Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
Posted: Mon Jan 15, 2018 4:06 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
joey1320 wrote: |
Crazy project Buggeee
Glad you didn't use the hitch, not sure how safe that would've been with the suspension/body not attached/secured. |
No Kidding Joey. Can you imagine flat-towing that mess and the wind gets under the body at around 60? Thank you MUCH for the tow bar.
Mud Peeps, I went out there with Joey's bar but ended up buying that trailer off the dude once I assessed things a bit. For 500 bucks it was a no brainier. What a great night of Buggin’ !!!!! _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
FRFABWORKS Samba Member
Joined: November 19, 2009 Posts: 28 Location: PICKERING , ONTARIO , CANADA
Posted: Tue Jan 16, 2018 8:15 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
Welcome to the sickness . For sure it is a thing frame because of the formed brace weld across and under the rear torsion tube of the pan . The serial # on the frame should start with 18------. Good luck with the project . |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Jan 16, 2018 9:42 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
Do yourself a favor and get rid of those chrome spring assisted shocks. They are way to stiff for the car and will make it ride like crap. |
Dark Earth Samba Member
Posted: Tue Jan 16, 2018 9:52 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
Have you thought about making it a class 11 look-alike ? _________________ My Build: '69 Baja - Dark Earth Version
~I'm almost done. I just lack finishing up.~ |
MI-Bug Samba Member
Joined: March 12, 2016 Posts: 117 Location: Marne, MI
Posted: Tue Jan 16, 2018 11:53 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
Dark Earth wrote: |
Have you thought about making it a class 11 look-alike ? |
The thought of a Class 11 has crossed my mind, yes. Especially because:
The nose and tail are not accident damaged, although the aprons are a bit tweaked up.
I do not have the front fiberglass pieces so I will be acquiring body parts whichever way I go.
I am not keen on an open engine compartment in Ohio's weather as snowballing in the winter is one of the few "adventures" that I would have readily available for an "off road" machine. (I'm seeing it as my old man quad runner).
Joey's brother has some fenders available if I go that route, which makes it easier.
The street peeps would disown me because "they're not making any more of these"
The alternative, however, is equally enticing simply because
It's already an irretrievable frankenbug
I read somewhere that the thing pan and suspension might have a different wheelbase so the wheels won't center in the stock bug fenders (IS THIS TRUE? I have to research this point a bit more)
When I was a tot, I would drool all over the baja kit bugs in the Mags dreaming of having a driver's license.
Thank you for those links MI-Bug, I am starting into them and will enjoy the reading!!! _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
oldschool5er Samba Member
Posted: Tue Jan 16, 2018 11:57 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
Ok I am jumping in on this one. I am in Westerville Ohio and I have two Baja's sitting in my garage right now with Thing undercarriage and I have built many. It is a complete Thing pan undercarraige that has had beetle pan halves welded in so it fits a Beetle body. Things are normally a Ghia pan but you can put Beetle pan halves in retaining the primary Thing tunnel complete with torsion. This looks like what has been done. I am a dyed in the wool Baja guy who has built and raced both class 11 and class 5/1600 and class 5 Bajas from all the way back in the early years so I don't say this lightly, But keeping this as a Class 11 look alike is absolutely what I would do. You don't find them here in Ohio in that good of condition and in fact I just brought a couple of them from Calif out here for friends just because it is pointless trying to find good ones out here. You have a gem and I would not take a sawsall to it and my nick is Sawsall Rob so not making it into a Baja is hard to admit, but in this case don't do it. Where are you located here? I have about 5 of us here that I support 3 Bajas soon to be another two. A class 11 with Thing undercarriage would keep up with anything we do up in Michigan or south of here no problem. _________________ HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving. |
Posted: Tue Jan 16, 2018 12:11 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
oldschool5er wrote: |
Ok I am jumping in on this one. I am in Westerville Ohio and I have two Baja's sitting in my garage right now with Thing undercarriage and I have built many. It is a complete Thing pan undercarraige that has had beetle pan halves welded in so it fits a Beetle body. Things are normally a Ghia pan but you can put Beetle pan halves in retaining the primary Thing tunnel complete with torsion. This looks like what has been done. I am a dyed in the wool Baja guy who has built and raced both class 11 and class 5/1600 and class 5 Bajas from all the way back in the early years so I don't say this lightly, But keeping this as a Class 11 look alike is absolutely what I would do. You don't find them here in Ohio in that good of condition and in fact I just brought a couple of them from Calif out here for friends just because it is pointless trying to find good ones out here. You have a gem and I would not take a sawsall to it and my nick is Sawsall Rob so not making it into a Baja is hard to admit, but in this case don't do it. Where are you located here? I have about 5 of us here that I support 3 Bajas soon to be another two. A class 11 with Thing undercarriage would keep up with anything we do up in Michigan or south of here no problem. |
Fish On!!!! Damn that strike was like a seven pound smallie. Damn near pulled the rod right out of my hand.
