Sink Drain Options (No cutting)
sethpat Premium Member
sethpat is offline
PostPosted: Wed Jan 10, 2018 12:21 pm    Post subject: Sink Drain Options (No cutting) Reply with quote
Long story short, I'm too chicken shit to cut a giant hole in my new cargo floor to accommodate the stock floor drain. I'm thinking about running the drain pipe to a small piece of PVC and connecting to a length of flexible tubing that fits into a removable collection tank. Has anyone done something like this? I'm thinking that I wouldn't need anything larger that 2-3 gallons so long as it's easy enough to remove and dump out.
Cheers,
Seth
Frankenbus
https://www.thesamba.com/vw/forum/viewtopic.php?t=674133&highlight=
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift
asiab3
Air-Schooled
asiab3 is offline
PostPosted: Wed Jan 10, 2018 1:37 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
How often do you use the sink? My favorite solution was an easily removable stainless steel dog bowl used as a sink, so you just fill it gradually and dump it outside as needed. Easier to remove for transporting large cargo, too.
Robbie
www.airschooled.com
Three rules of troubleshooting:
1. Do the easiest thing first.
2. Don't rely on the guy before you. He was not able to fix the problem.
3. 90% of problems are between the driver's seat and the steering wheel.
sethpat is offline
PostPosted: Wed Jan 10, 2018 3:43 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
Robbie
To be honest, I've never used it besides to test the pump. I just got the bus back together and on the road. Figure I'll just use it every once in awhile
Cheers,
Seth
Frankenbus
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift
Tom Powell
Tom Powell is offline
PostPosted: Wed Jan 10, 2018 4:17 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
The sink in my '69 camper doesn't have a drain. I find it very handy for loose change and temporary storage of small items. It's easily removed and I use it occasionally for bathing.
Aloha
tp
my59
my59 is offline
PostPosted: Wed Jan 10, 2018 6:07 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
The sink in our 79 is connected to a plastic jug under the water container via flexible hose. The jug holds more than the supply tank, and can be removed by unscewing the hose clamp.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'75 MG Midget, '77 MG Midget in boxes, '12 Jetta, 77 Mercedes 300D
otiswesty
otiswesty is offline
PostPosted: Thu Jan 11, 2018 10:22 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
I got rid of the dumb black 1 1/2" pipe and went with a standard RV P-trap like the Vanagon Westfalia has
http://www.gowesty.com/product/faucets-plumbing/2424/p-trap-sink-drain-kit-?v=
1989 Syncro Westfalia
1978 Sage Green P22 Westfalia
Mercedes Gwagens
Just a regular guy
sethpat is offline
PostPosted: Thu Jan 11, 2018 10:41 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
Thanks for the replies everyone. Otiswesty, what do you have the P trap running to ? ,
Frankenbus
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift
Globespotter Premium Member
Globespotter is offline
PostPosted: Thu Jan 11, 2018 11:47 pm    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
I ran clear tubing and installed a small holding tank under the bus:
http://globespotter.com/?p=676
1977 Westfalia - October 2015 - Current
1971 Super Beetle - May 2012 - Current
1979 Westfalia - 1986-1991
1971 Super Beetle - 1977-1980
Read the story about my Survivor Super Beetle: http://globespotter.com/survivor/
My 77 Westy M-Plate decoded: http://www.vw-mplate.com/mplate-30990.htm
scubaseas Premium Member
scubaseas is offline
PostPosted: Fri Jan 12, 2018 12:12 am    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
I have a collapsible 5 gallon water tank and flex hose. Rarely gets used. Tank is collapsed when empty with bottled water on top of it so amount of water is smaller than tank. There is a removable shelf between tank and water bottles. As the tank expands the shelf comes out. My 1970 has the stove/sink/fridge set up out of a 78 Westphalia.
Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired
otiswesty
PostPosted: Fri Jan 12, 2018 10:33 am    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
The P-trap just runs down to the adaptor out the floor like before. Increased my sink cabinet shelf size into the back left corner.
I made a new plate for under the floor out of stainless 16ga sheet, but with a smaller hole
Mercedes Gwagens
Just a regular guy
sethpat is offline
PostPosted: Sat Jan 13, 2018 11:33 am    Post subject: Re: Sink Drain Options (No cutting) Reply with quote
Right on, I like this solution a lot, still have to drill a hole, but very small compared to the original. It's also nice and cheap which is a big plus Cool
Thanks for the input everyone !
Frankenbus
1975 Westfalia
914 IV 1.7
93mm pistons
Weber 34 ICT's
Cam 264* .402 lift
