dzhezzkampos Samba Member
Joined: April 01, 2016 Posts: 12 Location: El Segundo, CA
Posted: Tue Jan 09, 2018 5:35 pm Post subject: '81 VW Rabbit Diesel Rear Light Socket and Heat Shield Question |
Hello All!
I need a bit of help here and instead of creating two different posts I thought I might as well lump these two things together albeit not exactly the same issue. I am working on restoring my old '81 VW rabbit, which I purchased for about $900 from an older guy who just had it lying around.
So, I was having issues with my brake light bulb, and when I went to replace it I noticed that the plastic on all of the bulb holder sockets was breaking apart. Fast forward a few weeks and suddenly my dash and tail light aren't working. My directional signals work and my brake lights work also, my front head lights also work. I went to the back and noticed that the plastic on my troublesome brake light had completely broken off and I had two long metallic pieces along with wires soldered to them floating around, I tried to stick them back in place for the meanwhile, but still no luck, until I pressed the brakes and the dash lights would turn on, I then let go of the brakes and the dash lights would turn off. I am almost sure that is the issue, but I want to make sure.
If that is the issue I plan to get the sockets (from a 1989 golf in a junkyard), but do I need to crimp these new wires or do I just take off the plastic piece slide in the metal pieces and close everything up?
Now the heat shield, I would like to know the part number for the heat shield that protects the brake lines under the floor of the vehicle. I haven't checked to see if it has it or not, but I have noticed that the metal pieces near the floor of the vehicle get really hot, like the brake handle the bottom rails for the seats and such. It might be the missing heat shield, I would really appreciate a part number or something similar I can stick under there.
I know a bit long winded, but I would really appreciate the help.
Thank you guys! |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Tue Jan 09, 2018 8:18 pm Post subject: Re: '81 VW Rabbit Diesel Rear Light Socket and Heat Shield Question |
heat shield is nla...don't waste your time. try to find a good used one....but by now, they are all toasty
sounds like you need a light socket. go to napa and match them up. they were used on domestic junk, so should be easy to find _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Jan 09, 2018 11:11 pm Post subject: Re: '81 VW Rabbit Diesel Rear Light Socket and Heat Shield Question |
Awesome, thanks!
The floor of my VW gets really hot, like the e-brake handle and the seat rails, is there any way to avoid that without the use of a heat shield? |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Wed Jan 10, 2018 8:49 am Post subject: Re: '81 VW Rabbit Diesel Rear Light Socket and Heat Shield Question |
Get a section of aluminum or galvanized chimney pipe from the hardware store & make your own heat shield, or rob one from a modern Jetta at a local pick & pull bend it to fit. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
