheeluvbug
PostPosted: Yesterday 3:38 pm    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Is there anywhere I can source a Bosch 0231170093 distributor? It seems like they aren't manufactured anymore.
guitarman63mm
guitarman63mm is offline
PostPosted: Yesterday 8:17 pm    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
Looks like this person is selling one:
https://www.bugcity.com/shop/shop.lasso?cid=&s...ort=name_d
That said: you should post the part number for the distributor you have in there - what makes it special compared to any old SVDA? Did these have vacuum retard at idle? Unless there's a technical CA/FI reason you need it (have seen SGKent talk about ECU considerations in other threads), switching to electronic will likely run better:
http://vwparts.aircooled.net/Pertronix-III-SVDA-Distributor-D7182504-p/d7182504.htm
Jimmy
- 1974 Safaré Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine.
luvtheeluvbug
PostPosted: Yesterday 8:57 pm    Post subject: Re: Uncharted Territory: Adventures with a '78 Kombi Reply with quote
guitarman63mm wrote:
Unless there's a technical CA/FI reason you need it (have seen SGKent talk about ECU considerations in other threads), switching to electronic will likely run better.
That's precisely the reason why I need that specific distributor. I'm in the process of getting the bus ready to SMOG (in California) and that distributor is one of two missing links, the other being the crossover pipe for the exhaust system. I did try BugCity but their online ordering didn't seem to be working properly so, I'll try by phone.
