gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Mon Jan 15, 2018 8:58 am Post subject: BRM Gasburners |
I've had a new set of these for about 10 years...waiting for something to put them on...now I'm
thinking about doing this,machining required.....any thoughts?
_________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go...
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Jan 15, 2018 9:05 am Post subject: Re: BRM Gasburners |
Huh? _________________ Glenn
Member #1009
#BlueSquare |
EmpiGT Samba Member
Posted: Mon Jan 15, 2018 4:51 pm Post subject: Re: BRM Gasburners |
I looked at the pic for a bit before seeing the difference. They look good and may not notice unless told.
Is this a set done or photo shopped? |
Posted: Mon Jan 15, 2018 5:27 pm Post subject: Re: BRM Gasburners |
It's a done set. Talked to one machinist a while back, and checking with another when time permits. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
And various VW's that come and go... |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Mon Jan 15, 2018 7:48 pm Post subject: Re: BRM Gasburners |
I don't think I'd be machining a wheel that heavily. That's taking a ton of meat out of a structural area. I wouldn't use it... |
ssx Samba Member
Joined: May 19, 2004 Posts: 641 Location: Big Isle Hawaii
Posted: Wed Jan 17, 2018 1:25 pm Post subject: Re: BRM Gasburners |
Looks awesome! As mentioned above, not sure how much of the structure is compromised tough? _________________ 1956 Oval/Ragtop |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Jan 22, 2018 10:59 pm Post subject: Re: BRM Gasburners |
Cut windows in the 5 spokes with nice radius at corners, likely caused little structural weakness.
A Plumber cuts a 2" hole in a 10" beam causes no issue, a hack cuts a 2" notch out of a 10" beam, and you got a problem. _________________ Good Luck
Al |
Posted: Tue Jan 23, 2018 6:58 am Post subject: Re: BRM Gasburners |
A 10" Wooden beam doesn't have to endure extreme dynamic forces exerted at 30+ MPH supporting 2500 lbs of weight. The beam only supports dynamic and static weights. Apples and oranges. They are your wheels....do what you want, I know there's no way I'd even consider doing this to my wheels. |
jason Samba Member
Posted: Wed Jan 24, 2018 2:37 pm Post subject: Re: BRM Gasburners |
It had 5 spokes, now it has 10. It’s probably stronger. |
chickengeorge Samba Member
Joined: August 18, 2004 Posts: 5634 Location: Spokompton Warshington
Posted: Thu Jan 25, 2018 4:33 pm Post subject: Re: BRM Gasburners |
It never ceases to amaze me what holds together as far as a wheel goes. I hang around a lot on import tuner sites. Not the B18 swap Civic-type sites, but Speedhunters and G35driver.com and whatnot. Some of the high-end wheels out there, don't look like they'd be able to hold the car up while standing still, much less moving.
Like the three-piece wheels below. How?
ach60 Samba Member
Posted: Wed May 05, 2021 1:15 pm Post subject: Re: BRM Gasburners |
ach60 wrote: |
A Plumber cuts a 2" hole in a 10" beam causes no issue, a hack cuts a 2" notch out of a 10" beam, and you got a problem. |
motofly196 wrote: |
Funny I came across this thread again, and found my post.
motofly196" has a good point, and also years ago when they made BRM reproduction wheels for New Beetles.
I showed them to a Automotive Engineer and his gut reaction was they looked weak.
So I didn't buy them, and bought stock 17" Aluminum VW wheels instead.
They were heavy, and slowed the car down. _________________ Good Luck
Al |
