Goach2 Samba Member
Joined: November 20, 2017 Posts: 522 Location: Niagara Region, Ontario
Posted: Fri Feb 02, 2018 5:11 pm Post subject: Re: Late Bay Fuel sender |
Well, I tried dropping the original float in, with float arm pointing directly to the back and it hits the bottom before it is totally seated in the hole. This doesn't happen when it's pointing to the driver's side.
As you can see, the spades on the replacement aren't pointing in exactly the same direction as the originals:
And if you look close, you can see the teeth aren't aligned either:
Is this a defect? Or do I have the wrong sender? _________________ 1977 FI Westfalia |
Goge Samba Member
Joined: July 02, 2007 Posts: 58 Location: Medford, OR
Posted: Fri Feb 02, 2018 5:12 pm Post subject: Re: Late Bay Fuel sender |
I just installed one and found the same thing. My old VDO sender had the float towards the driver side. I went to install the new one but the teeth were off, as you stated. I thought it might hit the side of the tank it was that far off. So, I flipped it around with the float to the passenger side and it lined up much more centered in the tank. I hope it works OK that way, don't see why it wouldn't. _________________ '64 Beetle
'73 Westfalia
Too many kids
Not enough hair on my head
Not enough beer in my fridge |
Goach2 Samba Member
Posted: Fri Feb 02, 2018 5:21 pm Post subject: Re: Late Bay Fuel sender |
Dude on youtube bent the float arm to the side to align it again:
https://www.youtube.com/watch?v=aAXuSANkCaI
Is that the best work-around? _________________ 1977 FI Westfalia |
Goach2 Samba Member
Posted: Fri Feb 02, 2018 5:24 pm Post subject: Re: Late Bay Fuel sender |
Goge - There's a baffle on the pass-side of the tank, I'm pretty sure it would hit it if I did that... _________________ 1977 FI Westfalia |
Goge Samba Member
Posted: Fri Feb 02, 2018 5:28 pm Post subject: Re: Late Bay Fuel sender |
Oops yeah that probably wouldn't work. I gots no baffles. _________________ '64 Beetle
'73 Westfalia
Too many kids
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Sat Feb 03, 2018 1:10 am Post subject: Re: Late Bay Fuel sender |
Goach2 wrote: |
German Supply is VDO, so that sounds like the preferred way to go. |
I was scratching my head for quite a while thinking why VDO might have changed the design. I've now realized from your pictures... you don't have a VDO sender.
It's a JP Group aftermarket sender, the same one as the guy on the YouTube video. So if you bought it as part # 211 919 051 A, you've got the correct (but crappy) sender.
I also noticed that in your pictures the new sender does not have the sealing O-ring (you can compare it with your old sender, with the cracked black O-ring). If it didn't come with your sender, you'll need to purchase it separately, but you definitely need it, as you don't want to spill fuel or its vapours.
As per R vs swing being linear, after Colin's comment I've double-checked it again: most of the curve is linear, but indeed windings are tighter at the ends. Towards full the wiper does barely go into the tighter packed winding, but towards empty, the wiper does go a few degrees into the tighter winding area.
My mistake was to measure only on three points. Sometime this weekend I'll post a new diagram with more sample points. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Goach2 Samba Member
Posted: Sat Feb 03, 2018 12:40 pm Post subject: Re: Late Bay Fuel sender |
So I also discovered that if you dry-fit this sender without the gasket, it locks in nice. When the gasket (o-ring) is on it, it's really snug, but if you tap the slots it will actually go past the locking point to the next slot, where it will be loose again... not a well made part. _________________ 1977 FI Westfalia |
Goach2 Samba Member
Posted: Mon Feb 05, 2018 1:16 pm Post subject: Re: Late Bay Fuel sender |
So now that I've bent the arm to better align with the original position of the float, it causes it to 'rotate' as it rises to point down a bit when full. I know this messes with accuracy, but is it really going to make that much of a difference? Is there a better way? _________________ 1977 FI Westfalia |
furgo Samba Member
Posted: Mon Feb 05, 2018 3:36 pm Post subject: Re: Late Bay Fuel sender |
Goach2 wrote: |
So now that I've bent the arm to better align with the original position of the float, it causes it to 'rotate' as it rises to point down a bit when full. I know this messes with accuracy, but is it really going to make that much of a difference? Is there a better way? |
How exactly did you bend the arm and what do you mean by 'rotate' and 'rises to point down a bit' in this context? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Goach2 Samba Member
Posted: Tue Feb 06, 2018 6:38 am Post subject: Re: Late Bay Fuel sender |
I don't have a pic at the moment, but I bent the float arm at the 'elbow' to the side, so that it pointed down the length of the tank. As above, the whole sender is rotated because the locking tabs are off of the originals. So with the arm bent to the side, it's sideways to the arc motion of the arm, therefore the float 'rotates' a bit. I've already started to get the tank back in, so I guess I can let everyone know how it goes?! _________________ 1977 FI Westfalia |
furgo Samba Member
Posted: Tue Feb 06, 2018 8:58 am Post subject: Re: Late Bay Fuel sender |
Thanks for the clarification. Sure, do let us know how it goes once you've finished, I'm sure others will find it helpful as well.
As I said, I can't help with the last (mechanical) part of the calibration/compensation, but I finally put together the sparse notes I had taken when I did the electrical calibration of mine on this separate thread. _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
