Posted: Mon Jan 15, 2018 8:58 pm Post subject: Re: Major Oil Leak |
Post a picture of your engine.
If the engine is in the back of the car, the leak is in front of the pulley not behind it.
i_luv_my_bus76 wrote: |
I have a real bad oil leak coming from behind the crankshaft pulley
I pulled the pulley off, is there suppose to be a seal behind the pulley? |
_________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Mon Jan 15, 2018 9:01 pm Post subject: Re: Major Oil Leak |
[email protected] wrote: |
Hey John...I just bought a set of single port heads from you guys!!!!!
I pressure washer the engine but you can still see where the leak was...give me a sec. I'll post a pic |
Posted: Mon Jan 15, 2018 9:10 pm Post subject: Re: Major Oil Leak |
Please let me know if more pics are needed
Posted: Mon Jan 15, 2018 9:13 pm Post subject: Re: Major Oil Leak |
oK, you have an upright Type 1 engine. Now post a picture of the front side of the crank pulley. _________________ It's just advice, do whatever you want with it!
Posted: Mon Jan 15, 2018 9:25 pm Post subject: Re: Major Oil Leak |
oK, you have an upright Type 1 engine. Now post a picture of the front side of the crank pulley. |
Danwvw Samba Member
Posted: Mon Jan 15, 2018 11:09 pm Post subject: Re: Major Oil Leak |
The screw pulley system works amazingly well, it's hard to understand how it could leak much at all there unless it's overfilled with oil. Aluminum pulley or not.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Danwvw Samba Member
Posted: Mon Jan 15, 2018 11:31 pm Post subject: Re: Major Oil Leak |
What is that rusty stuff in there on the slinger? Is the slinger messed up? Rusted out? Or is that some old gasket material someone tried because they did not have the pulley nut seated tight?
Dale M. Samba Member
Posted: Tue Jan 16, 2018 6:59 am Post subject: Re: Major Oil Leak |
67rustavenger wrote: |
What is a slinger |
This is an oil slinger.
It is attached to the end of the crank and the cupped side faces forward(toward the flywheel).
Good Luck. |
Actually I think that is wrong.... Cup (concave) faces to rear (v belt pulley) .. But in any case crank will not go in case (easily - binds up on assembly) if slinger is faced wrong way....
https://www.thesamba.com/vw/forum/viewtopic.php?p=6260852#6260852
And...
According to Danwvw's graphic...
Leak could also be caused by drain path for slinger chamber is blocked...
