Dog House Differences
ChapinBusDude
ChapinBusDude is offline
PostPosted: Sat Jan 13, 2018 1:04 pm    Post subject: Dog House Differences Reply with quote
I have these two dog houses that I think are for stock T2 engines. It looks like the difference is around the oil cooler with the one on the right having the extra bit of tin for the cooler to be offset on an engine from the engine that uses the dog house on the left in the picture. Can someone give me an idea of what these two would typically be used for?
Brian
Brian is offline
PostPosted: Sat Jan 13, 2018 1:10 pm    Post subject: Re: Dog House Differences Reply with quote
One on the left is from a single port and the one on the right is for a Type 1 based 71+ dual port.
Single port upright cooler: http://vwparts.aircooled.net/Oil-Cooler-Non-Doghouse-111-117-021E-to-1970-p/111-117-021e.htm
Doghouse cooler: http://vwparts.aircooled.net/Oil-Cooler-Doghouse-OEM-VW-1971-Upright-Engine-p/113-117-021oem.htm
Uses this stand: http://vwparts.aircooled.net/Doghouse-Oil-Cooler-Adapter-EACH-113-117-303-p/113-117-303.htm
The non-doghouse one pushes the hot air down onto the cylinders, which is OK but not great.
Doghouse pushes the hot air forward towards the transmission.
'69 Bug
'68 Baja Truck
'71 Bug
Ran when parked
babysnakes
babysnakes is offline
PostPosted: Sat Jan 13, 2018 5:36 pm    Post subject: Re: Dog House Differences Reply with quote
The black one has the oil cooler inside the shroud and inhibits airflow to the 3/4 side. The purple one has the "dog house" where air is diverted to the oil cooler and air is more efficiently delivered to the cylinders/head. The air flow is divided between the two. Hot oil cooler air is diverted to the front and the remaining fresh air is forced through the head/cylinders.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Jan 13, 2018 5:42 pm    Post subject: Re: Dog House Differences Reply with quote
As stated, the one on the left is NOT a Dog House shroud.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2018
ChapinBusDude
PostPosted: Sat Jan 13, 2018 6:34 pm    Post subject: Re: Dog House Differences Reply with quote
Ahhhh! The dog house is not the entire fan housing it is the modification that allows the oil cooler to be moved out of the way of #3.
Thanks very much!
Wildthings
Wildthings is offline
PostPosted: Sun Jan 14, 2018 5:13 pm    Post subject: Re: Dog House Differences Reply with quote
A doghouse shroud has a dedicated air supply for the cooler. You can see the volute for the cooler wrapped around the inlet. This way it does not "steal" the cooling air from the 3-4 side.
The later beetle shrouds also have a venturi ring built into the air inlet. Never heard how much this would have increased the air flow. Don't know what was used on shrouds for the Mexican and Brazilian market.
ChapinBusDude
PostPosted: Sun Jan 14, 2018 5:30 pm    Post subject: Re: Dog House Differences Reply with quote
So now I am wondering if the doghouse completely addresses the #3 cooling issue I read about every now and then?
Wildthings
PostPosted: Sun Jan 14, 2018 5:36 pm    Post subject: Re: Dog House Differences Reply with quote
With the offset cooler and doghouse shroud, all the cylinders get a similar amount of air flow.
