hutmo Samba Member
Joined: February 05, 2002 Posts: 37 Location: Pittsburgh, PA
Posted: Sun Jan 14, 2018 10:33 am Post subject: Fram Filter Install Question |
01/14/2018
I just purchased a a Fram (Flat 4) filter for my Okrasa engine.
What would be the best way to hang the bracket? Drill and bolt from inside the fan housing I am assuming. plastic lined lock nuts or lock-tite on threads?
Thanks
Chris _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
Joined Feb 6, 2002 |
MeeferMadness Samba Member
Joined: June 14, 2004 Posts: 305 Location: Eugene Oregon
Posted: Mon Jan 15, 2018 4:35 pm Post subject: Re: Fram Filter Install Question |
I had nuts welded to a sheet metal plate then spot welded to the inside of the fan housing
Bruce |
mkbug Samba Member
Joined: October 12, 2004 Posts: 145 Location: Northern California
Posted: Tue Jan 16, 2018 4:22 pm Post subject: Re: Fram Filter Install Question |
Consider using longer bolts and go through the whole fan shroud. This way you aren't relying on just the front sheet metal of the shroud but both front and back. The bolts would have to be about 2 inches long...guessing without a shroud in front of me. _________________ I'm Martin
My Build: https://www.thesamba.com/vw/forum/viewtopic.php?t=667183 |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1083 Location: Dover, DE
Posted: Sat Jan 27, 2018 8:55 am Post subject: Re: Fram Filter Install Question |
Hey Hutton- who did you order the kit through? The flat four site won't direct me to a price list. _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
hutmo Samba Member
Posted: Sat Feb 03, 2018 7:57 am Post subject: Re: Fram Filter Install Question |
6T5 square wrote: |
Hey Hutton- who did you order the kit through? The flat four site won't direct me to a price list. |
CB Performance
https://www.cbperformance.com/product-p/1699.htm _________________ What if the Hokey Pokey really is what it is all about?
Samba Member #1115
