AlmostHeavenWV_VW Samba Member
Posted: Tue Jan 16, 2018 12:37 pm Post subject: Back up / Spare /emergency Distributor Options |
Disclaimers:
*This thread is intended to spark(pun intended ) discussion for the roadside spare dizzy carried in the car to get you home if the installed dizzy goes out on a trip, not intended as discussion of changing my installed dizzy (an OG Bosch 019)
*This thread is not another debate thread of SVDA vs centrifugal only- there are already lots of threads and discussion on that.
*Also this is not the thread to debate "points vs points replacements"- there are plenty of threads on that topic as well.
and as always....
*I searched but found no similar thread, if it exists- please direct me towards the light
Now for the fun stuff
Considering that:
(1) good, OEM/NOS bosch dizzys are getting rarer by the day
(2) new, aftermarket dizzys seem to be a crapshoot as far as quality goes
(3) it is wise to carry a pre-timed, ready to go dizzy in the in-car spares bag
(4) most agree that a cheap 009 is acceptable for this role of emergency spare (I like to think of it as a doughnut spare tire-gets you there, but swap it ASAP)
What currently available 009 dizzy would you all recommend/have currently?
(either as your primary or roadside spare dizzy) I have found the following that seem even worth considering:
http://www.jbugs.com/product/0231178009.html (Japan?-"bosch style")
http://www.jbugs.com/product/0231178010.html (Kuhltek)
http://www.cbperformance.com/product-p/2006.htm (Canada-accuvance)
http://vwparts.aircooled.net/009-Distributor-Made-in-North-America-p/009na.htm
as well as these RockAuto options (specifically the Spectra or Cardone select- ~$40 each)
http://www.rockauto.com/en/catalog/volkswagen,1973,beetle,1.6l+h4,1368851,ignition,distributor,7108 _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Tue Jan 16, 2018 12:49 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
I have used (now-vintage) German 009 distributors in both my VWs, since the 1970s. I carry spare points and condensers in each's trunk, but NEVER had to use those. And I used to travel 400 miles through Arizona-California desert in my 1970 VW, alone, and well before cell phone days.
I am interested in learning more about the KuhlTek distributor though; I assume that it is made in China to a certain set of specifications, but I don't know. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Tue Jan 16, 2018 1:00 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
I am with Cusser, never trashed a distributor, always carry extra points, condenser, cap and rotor, been running Pertronix since they came out and never been stranded.
Now there was a brief period I tried a Mallory Unilite, brief as in less than a month, during that time I carried a spare 009 just in case, had to install it one night after midnight South of Santa Fe, NM. The Mallory never got installed again. Lesson in how to waste $400 plus dollars and practice mechanic skills on the side of a very dark road.
Chances of trashing a distributor (Bosch style) with points or electronic are slim, spare parts take up less space.
But if you gotta have a spare get the CB one or look for a good used Brazilian or German 009. |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Tue Jan 16, 2018 1:45 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
I have never carried a spare distributor. When my Beetle was my only car I carried spare points but never had to use them. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Tue Jan 16, 2018 1:56 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
Cusser wrote: |
I am interested in learning more about the KuhlTek distributor though; I assume that it is made in China to a certain set of specifications, but I don't know. |
Don't bother with the kuhltek, waste of time, and no end of sorrows as it rapidly wears and wont hold steady timing over time... _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Tue Jan 16, 2018 2:13 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
Cusser wrote: |
I have used (now-vintage) German 009 distributors in both my VWs, since the 1970s. I carry spare points and condensers in each's trunk, but NEVER had to use those. |
busman78 wrote: |
Good insight to the reliability of OG Bosch.
