rcroane Samba Member
Joined: January 03, 2013 Posts: 2000 Location: Springfield, Virginia
Posted: Wed Jan 10, 2018 6:08 am Post subject: Help me understand cold tire pressure |
Like many of you, we've had a real cold snap recently here in Virginia. I've always known that tires lose pressure when the temperature drops and I've read that I should add air when this occurs.
We've warmed up a bit here and I now see that my air pressure is too high in all of my cars. Am I now supposed to deflate them to the correct pressure? This process seems like it could be a daily occurence as temps fluctuate!
Sorry if this is a dumb question.
Thanks. _________________ '65 Sunroof Bug
raygreenwood Samba Member
Posted: Wed Jan 10, 2018 6:56 am Post subject: Re: Help me understand cold tire pressure |
Actually....in relatively normal weather.....you should not add pressure to bring your cold pressure up......unless your driving length of time, ambient temps and speeds....require it.
For example: I am using my 2012 Golf for this example. Fronts with my tires should be at 35 and rears at 34.
At 7:00am.....at 40°F outside.....the tire pressures are at 32 psi front and 31 psi rear.
NOTE: its going to warm up to close to 60°F outside.
In this case...I leave the tire pressure alone. Between heat generated by driving and ambient heat going up.....by lunch time.....my tire pressures are at 35/34 again and sometimes 1 psi higher.
Next case:
Its full winter now. At 7:00 its 8°F. My front tire pressure is now 30 psi and my rears are at about 29 psi. It not going to get any warmer than 20°-25°F today.
But.....the first time this happens....do not add pressure....yet. Drive the car, wait for the h8gh temperature outside....and check them.
In this case....the pressure came up only 2 psi. I needed to add 3 psi front and rear to get the pressure where it needs to be.....and my car with my tires....handles oddly when its low or high.
Further checking over time has shown me....with my tires and average driving pattern...that this same low temperature pattern holds up.....to about 35° outside temp. Your results may vary.
So from historical checks..... I know that as long as we are in this temp range.....I have to keep 3 psi extra in the tires.
And...when constant weather warms up over about 35°F....I am going to have to let 2-3 psi out.
The thing that throws this off.....is that in when I am in the cold weather, extra 3 psi cycle...... whenever I go on a long distance highway speed drive.....like driving from Des Moines to Kansas city....3 hours at 75 mph.......like clockwork.....within about a 10 mile radius each time....about 2.5 hours into the drive.....the tires heat up enough regardless of ambient temps.....that they are now right at 2 psi too high....and.....I know this because the tire pressure light and alarm goes off.....and I stop within ahout 10 minutes at the SAME rest area to check the air just in case. 2 psi higher....while I can feel a slight difference....is fine.....so I dont adjust it....because in an hour or two when I get where Im going....I am going to be back at street speeds and normal temperature and pressure.
Ray |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31381 Location: Hot Arizona
Posted: Wed Jan 10, 2018 7:58 am Post subject: Re: Help me understand cold tire pressure |
If you convert the current and previous temperatures to degrees Kelvin, then you could calculate the pressure change due to temperature.
Like (measured pressure x Kelvin temperature when measured)/"other" temperature in degrees Kelvin. Then convert to Celsius or Fahrenheit, whatever. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Jan 10, 2018 8:18 am Post subject: Re: Help me understand cold tire pressure |
Cusser wrote: |
Like (measured pressure x Kelvin temperature when measured)/"other" temperature in degrees Kelvin. Then convert to Celsius or Fahrenheit, whatever. |
So true!....but my brain is too slow in the am. Therefore I have a special tool (tire pressure gauge)...that does that for me! ..I know...I know....call me a Luddite!
But I do use my geometry and trig!..Algebra...not so much!
Ray |
Posted: Wed Jan 10, 2018 8:20 am Post subject: Re: Help me understand cold tire pressure |
Thanks, guys. This is very helpful. _________________ '65 Sunroof Bug |
gt1953 Samba Member
Posted: Wed Jan 10, 2018 10:36 am Post subject: Re: Help me understand cold tire pressure |
Yesterday mid morning aired up all of the tires...Some took almost ten lbs. Three VW's a pickup and Subaru.
No one mention elevation change. Ok so go from 6500 feet to 1000 feet. What does the pressure do??? I know I know. When you go down in elevation so does the pressure. When you go up so does the pressure.