I'm all in Oldschool5er. Summer after this one I'm gonna want to get plugged into these trips. The better half has had her eye on Northern MI forever and that could be a total satisfaction tour. Shorter trips into the Southern Ohio strip-mined reserves would be a ball I would imagine from what I hear of friends with quads.
I'm in the heart of the "Northcoast". Cleveland Rocks. Thank you very much for the confirmation of what I might have here and the motivational coaching too. This one will be moving slowly but if you happen to check in and see me doing something that won't hold up gimme a dope-slap wouldja? _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Tue Jan 16, 2018 12:22 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
Yep no problem I am happy to see another off road bug here being put together, that has been kind of a mission of our small group down here since so many get turned to rust/dirt from weather. We will help anyway we can to get you on the road, I have a good stockpile of extra used thing parts but there is a couple good yards in Canton area for parts we usually go up there for. I have never had to chop for that, I do roll fender lips and notch/grind the lower lip of the fender well for turning clearance 94.49" Thing 94.5" Beetle same _________________ HRE in Westerville,Ohio
Posted: Tue Jan 16, 2018 12:29 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
Wheelbase is the same, on class11 we roll the fender lip. You are limited to keeping to a non Baja bug width tire in the front and rear though because of the fenders. If you change out those front coil overs and put a good set of off road shocks with the stock top Thing rubber snubbers you won't have issues. The beam should get hard hook and pin stops whenever you can get them welded in though. You get 3" of extra height in the front with Thing beams and the front spring pack is about 15% or 20% higher springrate over stock so other than the lip of the stock fender and the rubbing of the lower body lip in a hard corner I am not sure what clearancing they would be talking about. I clearance the lower body lip on even Bajas because of tire diameter. Your limited to a 235/75x15 on a C11 style. Maybe they are bouncing the car hard in a hard corner with a soft suspension setup. _________________ HRE in Westerville,Ohio
Posted: Tue Jan 16, 2018 6:07 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
Wheelbase is the same, on class11 we roll the fender lip. You are limited to keeping to a non Baja bug width tire in the front and rear though because of the fenders. If you change out those front coil overs and put a good set of off road shocks with the stock top Thing rubber snubbers you won't have issues. The beam should get hard hook and pin stops whenever you can get them welded in though. You get 3" of extra height in the front with Thing beams and the front spring pack is about 15% or 20% higher springrate over stock so other than the lip of the stock fender and the rubbing of the lower body lip in a hard corner I am not sure what clearancing they would be talking about. I clearance the lower body lip on even Bajas because of tire diameter. Your limited to a 235/75x15 on a C11 style. Maybe they are bouncing the car hard in a hard corner with a soft suspension setup. |
Great info. 235s are huge so... plenty. The 5 lug wagons I've got with this are 6 or 7 inch wide or so. There are some old timey 5 lug steelies popped up on Craigslist recently. Maybe I'll grab those for options.
I've rolled my fenders on my scraper so I get that.
