WillSharp Samba Member
Joined: November 02, 2016 Posts: 199 Location: US 80424
Posted: Sun Jan 14, 2018 9:44 pm Post subject: Subaru Vanagon Vehicle Speed Sensors |
Hey all,
Just wrapping up my first vanagon subie swap, did a 2.5L turbo into my 91 Westy. Based on what I have read in various places, a electronic VSS for the subie ECU is important for function. The two easy options I could find are Small Car's VSS https://smallcar.com/vanagon/subaru-vanagon-conversion-parts/hall-effect-speed-sensor-kit.html
And RMW's http://www.rockymountainwesty.com/product_p/rmw-ch395ss.htm?1=1&CartID=0
I am running 944 CVs, and I am wondering what are peoples experiences?
Whats better Small Cars or RMWs?
I have a few troublesome O2 sensor related CEL codes and I have read a few things that a VSS might fix them. Anyone have experience with this?
I started this topic to open up a discussion about vanagon/subie speed sensors. Please post you thoughts, opinions, and experiences! _________________ 1889 Syncro Adventure Wagon 3.3 SVX |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Sun Jan 14, 2018 9:56 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
There is also this one.
http://fastforward.ca/vehiclespeedsensors/
I’m planning to use this because it is installed inside right in the gauge cluster. I have no personal experience with any so I’m interested is this topic. _________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Mon Jan 15, 2018 8:54 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
Good Stuff!
Thanks for the thoughts!
The poor man VSS is pretty sweet so I think Ill give it a shot. (save some $!)
I just ordered one on ol' Amazon https://www.amazon.com/gp/product/B01F58UDA8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Hopefully it will do the trick. _________________ 1889 Syncro Adventure Wagon 3.3 SVX
Posted: Mon Jan 15, 2018 8:55 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
My current O2 codes are:
P0137 - O2 Sensor Circuit Low Voltage Bank 1 Sensor 2
P0037 - HO2S Heater Control Circuit Low Bank 1 Sensor 2
P1152 - HO2S11 Sensor Circuit Range/Performance Low
P1153 - HO2S11 Sensor Circuit Range/Performance High
I have checked voltages and continuity according to the service manual at the harness plug and everything is correct so I have ruled out wiring problems.
Either I am super unlucky and both my O2 sensors are bad, or maybe the VSS will fix em. The donor car didn't run when I got it so IDK what codes it was throwing before modification.
I ordered a new front O2 sensor to try also.
The van is running ok, on start up when cold, it idles really high (3000-3500 rpm) for about 15secs then it eventually drops down to normal rpms. Not sure why this is happening but Im hoping that if I fix the O2 sensors, it might sort itself out. _________________ 1889 Syncro Adventure Wagon 3.3 SVX |
si2t3m Samba Member
Joined: September 08, 2005 Posts: 78 Location: Quebec, Canada
Posted: Mon Jan 15, 2018 9:28 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
I'm going the poor man VSS path also.
BTW, been running our 2004 EJ25 WITHOUT a VSS all summer. The only symptom I get is when running on the highway at constant speed (read no real movement detected by the Throttle Position Switch). Seems like there is a timer, and eventually the ECU will cut fuel delivery, so we loose power. I just back off the gas pedal and go back on it and everything is fine. On a trip i'd back off the gas pedal at each 10 minutes or so and the ECU would not cut fuel delivery. _________________ Marc-André Morin
90 Westy Syncro EJ25
90 Weinsburg Syncro EJ22
76 Westfalia EZ30D
72 911 Targa
70 914-6 conversion
69 Ghia convertible
68 912 coupe
67 912/911 coupe |
Jon_slider Samba Member
Posted: Mon Jan 15, 2018 11:11 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
Cool thanks guys!
Quick question for anyone,
My subie came from an Auto trans forester, which also has a trans. control module tied in with the speed sensor. The interesting thing is that I am not actually getting the VSS codes, even tho the wire for it is cut (i have it labled).
for $7 ill install it and see what happens, but it makes me wonder why I am not getting the code?
Here is the wiring diagram for the VSS on my subie:
is the VSS only on manuals?
driverdave Samba Member
Joined: October 15, 2014 Posts: 66 Location: Denver, CO
Posted: Mon Jan 15, 2018 11:17 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
I have the VSS from http://fastforward.ca/vehiclespeedsensors/
Previously I had a hall sensor that picked up pulses from the CV bolts, but I don't think it was sending the correct signal.
