OrangeMango Samba Member
Joined: April 12, 2015 Posts: 114 Location: Sacramento, California
Posted: Sun Jan 14, 2018 2:14 pm Post subject: Rear Window Defogger |
So I have to change the seals on the front window and back window soon because theyre letting some water get in but at the moment I wanted to look at my back defogger and figured im going to have to remove the glass maybe I can fix this when I have to pull it out.
This is what I know. On my dash the light will pop on if I flip the switch a few time, not on every flip tho. I took a test light and the wire coming for the driver side wall lights up but none of the lines across the window will and the wire from the passenger side wall does not either. I'm not sure if the passenger side is supposed to be a ground or another power.
Taking a closer look the metal looks a bit green from rusting.
I'm not sure what I should do from this point on, does anyone have any knowledge of fixing their rear defroster? _________________ 1972 Super Beetle stock 1600 DP
1967 Karmann Ghia stock 1500 SP |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9960 Location: Huntington Beach, CA
Posted: Sun Jan 14, 2018 2:37 pm Post subject: Re: Rear Window Defogger |
There should be a relay under the rear seat which allows current to flow from the battery to the element. The switch at the dash is for switching the relay from normally off to on. That switch also supplies power to the instrument light.
Those old rear window elements have been around for many years, so it is hard to know if they are still good, until you can apply juice to them. Do not get dissapointed, if after all the work, it fails to respond. They barely responded when new! The one in my Bug is hardly functional, all the components are present and operate, it is just old and slow. I believe there to be a semi corroded conductor under the copper plate soldered to the window grid, but I am not eager to go tearing into a window grid connector plate. Way too many other items to attend to first!
Good luck, hoping yours works awesome! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Sun Jan 14, 2018 3:47 pm Post subject: Re: Rear Window Defogger |
The passenger side is a ground. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Sun Jan 14, 2018 4:30 pm Post subject: Re: Rear Window Defogger |
Your heating elements (grids) are no doubt shot--like most other bug owners. You can buy a Frostfighter grid kit, so check them out. It's best to replace with the window out.
It also sounds like your switch needs replacement, but, as stated, the relay under the seat could be wonky.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
MERKURmeow Samba Member
Joined: December 19, 2017 Posts: 45 Location: SF Bay area
Posted: Mon Jan 15, 2018 9:17 am Post subject: Re: Rear Window Defogger |
There's a defroster switch? _________________ "Keep your dick in a vice!" |
Posted: Mon Jan 15, 2018 10:30 am Post subject: Re: Rear Window Defogger |
MERKURmeow wrote: |
There's a defroster switch? |
Yes under the speaker (grill left of the cluster gauge) and above the fuse box. It should turn on a green light in the cluster gauge below the 20 mark.
If your back window has lines across it you should have a rear defroster but I'm not sure if standard beetles had them, ive seen some without them, or it might just be someone replaced the window with a regular without a defroster. _________________ 1972 Super Beetle stock 1600 DP
jwold Samba Member
Joined: September 30, 2008 Posts: 2088 Location: Portland, OR
Posted: Mon Jan 15, 2018 3:33 pm Post subject: Re: Rear Window Defogger |
First hand experience, I've tried the frost fighter route, I'd suggest you spend your money on a new rear window. Rear windows are (or were) still available and will work way better than the frost fighter. |
Posted: Mon Jan 15, 2018 7:34 pm Post subject: Re: Rear Window Defogger |
I have all of the rear defroster equipment except the switch. Everything is connected except that. I verified it's not hanging under the dash or tucked in somewhere in the car, then I looked from the other side near the radio, hazard switch, cigarette lighter, speedo, nowhere to be found. _________________ "Keep your dick in a vice!" |