I see Dark Earth working on pin and hook stops so there's a new use for the welder right there. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Tue Jan 16, 2018 7:03 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
The 235 some are using in class 11 are being mounted on 4 bolt stock rims on a stock T1 beam, a Thing spindle makes the width a little wider than a T1 but not by much. You might have to use an offset rim to keep the 235's tucked in a little bit. I ran 225's. I included a pic of a late 70's Thing beam modded with a platform stop for droop and compression before hook and pin were used. The stops were adjustable. This is on a Baja not a C11 style though. The beam has not been cut and turned nor adjusters installed. It's been holding up since 78. So much can be done just with a welder lol.
dustymojave Samba Member
Posted: Tue Jan 16, 2018 11:18 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
For wider fenders on a Class 11 style for a little more tire room, Creative Car Craft in Florida makes wider than stock (+2 and +4) fenders in stock style.
http://www.creativecarcraft.com/
Not inexpensive...But _________________ Richard
SoCalBajas Member
tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Wed Jan 17, 2018 8:32 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
there is a whole lot of awesome going on in that picture. Is your frame head clearanced at all for the location of the inner tie rod ends? _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Wed Jan 17, 2018 5:16 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
Once you head to Michigan, if you want a trail ride on the way north, I'd be glad to guide you! Yankee Springs, south of Middleville has a fun trail system and it only costs the MI recreation passport fee to ride them. Up north there are trail permits and orv permits that are required in many areas.
Lookin' forward to your build! _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
Posted: Wed Jan 17, 2018 6:18 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
there is a whole lot of awesome going on in that picture. Is your frame head clearanced at all for the location of the inner tie rod ends?[/quote]
No none was needed since the rack is moved rearward off the beam and because the slope of the panhead is going downhill a little bit more, they clear. This was done so long ago that most are not done this way anymore. There were issues doing it this way that had to be resolved when it was built, but it has lasted so long I don't want to change it because it was raced this way and kind of historical to me so trying to keep it early vintage oldschool. _________________ HRE in Westerville,Ohio
Posted: Wed Jan 17, 2018 6:21 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
there is a whole lot of awesome going on in that picture. Is your frame head clearanced at all for the location of the inner tie rod ends? |
No none was needed since the rack is moved rearward off the beam and because the slope of the panhead is going downhill a little bit more, they clear. This was done so long ago that most are not done this way anymore. There were issues doing it this way that had to be resolved when it was built, but it has lasted so long I don't want to change it because it was raced this way and kind of historical to me so trying to keep it early vintage oldschool.[/quote]
Thanks for the response! What kind of issues? Fabrication issues or did it not steer very well or have bad feedback? _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
Posted: Wed Jan 17, 2018 7:04 pm Post subject: Re: It's a Bug Thing, you wouldn't understand |
Thanks for the response! What kind of issues? Fabrication issues or did it not steer very well or have bad feedback?[/quote]
No it steers fine for not having PS but is typical of it's day. Only two issues, added support plates because of being mounted to the pan head which is fairly thin metal and a double U-joint added to ease angularity. It actually has improved tie rod angles to the spindle and rack. _________________ HRE in Westerville,Ohio
Posted: Thu Jan 18, 2018 6:50 am Post subject: Re: It's a Bug Thing, you wouldn't understand |
pullstart wrote: |
Lookin' forward to your build! |
Thanks Pullstart I'll look forward to that! Browsing the Yankee Springs Recreational Area website will motivate me to build this thing.
In the meantime... during the multi-step quest for semi-permanent storage I picked up the trailer from my buddies' house last night to drag to my brother's driveway in town, as a stopping point before heading to yet another spot later in the week. (I gotta love the network of foster parents helping me out on this ridiculous and illogical decision of mine to rescue this bug). On the highway had a massive blowout of right rear trailer tire, which peeled from the rim and took the right side lights with it!!!!!
With the trailer rim screwed immediately, in the dark, single digit temps, snowing, I made the executive decision to simply drag the mess for the last 7 miles as is. Here's what I parked in my brother's driveway.
I'm sure his neighbors will be thrilled to wake up to that sight today.
Saturday drudgery to come. Oh well.
Buggin... Never a dull moment! _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