The VSS from http://fastforward.ca/vehiclespeedsensors/ works great for me, no issues so far, ECU receives correct signal. _________________ 1984 Vanagon Westy with a 91 EJ22 KEP Conversion |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jan 16, 2018 10:38 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
I've been using the MkII Jetta cruise control VSS that goes into the speedo housing for ~75,000 miles now with just one hiccup. When the speedo cable broke, I was limited to ~4000RPM!!
The GoWesty VSS looks as though its pretty similar to the old VW part. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
VanOnTheRun Samba Member
Posted: Tue Jan 16, 2018 11:18 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
Not really sure why you guys with your +20k dollar Syncros and turbo Westys are skimping for the $7 part instead of buying the $60 part, which is integral to the performance of your multi-thousand dollar engine conversion. Just spend the 50 extra bucks on the nice one and never have to worry about it again. The fastforward part is vastly more reliable and of a much better quality than all others.
Cheers _________________ 1987 Syncro Westfalia EJ22
2008 Ural Patrol 2WD |
vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Wed Jan 17, 2018 1:50 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
+1 on the fastforward VSS, the CV attached ones suck, the one i had on my zetec sucked, and the one i put on from small car for my dbw 2.5 sucked.
could both sucky things have been user error? sure. the small car one i thought i had lined up but the cv ring basically cut thru the sensor after getting too close. i'm pretty sure the zetec one never worked correctly.
i just got the speedo mounted one on this weekend and it kicks ass, works perfectly, and don't have to worry about a rock fucking it up.
-drew |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Thu Jan 18, 2018 2:55 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
The gowesty one has multiple reported failures in the Subaru vanagon lists. Ive been using a 3 dollar proximity sensor running straight off the cv bolts with a bracket I made myself for over 2 years with zero failure on my DIY conversion. I keep a backup in my glove box just in case. *edit*, im using the "poor man" VSS _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Posted: Thu Jan 18, 2018 12:52 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
So I received my switch today and I threw my multi meter on it to check the output voltage to make sure it is correct. According to the subaru manual it is meant to be 0-5V.
I connected it according to diagrams online:
Brown - 12v
Blue - ground
black - sensor
Im getting 12.5V (battery) when its open and 0.65V when its reading. That shouldn't work, its not in the 0-5V range.
I got the LJ12A3-4-Z/BX just like the one in the suggested in https://www.thesamba.com/vw/forum/viewtopic.php?p=7472253
Did I just get a crappy sensor? what are other peoples voltage outputs? _________________ 1889 Syncro Adventure Wagon 3.3 SVX |
Posted: Thu Jan 18, 2018 5:04 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
That is the voltage output AFAIK. The sensor is just a switch.The ouput will be a square wave. You could knock it down using a zener diode regulator,but I don't know that the actual voltage matters because I don't see them (DIY or RMW using a regulator). My reed switch VSS from SC way back when uses only open to ground. Here is a photo from subaruvanagon2 of the zener regulator.
https://groups.yahoo.com/neo/groups/subaruVanagon2...1954589891 |
Syncro Jael Samba Member
Posted: Thu Jan 18, 2018 8:11 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
VanOnTheRun wrote: |
Cheers |
When I purchased the van it had VSS fault codes and the CEL would come on anytime you decelerated, go into limp mode, until you came to a complete stop. Then it would reset and turn off the CEL and run fine till you decelerated again. The PO said it had always done it and he replaced the CV joint VSS twice. It never changed the symptoms.
After a year I finally purchased the Syncro speedometer VSS and have never had another issue since. I also checked all the wiring pin connections on the ECU. My CEL never comes on and the Subaru EJ22 has ran flawlessly since.
Worth the extra money in my book. Just FYI. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Posted: Fri Jan 19, 2018 7:41 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
Syncro Jael wrote: |
Worth the extra money in my book. Just FYI. |
Are you referring to the http://fastforward.ca/vehiclespeedsensors/ sensor? _________________ 1889 Syncro Adventure Wagon 3.3 SVX |
Posted: Fri Jan 19, 2018 10:32 am Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
WillSharp wrote: |
Are you referring to the http://fastforward.ca/vehiclespeedsensors/ sensor? |
I purchased one from GoWesty. It has worked flawlessly.
http://www.gowesty.com/product/cruise-control/23945/gowesty-vehicle-speed-sensor-?v=
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Fri Jan 19, 2018 4:22 pm Post subject: Re: Subaru Vanagon Vehicle Speed Sensors |
Early clusters had the knock out for the VSS, but the speedo head may not support the VSS. I think the break is 83-84. _________________ ☮️ |
