stugger57 Samba Member
Posted: Sun Jan 14, 2018 10:47 am Post subject: Restarting problem |
My type 1 motor starts right off when cold. After driving a bit and getting the engine up to freeway temperatures I'll turn the motor off. When trying to restart there is nothing. No click from starter, nothing. The accessory lights are on. Letting motor cool for an hour seems to work also push starting works. Is this a solenoid issue at starter. Help? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Sun Jan 14, 2018 11:10 am Post subject: Re: Restarting problem |
It probably will be fixed by a starter, but you should evaluate condition of
Ignition switch
wiring
starter
and bring all three components to near new condition for a trouble free starting experience. _________________ .ssS! |
Xevin Samba Member
Posted: Sun Jan 14, 2018 11:40 am Post subject: Re: Restarting problem |
I know it’s been mentioned before. We need a sticky for this type of situation. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Sun Jan 14, 2018 11:57 am Post subject: Re: Restarting problem |
When hot and not starting remove solenoid wire (red 12? gauge 1/4" spade push on) and measure the voltage when in the "crank" position. It has to be 11V or higher to get the solenoid to pull in. If you have 11 or more volts on the solenoid wire then you need a starter or the bushing in the bell housing. Ideally you would have close to battery voltage at the solenoid wire.
If you do not have 11 or more volts (you should have close to what the battery voltage is) then check the wire back to the ignition switch.
Also check resistance from engine block/case to negative battery post. Should be zero ohms or very close to it. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Fri Jan 19, 2018 3:00 pm Post subject: Re: Restarting problem |
Perfect, great info without a ton of BS. Got it handled. THX again |
