Steering Rag Joint
BIGMIKEY
BIGMIKEY is offline
PostPosted: Wed Jan 10, 2018 1:56 pm    Post subject: Steering Rag Joint Reply with quote
How much misalignment is it going to take before it fails? It's not a U-joint.
A stock Beetle, the steering shaft and steering box shaft are all in line. The rag joint serves as vibration damper. It doesn't have to flex to do it's job.
So I say the factory sets them up with no misalignment at all. My thinking is any misalignment from mounting the steering wheel higher or lower flexes the rag joint past it's design.
I think my Deserter will end up with a few degrees of misalignment. I have a universal joint to use in that case.
But the rag joint is rubber and can take a bit of misalignment. How much of an angle do you think is asking for failure?
Mike T
BIGMIKEY
Deserter Series 1 on 1969 chassis
1973 Beetle Standard project, Marina Blue
woodoctr
woodoctr is offline
PostPosted: Wed Jan 10, 2018 3:42 pm    Post subject: Re: Steering Rag Joint Reply with quote
I've seen them set up pretty wonky over the years on both kit cars and dune buggies. If they fail, it doesn't happen overnight....it is usually a gradual tearing. I have seen them fail but that was guys taking a car that had set for a long time and not changing them right away. Rot, not good....
I'd throw it on there and just inspect it regularly. If you get any indication of tearing/deterioration go to the U joint.
joescoolcustoms
joescoolcustoms is offline
PostPosted: Wed Jan 10, 2018 4:16 pm    Post subject: Re: Steering Rag Joint Reply with quote
The steering box can be "tuned" a little to correct a few degrees is mis-alignment. The two bolts that bolt it to the beam tube can be used for this. Loosen one and tighten the other to twist the box on the beam to catch better alignment. I would not do more than 2 turns out/in so there will still be plenty of threads left engaging in the box for a safe mount.
If you do this, remember, it changes the wheel alignment. That will need to be corrected afterwards.
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
Dale M.
Dale M. is offline
PostPosted: Wed Jan 10, 2018 4:42 pm    Post subject: Re: Steering Rag Joint Reply with quote
DO NOT replace OEM style rag joint with Urethane "joint" they crack and break without warning and can leave you stranded or worse case at speed on freeway with no steering....
No don't even think about it....
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
joemama
joemama is offline
PostPosted: Wed Jan 10, 2018 8:10 pm    Post subject: Re: Steering Rag Joint Reply with quote
BIGMIKEY
BIGMIKEY is offline
PostPosted: Thu Jan 11, 2018 10:34 am    Post subject: Re: Steering Rag Joint Reply with quote
You know, I had a reference to the red disc of death being a bad idea in the original post but I deleted it because I thought the post was too long. I guess I should have left it in. I am well aware and I know to not use that urethane disc and wasn't trying to say that I was considering it.
It's Good that information is in this thread though.
Mike T
BIGMIKEY
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Thu Jan 11, 2018 2:17 pm    Post subject: Re: Steering Rag Joint Reply with quote
Late super beetles and VW Porsche 914's used steering column flexible U-joints that could be safely used. Hod rod shops also have them.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
BIGMIKEY
BIGMIKEY is offline
PostPosted: Thu Jan 11, 2018 4:37 pm    Post subject: Re: Steering Rag Joint Reply with quote
Yes. I have a couple Super beetle universal shafts that I picked up a few years ago. I was surprised to see that the I.D. of the ends were too big to clamp down on the beetle steering box stub. Easily enough corrected if you have fabricating capability.
Mike T
BIGMIKEY
kitcarguy
kitcarguy is offline
PostPosted: Mon Jan 15, 2018 5:35 pm    Post subject: Re: Steering Rag Joint Reply with quote
I cant even get the damn thing off my car haha
www.fiberclassics.org