Lingwendil wrote: |
Don't bother with the kuhltek, waste of time, and no end of sorrows as it rapidly wears and wont hold steady timing over time... |
Alright, strike one for Kuhltek
Keep the insights coming! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
tspot100 Samba Member
Posted: Tue Jan 16, 2018 3:26 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
i carry an oem bosch unit in each vw. i swap out the spare unit at tune up time and rebuild the other and carry that as a spare.... think its a muir idea. never used aftermarket so i have no insight, but an 009 works fantastic on the volksair. |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Tue Jan 16, 2018 3:32 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
For total surety and piece of mind, you should carry spares for every part on the car.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
mikewilkinson007 Samba Member
Joined: October 26, 2016 Posts: 554 Location: Nebraska
Posted: Tue Jan 16, 2018 4:47 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
In my experience/opinion:
Odds of part going bad and leaving you stranded:
Distributor: 1-100,000
Rotor: 1-100,000
Cap: 1-100,000
Condenser: 1-42,681
I did the math. 😊
But to answer your poll/question. The cheapest 009 I could find to get me home if I were to store one in the trunk for emergencies. _________________ 72 Super - Marina Blue
1641 AH Dual Port
Dual Weber ICT 34's
Bosch 034
Long Gone: 70 Vert, 66, 68, 73SB, 70, 72, 61 Rag and a 64 with a cinder block in the spare tire well. |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Tue Jan 16, 2018 4:49 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
I actually like he idea of carrying a "ready to go" spare distributor. I've broken down twice with 2 different Bugs and both times it was the condenser that failed without warning. The new condensers are junk even if they say Bosch on it. For me it's much easier and quicker to just swap distributors since the condensers on mine are in the back and I need to either pull the distributer out, or turn it to get to the screw that holds the condenser in which then means having to set the timing again. So I'd rather swap distributors instead of having to carry a timing light and going thru all that work. Gotta find a spare for my 74 now.
Maybe this video will be of help to someone:
https://www.youtube.com/watch?v=7xF4JHxAYto&t=138s |
gt1953 Samba Member
Posted: Tue Jan 16, 2018 7:49 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
I have to do just that replace the distributor on the side of the road. Reason defective condenser. What I carry is the German 009 with clamp installed cap and rotor in place points set and pretimed. Hope that makes some sense. Swap the plug wires to proper location, takes a few minutes and on the road again. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
airschooled Air-Schooled
Posted: Tue Jan 16, 2018 8:12 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
I carry a spare Echlin (Napa) points and condenser somewhere in the car. If it's a vacuum-only distributor like both my current VWs, I'll carry a spare vacuum can. There's nothing else on the distributor that can physically go wrong and leave me stranded……
www.airschooled.com |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Jan 16, 2018 8:33 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
The new Bosch condensers don't have their logo on them, not much of an
Used SVA= vacuum only distributors are still very common. These disributors need to match the carburetor. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Tue Jan 16, 2018 9:01 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
Chad1376 wrote: |
That's one serious "bag of spare parts"!
AWESOME! I couldn't stop laughing! _________________ AshMan40
Posted: Tue Jan 16, 2018 9:44 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
If you end up on the side of the road w/ distributor/ignition related issues it is much faster/easier to swap out the distributor with one that has been previously timed and has the hold down clamp on it. This avoids the need to spend time adjusting things.
I would also add that this replacement distributor should be points/condenser based and NOT have an electronic ignition. In the dark if you accidentally install the electronic ignition wires backwards and short it out you are back where you started with a dead ignition system. The single wire of the points reduces the chance of a catastrophic failure.
If you are swapping a 009 in place of a SVDA/DVDA distributor be sure to carry a few screws to plug the loose end of the vacuum hoses.
I am surprised to see on the Rockauto site SVDA distributors going for so cheap. I knew there were rebuilt SVDA distributors but I thought they started around $120. _________________ AshMan40
Posted: Tue Jan 16, 2018 9:55 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
ashman40 wrote: |
I am surprised to see on the Rockauto site SVDA distributors going for so cheap. I knew there were rebuilt SVDA distributors but I thought they started around $120. |
Yeah, my thoughts too- I would wager that they are made with asian cores.
How do you say Bosch in Mandarin?
Great discussion guys! Keep 'em coming! I'm learning lots of things over here! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Xevin Samba Member
Posted: Tue Jan 16, 2018 10:58 pm Post subject: Re: Back up / Spare /emergency Distributor Options |
AlmostHeavenWV_VW wrote: |
Botched It’s the same in all languages. As in, Another run of Botched condensers. Not making fun of Mandarin speakers.
IMHO, Bosch is going down the path of EMPI. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Jan 17, 2018 1:26 am Post subject: Re: Back up / Spare /emergency Distributor Options |
If on a long trip (not just putting around town), I carry spare points, condenser, my timing light, and tach/dwell. I carry a flashlight in case something happens when it’s dark.
I haven’t had a breakdown on a trip, thus far—-just an accelerator cable break on an in-town shopping trip, a mile away from home (four and one-half years ago).
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Krochus Samba Member
Joined: January 01, 2017 Posts: 892 Location: NW Arkansas
Posted: Wed Jan 17, 2018 5:25 am Post subject: Re: Back up / Spare /emergency Distributor Options |
I carry a spare distrubitor on the clamp ready to go and an extra coil.
I don’t have a spare tire. Just plugs and a compressor.
Think about that |
