Auto trans in 68-71 Bay window ??
tinlizard
tinlizard is offline
PostPosted: Mon Jan 15, 2018 1:28 pm    Post subject: Auto trans in 68-71 Bay window ?? Reply with quote
Does anyone have experience with installing an auto trans in an early (68-71) Bay window? If not experience, solids ideas and theories would help.
I have no interest in discussing why I want to do this, or whether it's a good/bad idea (unless the whether is technical). Not wishing to be an *hole, it's just that all the previous threads I can find seem to degenerate to this off-topic angle.
It seems as if the type 3 auto would be the easiest swap. Any ideas?
Thanks!
Dave
68 Beetle Vert
70 Single Cab
79 Transporter
Abscate
Abscate is offline
PostPosted: Mon Jan 15, 2018 1:35 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Are you sure you can get CV joints and axles the right lengthS , with a capital S, for this conversion? That could be a crashing halt.
.ssS!
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Jan 15, 2018 2:11 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Transaxle output flanges are easy enough to swap. If I was installing a used trans, I would have them off to replace the output seals anyway.
Type 3 auto might be one way to go, but what about an early (003?) automatic from a 73-75(?) bus? The input shaft would need to be shortened, and a vacuum hookup plumbed in, but it might be easier, since it was made for a bus.
Wasted Youth has an excellent thread documenting the rebuild of one, so you can see all about the parts included and how they fit in.
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
pioneer1
pioneer1 is offline
PostPosted: Mon Jan 15, 2018 2:27 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
shifter cables are NLA so you'd need a complete donor. Would you also use a pancake engine?
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
tinlizard
PostPosted: Mon Jan 15, 2018 2:57 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
I could get long/short T3 axles, but haven't confirmed whether they would be a proper fit.
003 is certainly a possibility, if it's the better way to go.
Parts sourcing can be accomplished, I think, whatever I may need. I will use a stock ( but bumped to 1904cc) upright engine in the bus.
I'll search for Wasted Youth's post right now.
68 Beetle Vert
70 Single Cab
79 Transporter
danfromsyr
danfromsyr is offline
PostPosted: Mon Jan 15, 2018 3:02 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
to retain the T-1 engine, you'll need the T-III automatic flexplate as it's unique to a 1600 automatic fitment.
you'll either need to source a 'universal' case or hog out a hole in the DS face of the T-1 motor flange to access the 3 flexplate to torque converter bolts.
you;ll need the automatic from most any year bay. even aircooled vanagon. so 73-83. you can use a Waterboxer at but the cooler may interfere with the mounting into a Bay.
you'll need bay bus automatic driver & passenger axle shafts, they are unique and specific differing lengths
the T-III automatic willhave too high of a R&P unless you build up a much more powerful motor.
you will need to figure out the shifting cable, and the throttle linkage.. later AT 76-83 the throttle linkage is tied into the kickdown function of the automatic.
73-75 uses vacuum and an electric switch on the throttle pedal to facilitate in kick down..
Abscate wrote:
airschooled
Air-Schooled
PostPosted: Mon Jan 15, 2018 5:22 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
I asked about putting a late model bug auto-stick in an early bay a few weeks ago, but most people just heckled me so I took my beer and went home.
Robbie
www.airschooled.com
KentABQ Premium Member
KentABQ is offline
PostPosted: Mon Jan 15, 2018 6:09 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Robbie
...and took a header down the stairs. Shocked
Ya know you're never gonna live that down, right Robbie? Laughing
-Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!"
---WildIdea
Bus ownership via emoticons:
Very Happy Shocked Mad Sad Embarassed d'oh! Pray Brick wall Pray Dancing Dancing Dancing ---williamM
Abscate
Abscate is offline
PostPosted: Mon Jan 15, 2018 6:22 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Tough crowd when the band together to heckle you, kick you down the stairs, force you to convert, tell you your shafts are too short, and drink your beer
.ssS!
sodbuster
sodbuster is offline
PostPosted: Mon Jan 15, 2018 7:18 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Robbie
I would have heckled you too But I also would have explained why that is a very bad idea. Wink
TomWesty
TomWesty is offline
PostPosted: Mon Jan 15, 2018 8:00 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
My concern with the T3 tranny would be longevity. A bus is significantly heavier than any T3. I’m sure they didn’t engineer the T3 tranny for any more load than what was needed. I guess if you had the correct gear ratios to move a bus and drove smoothly and conservatively it might last a while....
tinlizard
PostPosted: Tue Jan 16, 2018 8:38 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Thanks, Danfromsyr!!! Exactly the kind of info I'm after.
