Nutter1973 Samba Member
Joined: June 16, 2015 Posts: 22 Location: Kent England
Posted: Tue Jan 16, 2018 7:23 am Post subject: Has my Distributor's electronic points messed up ??? |
Hi All, recently fitted a Distributor with electronic points...has anyone experienced these going wrong or not working ??? fuel getting to the carb, solenoid OK but no spark at the plugs????
car just stalled whilst moving and then will not start again
Gary |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Tue Jan 16, 2018 8:16 am Post subject: Re: Has my Distributor's electronic points messed up ??? |
Yes... they do fail. some sooner than others. install a set of points and condenser and that should fix your problem. _________________ Glenn
Member #1009
#BlueSquare |
bluebus86 Banned
Posted: Tue Jan 16, 2018 9:36 am Post subject: Re: Has my Distributor's electronic points messed up ??? |
If you would provide more info that maybe of help diagnosing the problem.
Which brand of ignition system?
which dizzie?
did this dizzie and ignition run ok for you prior of not? if it ran ok prior, what if anything was done prior to failure?
Have your confirmed wires connections are correct?
Confirm full voltage at coil primary terminal? also make sure electric choke , fuel solenoid are not drawing down the voltage at coil primary.
I have had Pertronix brand ignition for decades with only one issue, when all four spark plug were removed, and engine cranked for a compression test, the Pertronix died. never crank the motor with the spark plug removed unless the pertronix power wire is removed first.
More details please!
Good Luck, Bug On with a Nice Blue Spark! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Zundfolge1432 Samba Member
Posted: Tue Jan 16, 2018 6:11 pm Post subject: Re: Has my Distributor's electronic points messed up ??? |
What is a dizzie ? |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Jan 17, 2018 8:35 am Post subject: Re: Has my Distributor's electronic points messed up ??? |
It's the new stuff that is problematic. The NOS points including non Bosch are fine. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Wed Jan 17, 2018 9:33 am Post subject: Re: Has my Distributor's electronic points messed up ??? |
I like Echelin brand points from Napa the contacts seem to line up better. |