Not sure why but I bet a scientist type knows. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Jan 10, 2018 2:54 pm Post subject: Re: Help me understand cold tire pressure |
gt1953 wrote: |
Not sure why but I bet a scientist type knows. |
I think that when you go up in elevation you are closer to the Sun so the tires get warmer. |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Jan 10, 2018 3:20 pm Post subject: Re: Help me understand cold tire pressure |
Nitrogen fluctuates less with changes in temp and can lessen the psi swings. It is used in aircraft and even in new cars. Is it worth it? IDK. Maybe if higher performance is required or you notice handling issues with a slightly low, or high psi. |
gt1953 Samba Member
Posted: Wed Jan 10, 2018 4:24 pm Post subject: Re: Help me understand cold tire pressure |
Purchase a bag of chips or something like it at a low elevation...then travel up the mountain. Watch the bag swell up. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Cusser Samba Member
Posted: Wed Jan 10, 2018 6:20 pm Post subject: Re: Help me understand cold tire pressure |
gt1953 wrote: |
I'm a scientist type. But a chromatography specialist, primarily with consumer products experience. I seem to remember something about more weight of air molecules pushing down at lower elevations.
gt1953 wrote: |
Purchase a bag of chips or something like it at a low elevation...then travel up the mountain. Watch the bag swell up. |
Many bags like ships are actually flushed with nitrogen gas to keep out air/oxygen which tends to oxidize unsaturated bonds in the fats and oils of the contents.
The chips bag is not as rigid as a tire, so chips bags will expand more. A tire will expand minimally at higher elevations. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Jan 10, 2018 7:44 pm Post subject: Re: Help me understand cold tire pressure |
gt1953 wrote: |
Simple...at higher altitude...there is less air and therefore less atmospheric pressure...so less atmospheric pressure squeezing on the tire...so the air expands.
Tire pressure reads higher because its a relational pressure between internal (in the tore) and external (atmospheric). Ray |
Cusser Samba Member
Posted: Thu Jan 11, 2018 8:16 am Post subject: Re: Help me understand cold tire pressure |
gt1953 wrote: |
I'm a scientist. That's why I know why the days are longer in summer - the heat expands them !!!! Duh !!!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Thu Jan 11, 2018 9:02 am Post subject: Re: Help me understand cold tire pressure |
Cusser wrote: |
I'm a scientist. That's why I know why the days are longer in summer - the heat expands them !!!! Duh !!!! |
This guy sciences. _________________ sent from a phone using poor grammar and spelling |
Posted: Thu Jan 11, 2018 9:21 am Post subject: Re: Help me understand cold tire pressure |
Cusser wrote: |
gt1953 wrote: |
I know you are joking but for people who don't know, the sun is tilted more toward the sun in summer, that's why the days are longer - you are getting more rays of sun hitting the earth during the day.
Side note to that: This causes the higher temps too. The earth is actually further away from the sun in summer so summer is really just from the tilt of the earth. _________________ How to Post Photos
Posted: Thu Jan 11, 2018 12:24 pm Post subject: Re: Help me understand cold tire pressure |
EverettB wrote: |
Cusser wrote: |
gt1953 wrote: |
Side note to that: This causes the higher temps too. The earth is actually further away from the sun in summer so summer is really just from the tilt of the earth. |
Nope. I'm going with Cussers idea. Your way sounds like black magic. _________________ sent from a phone using poor grammar and spelling |
sb001 Samba Member
Posted: Thu Jan 11, 2018 1:03 pm Post subject: Re: Help me understand cold tire pressure |
EverettB wrote: |
Cusser wrote: |
gt1953 wrote: |
Yes, but how can Princess Leia float back to the ship if she is only "Force sensitive" and not a true master? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bruce Samba Member
Posted: Fri Jan 12, 2018 4:58 pm Post subject: Re: Help me understand cold tire pressure |
Pruneman99 wrote: |
Nitrogen fluctuates less with changes in temp and can lessen the psi swings. |
This is a myth. Nitrogen follows the ideal gas law, same as oxygen. This means they react exactly the same to temp changes. Besides, ordinary air is 78% nitrogen already! _________________
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6622 Location: Houston, Texas
Posted: Sat Jan 13, 2018 1:08 pm Post subject: Re: Help me understand cold tire pressure |
Drive the car until the tires can warm up from road friction. Then add your air making sure not to overinflate. The heat from driving on the road will heat the air inside the tires. _________________ www.vwnos.com [email protected]
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Tue Feb 27, 2018 12:27 pm Post subject: Re: Help me understand cold tire pressure |
I always check mine on the weekend (usually cause I have the time) the car has sat overnight so I have cold tires.
Midday/Noon-ish is "usually' when I get around to it.
But as you say in Virginia, you pretty much have to do this monthly esp in real cold weather sub 20degrees.
One thing to note: your Schrader valve in your air valve stem, I've had a few of these leak on one of my vehicles, the valve had small bits of plastic on the cork/rubber type surface causing a very tiny leak,
the old (spit on yer finger and check the valve for leak trick) didn't even notice it.
I try to keep a few spares handy and the wrench to check/clean/tighten or replace them.
Hard to believe that's the only thing keeping air in the tires!
Really been a pain on my 73 Thing's washer and spare tire pressure. I usually end up with a flat spare, think I have a slight leak in the rubber hose to washer screw top... Anyways...
And if you get curious, its real easy to "shoot one across the driveway" if you take it out while the tires got pressure on it.
I always heard you should check tire pressures monthly anyways for best MPG.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