So T3 flexplate, T2 auto axles, for sure. Sounds like 73-75 T2 trans would be best since the shift/linkage picture is simpler.
My calculation says the T2 auto is almost exactly the same as the manual, final drive-wise. 4.35 auto vs 5.37 x .82 = 4.40 for the manual.
Does anyone know whether the chassis-mounted shift linkage tube is different auto vs. manual? Can't tell from the Bentley.
68 Beetle Vert
70 Single Cab
79 Transporter
Amskeptic
Amskeptic is offline
PostPosted: Tue Jan 16, 2018 8:50 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
The bay auto box came only with the 5-point Type 4 engine/bell housing/nose cone mounts. The bell housing has two "ears" at the top to go into bell housing mount that has two rubber mounts just outboard. The '68-'71 bus has none of the bell housing mount super structure.
Likewise, the early bays with the 3-point Type 1 engine/transaxle mounts that were designed to handle weight and torque loads at the outboard ends of the Type 1 mustache bar and a different nose cone mount to the torsion tube.
You will find that the 003 automatic nose cone mount is *not designed to handle constant weight*. It is depending on the bell housing mount.
If you are planning on using a Type 4 003 autobox bell housing with a Type 1 engine, I think you are going to find a load of issues cropping up.
Colin
www.itinerant-air-cooled.com
danfromsyr
PostPosted: Tue Jan 16, 2018 10:35 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
he's definately going to have some obstacles..
the front trans mount is a good point but hardly too tough an obstacle.. well unless he can't or doesn't know anyone who can fabricate some.
in a friends 73 bay automatic, we made a new front transmission mount using a round vanagon front mount and some heavy angle steel and a welder.. wasn't difficult. and allowed for a better front mount.. though that 73 bus had the over the bellhousing engine carrier mount too.
Abscate wrote:
tinlizard
PostPosted: Wed Jan 17, 2018 10:16 am    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
I agree, guys, bit of an obstacle. But I'm only a few miles from Rusty Bottom Garage in Smyrna, TN, and Billy has good ideas and mad skills. I think we can hang the nose safely and securely.
68 Beetle Vert
70 Single Cab
79 Transporter
danfromsyr
PostPosted: Wed Jan 17, 2018 2:09 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
you'll spend most time figuringout the throttle, shifter electrical and vacuum linkages.
but as FYI, on our front mount, we moved the vanagon round part ahead of the rear torsion and then made the trans to mount bracket reach upto the vanagon mount.
as there is very little room between the transmission and the torsion tube.
the front mount is for the driveline to push against in a fore/aft location.
the rear mustache bar is for the side to side twist force.
ok, I did a little google-fu on the type3 automatic engine case.
you'll need to relieve the Type1 case in a similar fashion at the bottom of the bellhousing to access the flexplate to torque converter bolts. unless you source a T-III automatic 1600cc engine complete and convert it to upright cooling.
and a pic of a T-III flexplate
Abscate wrote:
tristessa
tristessa is offline
PostPosted: Wed Jan 17, 2018 2:15 pm    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
The transmission portion is essentially the same between T3, T4 and early (003) Bus automatics, the differential/governor section is what changed. Should be just fine...
tinlizard
PostPosted: Thu Jan 18, 2018 8:56 am    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Thanks to everyone who contributed! Next step for me is to begin sourcing pieces/parts.
Still looking for an answer as to whether the long tube under the chassis that holds the shifter rod for manual trannys is the same and in in the same location as the one that the auto cable runs through.
68 Beetle Vert
70 Single Cab
79 Transporter
danfromsyr
PostPosted: Thu Jan 18, 2018 9:02 am    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
personally I would build around and source a Morse style push-pull cable for this vs sourcing the rare and hardly ever pulled for parts stock bit.
I offer these ideas as I've the same plan myself.
well an automatic in a 71 bay, but not with a air cooled motor Wink
Abscate wrote:
WestyPop
WestyPop is offline
PostPosted: Fri Jan 19, 2018 1:18 am    Post subject: Re: Auto trans in 68-71 Bay window ?? Reply with quote
Just a thought, since the torque converter heat does migrate into the engine case, as well as the tranny... the waterboxer Vanagon automatic trans cases have taps for external ATF cooling, instead of the (overrated IMHO) air-cooled converters of the Type 2 & 80-82 Vanagon bus automatics.
As far as gearing, with a 1904cc (stroker) engine, you might even do better with a slightly higher ring & pinion ratio to keep the cruising RPMs down.
Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others)
