virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
Posted: Wed Jan 24, 2018 9:00 am Post subject: Re: KDF transmission - Info |
mr magyar wrote: |
Here's a photograph of the transmission in my December 1949 Standard. It too has a cog logo and serial number running vertically although the font is quite different to yours and has a six pointed star symbol either end of the numbers.
This is also a Kübel transmission, just earlier. _________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 984 Location: Bath, England
Posted: Wed Jan 24, 2018 9:25 am Post subject: Re: KDF transmission - Info |
Plus the rubber gaiter is wrongly installed. Somebody has made the common mistake of having it installed with the jointed seam in the vertical position, when it should be slanting forward. This is so that the when the torsion tube moves upwards, it isn't trying to compress an increased volume of rubber, with resultant stresses elsewhere. |
mr magyar Samba Member
Joined: October 19, 2008 Posts: 65 Location: Bradford, England
Posted: Wed Jan 24, 2018 9:33 am Post subject: Re: KDF transmission - Info |
Hi Martin,
The gaiters were like this on Charles' '47. I pointed out to him the joint should be horizontal so we slacken the clamps and tried to swivel the gaiter round but there was no way at all the gaiters would sit properly unless that joint was pointing up. I know what you mean about this thick rubber seam being in the wrong position to flex properly but we came to the conclusion (rightly or wrongly) that the gaiters were designed to be fitted seam up. |
geneL3c Samba Member
Joined: October 08, 2007 Posts: 296 Location: Bridgehampton,NY
Posted: Wed Jan 24, 2018 11:45 am Post subject: Re: KDF transmission - Info |
Thinking back to my days as VW line mechanic in the mid to late sixties, the recommended angle for the seam on replacement axle boots was an upward and forward 45 degree angle to prevent premature failure of the rubber adjacent to the seam. I have, over the years replaced many replacement boots that had developed leaks for that very reason. Regards, Gene |
Posted: Wed Jan 24, 2018 11:51 am Post subject: Re: KDF transmission - Info |
Additional thought, we also would temporarily put a standard 10mm nut ( 17mm wrench size ) between the torsion spring plate and the stop to keep the axle housing and drum assembly from hanging down too far so the clamps could be properly tightened in a more horizontal position. Gene |
sinclair Samba Member
Joined: July 01, 2004 Posts: 396 Location: New Forest UK
Posted: Sun Nov 12, 2023 11:45 am Post subject: Re: KDF transmission - Info |
Derosse wrote: |
additional info:
it has a very heavy yellow painted nose cone. |
What was the consensus on the steel nose cone? |
