Here's Sonya, a Mexican 1974 beauty
Page: Previous  1, 2, 3, ... 11, 12, 13  Next
Tom Powell
Tom Powell is offline
PostPosted: Sun Jan 21, 2018 5:32 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
tonysantacruz wrote:
Went to the shop yesterday to see how the bus is coming along and the guy showed me the intake manifold, which has a small hole. I didn’t take any pictures of it, will do tomorrow, but this is the part number. Is it safe to weld or it’s better to replace?
First question: How big is the hole?
Second question: Are there any other holes or weak spots?
Third question what caused the hole?
I would be inclined to patch one small hole with JBWeld, a KISS procedure. A smoke test will reveal any other holes and the quality of a JBWeld repair.
Do a search on how to build a smoke tester. You'll probably find a post by Aeromech.
Aloha
tp
TitoMX
TitoMX is offline
PostPosted: Sun Jan 21, 2018 7:20 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Ok that’s funny.....I have a Mexican Bus and his name is Tito (seriously). I never expected that there was a Tita out there.
tonysantacruz
tonysantacruz is offline
PostPosted: Mon Jan 22, 2018 11:29 am    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Aloha
tp
Here are the pictures:
Here's the hole:
This is the complete part:
Close up of the back of the dashboard instruments: nothing is plugged.
And even then, the wire is suspect. I'm getting a few manuals in color so I can have the electrical guy take a good look at them and replace what is wrongly placed. There's duct tape everywhere.
tonysantacruz
PostPosted: Wed Jan 24, 2018 9:39 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Also, I’ve seen a few fuel gauges from 73-75 and they have a vibrator, and mine doesn’t have one. Not sure if it needs it or it never had it; looks pretty smooth from the back.
tonysantacruz
PostPosted: Fri Jan 26, 2018 2:38 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Swung by the shop today, removed the plastic covers and took a peek: ack! Original panel floor has been replaced by sheet metal, I think. Gonna post pictures later. Looking for replacement options.
tonysantacruz
PostPosted: Fri Jan 26, 2018 3:03 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Here’s the engine with the new muffler. Hole has been fixed.
Here’s the below the floor tour:
tonysantacruz
PostPosted: Fri Jan 26, 2018 3:08 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
tonysantacruz
PostPosted: Fri Jan 26, 2018 3:11 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
tonysantacruz
PostPosted: Tue Jan 30, 2018 11:47 am    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Floor is gone, replacement is on its way and I decided to take a look under the floorboards. Lots of sanding, welding and rustproofing left to do.
And another picture of the dash. Lots of love needed there. Replacement windshield wiper lever is also under negotiations. On the dash they left the original headlight button, but they put the lighter next to it, and then they bypassed the steering column switch and put the wipers to the right, using another headlight pull-button. The hazard lights were replaced by a rectangular one, from a post 80s bus, I think. All that is getting moved to its proper position.
tonysantacruz
PostPosted: Wed Jan 31, 2018 2:40 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Replacement parts are stsrting to show up. I think the body work can begin in earnest as early as next week. Got the filter, door handles, sun blocking thingees, windows seals...
Incidentally, what is going on with the headlight? Needs to be tightened from the inside?
tonysantacruz
PostPosted: Wed Jan 31, 2018 3:35 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Oh, and someone told me that there should be a seal or some sort of plastic/rubber thing here, between the track cover and the metal from the bus. To keep it from getting water or something.
Not sure if this is true, just wanted to see if anyone has heard of it.
Bendejo
Bendejo is offline
PostPosted: Thu Feb 01, 2018 5:48 am    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Yes there is rubber that goes over the vertical section of the track cover, maybe for cushion between the parts.
Installing them can be challenging. I got mine from Wolfsburg West.
tonysantacruz
PostPosted: Thu Feb 01, 2018 8:27 am    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
You mean these: https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211843800
tonysantacruz
PostPosted: Thu Feb 01, 2018 9:49 am    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Here's the fuel tank, for the "which lines come out of it" question:
tonysantacruz
PostPosted: Fri Feb 02, 2018 6:32 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
The Thing oil bath is here.
I had some questions about what went where, but I found this thread ( https://www.thesamba.com/vw/forum/viewtopic.php?t=404060 ) for a Thing and I hope I can extrapolate the answers and put them correctly on the bus. I’ll send pictures.
Here 8t is:
[/url]
tonysantacruz
PostPosted: Wed Feb 07, 2018 5:41 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Body work has begun:
busdaddy
busdaddy is offline
PostPosted: Wed Feb 07, 2018 5:59 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
That just draws air from the engine compartment, ot a tube leading to a dust free cool air source higher up if you do alot of off roading.
The one facing down connects to the preheat pickup between the pulley and RH heater fresh air tube on the rear tin (if you have one).
The small vacuum nipple goes to the manifold under the carb.
That connects to the large nipple beside the oil filler cap visible in the background.
Слава Україні!
tonysantacruz
PostPosted: Thu Feb 08, 2018 5:48 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
They took out the fuel tank and, lo and behold, the fuel breathing lines were not connected to a canister. I'm thinking that's why the bus smelled like gas. Canister being sought after and will be installed.
Original sender. I'm told it's dead, Jim.
More paint coming off.
tonysantacruz
PostPosted: Fri Feb 09, 2018 5:02 am    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Yesterday I spoke with the machanic and had some conflicting advice on that last point. I then looked arounf and found this:
Last one on the back goes to the canister or the oil cap?
tonysantacruz
PostPosted: Wed Feb 14, 2018 8:25 pm    Post subject: Re: Here's Sonya, a Mexican 1974 beauty Reply with quote
Work keeps chugging along.
Now here are the colors I want. The red looks fine, but the pastel white looks a bit rich to me. I think I’m going to ask them to tone it down.
Page 2 of 13
